07-01-2005, 02:23 PM | #1 | ||
Posts: n/a
Hi Guys - I started a thread in the workshop about connecting up a touch pad to my car (AUII).
http://fordforums.com.au/showthread.php?t=731 Before I go ahead with purchasing a touch pad I need to answer a few questions like where are the central locking relays/triggers. I'm also looking for a AUII wiring diagram or advice as to where I will find the wires I need to tap into to get this unit going. This is the unit I want to hook up - the first link is its wiring diagram and the second is an example install. http://www.keyless.com/PDF/KE1601WD.pdf http://www.accesscnc.com/keylessinst.html Any advice? Thanks, Agent |
07-01-2005, 03:33 PM | #2 | ||
Smile
Hi man .You will need 2 changeover relays rated between 20 -30 amps for the door locking on the AU. The wiring is in the computer above your left knee .The trigger is a negative and an interrupt to work the central locking The system in the diagram needs relays to give a solid earth pulse trigger for central locking.
You will have to bring this computer down from its position by unscrewing it and manouvering it out.Once out you will need a logic tester..NOT TEST LIGHT...or you may destroy the computer.You must probe to find the appropriate wires then fit the relays in the correct way. The relays should have pins 85,86,87,87a and 30. Looking at that idea I must recommend that you do not buy it.This will be outside of the vehicle in an exposed position.Kids will not leave your car alone .A thief would probably take the device off gain access to your door rods and unlock the car manually via the holes. The other potential problem I see with this device is in the case of where it is physically removed and a drill battery with 15 volts reversed is connected to the wires..Will it unlock the doors? Will it blow the alarm up? What steps are taken to waterproof the control unit? I think there is a great potential for water damage,especially with the amount of attraction it wil cause .. cheers Stav Last edited by Stav; 07-01-2005 at 03:40 PM. |
07-01-2005, 09:56 PM | #3 | |||||
Posts: n/a
I also plan to fill the space where my keyhole used to be with fibreglass to block access to the rods. Quote:
http://www.keyless.com/PDF/KE1602WD.pdf Quote:
It's a solution in progress - I figure my car will be harder to break into with no keyhole. |
07-01-2005, 10:27 PM | #4 | ||||||
Smile
If they drill it how will you get in ? Last edited by Stav; 07-01-2005 at 10:28 PM. |
07-01-2005, 10:41 PM | #5 | |||
07-01-2005, 10:55 PM | #6 | |||
Posts: n/a
If someone damages the keypad there is still the remote and vice versa for if the remote fails/is lost. I figure (although I could be wrong) that since there are two relays for the door locks (one for the drivers side and one for the other three doors) it is unlikely that both would fail at the same time. In short I dont have a great soltuion yet. |
07-01-2005, 10:58 PM | #7 | |||
Posts: n/a
Even if the alarm system fails it dont think it will really matter. The keypad is self contained and maintains its own pin codes etc. It triggers a relay to turn the alarm on/off (as far as I can tell). I think it also triggers the relays for the central locking. As far as I know the AUII has two relays for the doors - one which unlocks the drivers side and one which unlocks the other three. I figure its unlikely for both to break at the same time so I should always be able to get into the car. (So long as there is power, and if the battery is flat the car is not going anywhere unitl I get some power from somewhere. When I do I can power the door system from the side of the car as I mentioned.) |
07-01-2005, 11:04 PM | #8 | |||
