View Poll Results: Do you like exhaust crackle
No, only bogans like it 15 8.38%
Yeah, if it's done tastefully and not over the top 95 53.07%
Hell yeah! I love me some overrun snap! 69 38.55%
Voters: 179. You may not vote on this poll
Old 21-11-2013, 04:16 PM   #31
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
Default Re: Exhaust crackle
Originally Posted by FlipXW View Post
Bloody F&F strikes again. Why would you double clutch in a car that's transmission has syncros? All its going to do is slow you down. Heel and toeing on the other hand (which I presume your talking about) yes sounds awesome when done right especially with crackle.
Yes, heel and toe when braking. That's the only way isn't it?
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 21-11-2013, 04:28 PM   #32
irish2
I believe a good crackle comes from more efficient exhaust scavenging. Only from anecdotal evidence though.
I had twin 2" exhaust after 4 into 1 heads on an AFR headed 306. Sounded angry. Put twin 2.5" and she sounded angrier, and had massive crackle from a high RPM lift off. Nothing else was changed except from the header flange back.
irish2 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2013, 10:47 AM   #33
GT69
GT69's Avatar
This yes - http://www.youtube.com/watch?v=2J8BM...RY1Om8kU7Jbcaz
POS car that sounds broken, no.
Current Ride - 2013 Ford Ranger, XLT 4x4, ARB kitted brick
Former Current ride - 09 XR6T in Octane, with a pinch of Sports pack
Weekender - Ford Cortina 1969 coupe
Project - 1968 Ford Cortina 4 door
GT69 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2013, 11:00 PM   #34
devoGT
Originally Posted by aussie muscle View Post
Isn't the crackle just unburned fuel igniting in the exhaust pipe?
Yes, the "Crackle and Pop" that occurs on deceleration is a function of the tune in the PCM. The background is that when a deceleration condition occurs, the PCM / ECM uses a different timing table than the normal high / low tables. This "coast down" timing table is used to help slow the car down and assist with engine braking. This table is used prior to entering Deceleration Fuel Cut Off ( DFCO ) and in stock form tends to have negative timing values.
When you start to slow down and use the engine to aid in braking, this table is used and the timing values go from BTDC to ATDC. Because the timing has been pulled so far back, the fuel burns slower and is still burning when the exhaust valve opens. This results in some unburnt mixture entering the exhaust with the burning mixture, and as the gases expand they explode in the exhaust. This results in the pop / crackle.
If you get the car tuned, many tuners will dull the coast down table down a bit so it will reduce the occurrence of the pop / crackle before DFCO kicks in and stops it.
devoGT is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2013, 12:44 AM   #35
XR6_661
Cane Farmer
XR6_661's Avatar
General consensus - We are all sad
1994 ED XR6T - Cobalt Blue.
2009 FG XR6 - Black.
Originally Posted by Tex
I couldn't give a crap how many are in their family, what gay passtimes they paticipate in, or whether they have a cat, dog or a freaken fish.
Keep your stinking family to yourself god damn it.
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2013, 10:18 AM   #36
pottery beige
reverse double thong clap award
crackle
is
crap
pottery beige is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2013, 11:42 PM   #37
XB GS 351 Coupe
Hate the crackle, sounds cheap and nasty like there is something wrong with the car.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2013, 11:47 PM   #38
Chrisosicko
ADELAIDE
Must of never heard a worked boss335 on over run mate
BOSS 335 MK11 #607
Black, ZF 435 RWKWS TUNED BY BRUCE HEINRICH POWERED BY HERROD
Chrisosicko is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2013, 04:20 PM   #39
Alan D Segal
Call me 'Al'
Location: On a flattened-out cardboard box out the back behind the wheelie bins.
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Good contributor.
Because racecar...
Probably just get your car impounded if you've got a modified car that does it in QLD under normal street driving conditions though.
Alan D Segal is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2013, 06:53 PM   #40
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
What about the "cowboy crackle"...?
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 01:36 AM   #41
Dave R
Member
Technical Contributor: For members who share their technical expertise. - Issue reason: Valued contributor especially in the FG threads. Offers help and information to all. Posts are always in a positive manner.
I'm on the fence about it- sometimes it can sound horrible. One example I do like is the SLS AMG, such a beautiful sound-
http://www.youtube.com/watch?v=xG8nQIBl7ig
Dave R is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 02:16 AM   #42
MercurySilver
Isn't it obvious?
MercurySilver's Avatar
i like the crackle when its foot flat from 2nd to 3rd in the turbs
08 Strike G6E T.
10 Ergo G6E
Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens
MercurySilver is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 09:30 AM   #43
Express
Bathed In A Yellow Glow
Express's Avatar
Mercedes and BMW’s performance cars do it in normal driving conditions and get away with it without worries.
Express is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 09:35 AM   #44
MercurySilver
Isn't it obvious?
yup and harleys can be as loud as an aircraft
go figure
08 Strike G6E T.
10 Ergo G6E
Old 26-11-2013, 04:23 PM   #45
Alan D Segal
Call me 'Al'
Because the cops automatically pull over the falcon/commodore in the lane next to it.
Old 26-11-2013, 07:49 PM   #46
XP6
Formerly ST170ish
XP6's Avatar
Crackle like a solid cammed clevo with a decent 2.5" twin.... Love it!
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!!
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 08:07 PM   #47
STINKY NINJA
Awesome car and motor with exhaust crackle that makes my skin crawl...
I hate it with a passion,it sounds like a cheap slapper 253.
Hate it!
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 08:15 PM   #48
XHBrad
XHBrad's Avatar
Loved the cackle and pop from my old XR6, really missing the sound.. Can't get that from a turbo diesel :/
Current-2013 SR5 Hilux TJM bullbar and bashplates, 2" lift, spotties and awesome fuel economy
Previous-
93 ED XR6 5 speed, dumped and exhaust
97 EL Ghia auto luxury, on it's guts
94 ED Futura 5 speed tucking with exhaust
97 XH ute, 5 speed with P-Plate spec exhaust
98 AU1 forte AU gheyness
XHBrad is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2013, 01:21 AM   #49
SPArKy_Dave
Too many Fords........ :)
SPArKy_Dave's Avatar
Hate it!
Like this?
http://www.youtube.com/watch?v=9WQmaY7t9tQ
or this?
http://www.youtube.com/watch?v=MtdujYxNmkY
Current Projects
97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY
93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal.
95 XG ute - awaiting a head gasket...... grrrrr.
74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto.
XB Coupe and Van TV Ad
you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it
SPArKy_Dave is offline   Reply With Quote Multi-Quote with this Post
