Old 19-05-2016, 01:29 AM   #1
Crazy Dazz
Default White Smoke = Water?
So, after sitting all day in the car park, when started, my daughter's car starts billowing white smoke.
However, after being idled for a while, then left to cool, and re-started, no sign of anything unusual.
To me, white smoke means water (coolant) being burnt.
So I'm thinking: Car driven to work, gets nice and hot, under pressure head-gasket starts to leak. When car is parked, continues to leak under pressure and builds up in cylinder. Car is started, burns off coolant and eventually purges all from exhaust. Engine turned off, not too hot, so no further leakage. Starts fine next time round.
The coolant looks fine, as does the oil. The coolant level was still ok.
So, with the engine cold we have topped the coolant to a precise level. Will drive the car to work, park it up, then check the level in the evening when its cold again.
It's also possible that it was simply a bunch of condensation after being driven and then parked on a cold day.
Am I missing anything?
Any other possible culprits for white smoke?
NB: It is a Nissan Tiida, with a typical, disposable, Thailand engine. So it's not improbable that the gasket or head has started to dissolve.
Crazy Dazz
Kicking Hippies in the Balls since 1966
Old 19-05-2016, 05:53 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: White Smoke = Water?
I think you are on the right track for the initial diagnosis although if it is using neither water or oil then it is going to be harder to diagnose.
Russ
Observatio Facta Rotae
Old 19-05-2016, 09:40 AM   #3
whitelion65
whitelion65's Avatar
Auto-trans fluid?? Pulled in via the manifold vacuum line.??
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2016, 11:51 AM   #4
11ford11
does it disappear quickly (water) or hang in the air for awhile (oil) -
trans. oil as mentioned by whitelion65
Old 19-05-2016, 11:58 AM   #5
falconhell74
falconhell74's Avatar
How cold is it out side temp? It just sounds like condensation in the exhaust as you haven't mentioned that it is hard to start or runs rough till it dissipates.
If it was a head gasket issue it would run rough and have bubbles in the cooling system .
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2016, 12:04 PM   #6
Silver Ghia
Silver Ghia's Avatar
Most likely just condensation in the exhaust system.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 19-05-2016, 12:18 PM   #7
Pis-ton broke
Pis-ton broke's Avatar
might be the valve stem seals/guides. take it down a big hill and see if it blows smoke then. if it does, might need to look into getting them replaced
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2016, 01:19 PM   #8
Olbucko
Olbucko's Avatar
Most cars blow clouds of condensation from the exhaust on a very cold day when they are dead cold, it's only water vapour.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
Olbucko is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2016, 06:56 PM   #9
XB GS 351 Coupe
You have answered your own question. It's just condensation in the exhaust burning off, all cars do it, second time around no condensation so no white smoke.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2016, 09:09 PM   #10
ea90gl
ea90gl's Avatar
Hopefully for your self it is only just a matter of water evaporation due to the colder weather.
In saying this, and I don't mean to worry you, I once repaired a 92 Ford laser which had similar symptoms as you have described. It would blow white smoke on start up after being stationary for a while with no other symptoms of any head issues (rough idle/ running, milky engine oil, bubbles in radiator whilst running etc).
Once the head was removed it definitely revealed that the head gasket was faulty so that ended up having to be replaced and finally resolved the issue.
However as you have mentioned, just top up all relevant fluids and see how things go over time. If you notice that no fluids are getting low down the track then you should be fine
ea90gl is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2016, 02:04 AM   #11
Crazy Dazz
Thanks everyone.
So far, it has impossible to substantiate any coolant loss, or replicate the problem to any significant degree.
Will keep monitoring the coolant, but fingers-crossed it was just some freak confluence of weather and condensation.
Crazy Dazz
Old 21-05-2016, 12:46 PM   #12
castellan
Running E10 seems to do that more so as well on cold days.
castellan is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2016, 01:01 PM   #13
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
Best sell it and get her a ford.
BA BF FPV starter button repairs. PM me.
Xtreme Ford Tuning
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
Thread Tools
Display Modes
