Closed Thread
Old 18-05-2013, 02:47 PM   #511
nstg8a
3..2..1..
nstg8a's Avatar
Default Re: HSV GTS LSA lettuce tomato & special sauce on a sesame seed bun
Originally Posted by timetaker View Post
Hi
This is my first post.
The VF GTS has captured a lot of headlines lately and it will be a little sad when Ford has to hand the performance/power mantle to GMH.The GTS will be great value compared to the European competitors,which GMH are targeting.I hate to say it but it will be a level up on the GT in terms of performance as well as in price range.
I don't believe that Ford will counter with a higher performing GT,sure the next updated Falcon FPV will have more power and torque but not to the level of the GTS....it would be very costly!
One solution would be to shoe horn the 5.8L GT500 engine in the GT.However with such power(492 kw) and massive torque(854 nm)that significantly exceeds the LSA,the Falcon would require serious re engineering input....again too costly.
Also we need to be ready for any GTS vs GT YouTube clips.I expect a number of Holden supporters "sticking" it to the Fords which is understandable considering they've been habouring pent up frustration for a number of years.
Pretty sure the 5.8 is physically too big for the falcon anyway.
Best bet would be the rumoured next gen mustangs turbo coyote.... It will open a can of whoop *** on the lsa
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline
Old 18-05-2013, 02:53 PM   #512
ford man xf
Hi
You are aware of the true power the FG Coyote makes already at the wheels? It's not massively off what the GTS will be pulling (that is assuming how HSV go about quoting actual figures and how much drive train loss the GTS will have, this would be similar drive train loss to the FG GT.)
The engine the GTS uses is a very pricey version I believe, someone may know what they cost just for an engine?
It's pretty amusing though, considering the XR8 next year will be reborn with the same spec engine as the FG GT, could you imagine being a HSV owner forking out all that money on a brand new GTS, then pulling up to the lights next to a FH XR8 and then sitting side by side all the way to 100 and beyond
Even more embarrasing would be the lower spec variants of the VF in HSV's stable getting whopped by a factory XR8.
ford man xf is offline
Old 18-05-2013, 03:02 PM   #513
ford man xf
Direct Injection on the current 5.0. I read that DI is expensive though, so maybe if they do this and match or exceed the GTS power figures they will price it similary as well, then the GS can get the power level that the current GT has leaving the GS to compete against the lower spec HSV models, which it will beat anyway so maybe not.
I'm hoping that they release a beefed up version of the F6 for the new Falcon, it's obvious that it will be the last of the straight sixes made here.
Old 18-05-2013, 03:04 PM   #514
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
The 5.8 is still based on the 5.4 so it should fit, but it would be a massive exercise to do so when it would be much simpler just to get more power out of the Miami package.
Needless to say they still don't have a drivetrain that gets the best out of the power they're making now
FPV GTHO is offline
Old 18-05-2013, 03:25 PM   #515
satria
FOXWHO
satria's Avatar
I'm not trying to sound negative here I'm asking out of pure curiosity, how much does a GT 335 actually make then? I always here about people saying it's way higher than the badge says, is there proof of this and can you give some examples? Also, is it every single one that rolls out of the factory that pulls these higher figures or are the odds just better if you buy a GT that you may get one with higher output compared to others?
I don't doubt it to be true, I'm just curious about how much higher it supposedly is. Especially when i plan to upgrade the family runabout to a nice new GT
satria is offline
Old 18-05-2013, 03:35 PM   #516
Motorbreath310
Has anyone driven and compared a normal GT to an R-Spec? Was it much better? I'd like to see FPV focus on the grip and handling side of things before cranking more power out. And fix the cars 'stance'. GT's on stock suspension remind me of gym junkies that skip leg day.
Motorbreath310 is offline
Old 18-05-2013, 03:48 PM   #517
UberKnee
The One Who Knocks
UberKnee's Avatar
Every thread I've seen or video I've seen with someone having chucked a new 335 GT on a dyno, the figures come back with it about 320-330kw at the wheels, which puts it at 400kw+ at the flywheel.
UberKnee is offline
Old 18-05-2013, 03:49 PM   #518
nstg8a
3..2..1..
nstg8a's Avatar
If you read some of the owners threads on here you will see that the 335s are dynoing around the 320kw mark on average, some higher some lower, but thereof thereabouts.
I think the street fords press car dynoed at something like 340ish kw, and that's all at the wheels, so the Miami as to be making upwards of 370kw from the factory.
Power wise the lsa isn't the massive jump its being made out to be by some.
Tech wise it is, but not power.
The interesting part is the tunability of the lsa, some say with the right mods its as easy to power up as the Miami, but going by how much emphasis is placed on cooling it in the gts then it will be curious to what effect heats oak will have on it compared to the non intercooled gt.
nstg8a is offline
Old 18-05-2013, 03:53 PM   #519
peteypete
Sunny side up
peteypete's Avatar
two words, GLORIFIED DAEWOO.
-= BF MK2.5 XR6 =-
Genies>hi-flow cat>X-Force 2.5" Catback. Stage 2 crow cams. Powerbond 20% Underdrives. Bent tab. BC racing Coilovers. Whiteline Adjustable Swaybars. SS Inductions Growler + XR8 snorkel + Territory intake pipe. More to come. Thread coming soon.
[P]Plater
Past rides:
1998 NL Ghia Concorde (Now Dads car)
1954 Austin A40
peteypete is offline
Old 18-05-2013, 04:44 PM   #520
Auslandau
335 - STILL THE BOSS ...
Auslandau's Avatar
This is my stockie having a run on the dyno a few weeks ago at LSX Garage to give you an idea of RWKW's ...... calculate that back to flywheel and the GTS (power only) isn't as jaw dropping as they lead you to believe. Driving it also confirms this
'73 Landau - 10.82 @ 131mph
'11 FG GT335 - 12.43 @ 116mph
'95 XG ute - 3 minutes, 21.14 @ 64mph
101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong!
Clevo Mafia
[SIGPIC][/SIGPIC]
Auslandau is offline
8 users like this post:
Old 18-05-2013, 04:55 PM   #521
DJM83
Barra Turbo > V8
DJM83's Avatar
Plenty of substance there, not even close.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline
Old 18-05-2013, 04:58 PM   #522
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
I hope this is NOT Off topic as the question was asked above ^^^
I have witnessed over 10 Standard Coyote GT's on the dyno (3x seperate workshops) and the least amount i have witnessed was 337rwkws they are quite the weapon cheers...
Road Games is offline
Old 18-05-2013, 05:01 PM   #523
UberKnee
The One Who Knocks
UberKnee's Avatar
I just don't understand why Ford understated the power figure to such a degree unless the test motor was a complete lemon.
The only potential reason I can think of is just to keep the nanny state off their backs, HSV have actually got some flack from the media (I'm pretty sure that's a sign of the apocalypse) for releasing a 400kw monster onto the Aussie roads.
UberKnee is offline
Old 18-05-2013, 05:04 PM   #524
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Power v Power the GT will hold its own, but all the tech in the GTS between the MRC, Huge Brakes and Driver Aid Witchcraft should have the GTS far quicker on a track and consistantly.
FPV8U is online now
Old 18-05-2013, 05:07 PM   #525
f6 boss
again just another dyno number, has anyone put the engine on a engine dyno then put it on a dyno run.. Here is what Simon from Nizpro wrote in the Nizpro Newsletter July 2011. Simon has had experience with engines on engine dyno's before..
FG Coyote SC 315/335
Since the release of the SC 5.0 GS and GT Falcons, rumours have been going into overdrive about power numbers. There have been some reports of chassis dyno numbers as high as 350 rwkW and that Ford had massively underrated the power output of the car. To say I was a little sceptical of this was an under-statement. OEM’s seldom underrate Horsepower, lets face it, why would they? It just makes a rod for their own back in years to come when newer models are released and need further improvement in power on their new models. Overrating would be a more likely scenario.
Secondly the 0-400 meter speeds that many car mags have published are around the 112 to 114 Mph mark; these simply don’t support power levels over the indicated badge on the boot lid.
Good and bad cars really don’t exist by very large margins these days, so it was a little interesting when I was asked on the Nizpro forum what numbers did I think we would see at the wheels of Ford’s new Coyote powered vehicles. However for regular readers of any information I publish in regards to a engine dyno versus a chassis dyno’s numbers go will be familiar with my 22% difference number.
For example the turbo F310 FPV Euro 4 makes 254 rwkW on our chassis dyno and guess what; add 22% and you get 309.88 kW. The FG XR6T 220 at the treads which equals 268.4 at the engine.
So when first asked what I thought the GS and GT would make I simply grabbed the calculator. Now I have waited until we've had a number of both 335 GT’s and 315 GT’s in so I could make sure that we don’t see abnormal cars, but no, they come in nearly kW perfect at 258 (314.7) for the GS and 274 rwkW (334.3) for the GT. So it appears in all cases, V8 and Turbo’s, Ford seem to have the decals worked out.
There are a couple of lessons here. For workshops with dyno’s, if you have a standard production car come in making more power at the wheels than the badge on the boot says, ring your dyno manufacturer and get it recalibrated, and secondly; for anyone that loves to think that OEM’s release super high output specials, then gags and ties their PR department up so they can’t tell you, think again.
2005 BA F6 Typhoon= 12.6 @ 116mph (manual+street tires) 300rwkw.. Speedo Run----> http://www.youtube.com/watch?v=ezYN_nedAzQ
f6 boss is offline
Old 18-05-2013, 05:13 PM   #526
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
The Miami makes around 375 Kw for around eight seconds at a time thanks to transient overboost,
which is why many GT owners have been seeing 320-340 Kw at the rear wheels.
From my limited research, it appears that the LSA as fitted to the Cadillac CTS-V makes
around 495 kp or around 370 Kw at the rear wheels which is what you'd expect with an
intercooled supercharged engine of that size, that output is well within Miami's grasp.
jpd80 is offline
Old 18-05-2013, 05:19 PM   #527
UberKnee
The One Who Knocks
UberKnee's Avatar
So basically every dyno in the country is wrong. Not having a go at you here. The 0-400 speeds can simply be a result of the rest of the driveline. You can have all the power in the world, but end of the day these are family taxi's they're not going to have amazing transmissions, diffs, etc that can make use of all that power. They wont have super sticky tyres or hardcore track suspension that makes the most of what power they do or dont have.
UberKnee is offline
Old 18-05-2013, 05:25 PM   #528
Auslandau
Auslandau's Avatar
That make more sense and different to this below ... which is rubbish and if said by NIZPRO .... well just shows they have no idea! That many Dyno's cannot be wrong. OH .... except his? He is staking the times made by journo;s as a basis for his statement? I have seen how they are done by journos and they ain't real scientific let me tell you
I know dynos are not the be all and end and really should only be used for tuning purposes ..... but really?
Blah blah ........ .
Sorry ..... not shooting the messenger here f6 boss
Clevo Mafia
[SIGPIC][/SIGPIC]
Old 18-05-2013, 05:25 PM   #529
Pedro
Pedro's Avatar
Shish ... what a dog. The rear valance tuck under the numberplate looks like a nappie.
Pedro is offline
Old 18-05-2013, 05:28 PM   #530
flooded one
ha and the fronts a Hyundai elantra with a BMW grill!!!
flooded one is offline
Old 18-05-2013, 05:34 PM   #531
FPV GTHO
Simon has his maths wrong here. If you assume 22% drivetrain loss, then what you get is 78% of the power to the wheels. His maths suggests simply doing +22% rwkw to get your engine kW, which is wrong.
If you take his numbers as being 78% of engine power, you get the 100% figure by dividing rwkw by 0.78. His figures then become:
FG XR6T - 220rwkw/282 derived engine kw/270kw advertised
FG FPV F6 - 254rwkw/325 derived engine kw/310kw advertised
FG FPV GS - 258rwkw/330 derived engine kw/315kw advertised
FG FPV GT - 274rwkw/351 derived engine kw/335kw advertised
If Simons engine numbers are correct then his drivetrain loss calculation is wrong, which based on his numbers is closer to 18-19% loss.
FPV GTHO is offline
Old 18-05-2013, 05:34 PM   #532
Mighty Reds
Mighty Reds's Avatar
I feel the same way about the GTS as I do the new vette, both cars will be monsters and great value for money but some styling issues have me a little underwhelmed.
Mighty Reds is offline
Old 18-05-2013, 06:50 PM   #533
Nikked
Oo\===/oO
Nikked's Avatar
Just letting you know, I flagged that video as inappropriate...
That sort of porn is for over 18's only!
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline
Old 18-05-2013, 07:53 PM   #534
timetaker
I agree,370 kw @ rear wheels seems right,although doing some "research"I have also come across 345-355 kw ranges.
I thought I'd post a clip for interest,featuring a ZL1 Camaro(LSA) and GT500 on the dyno.
I have to say,the Mustang monsters the Camaro in power,torque and sound.Turn up your speakers!
http://youtu.be/yZBKBf8Zsjo
timetaker is offline
Old 18-05-2013, 09:20 PM   #535
Eaturbo
BUILT FORD TUFF
Eaturbo's Avatar
Man that mustang looks awesome. The engine must be a real work of art to be that much better than the Camaro's LSA. Still think the mustang styling is pure muscle car and the designer should be given an award for the simple yet clear design cues
2015 FGX XR6 Turbo
Eaturbo is offline
Old 18-05-2013, 09:28 PM   #536
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Damn, that Shelby sounds angry!
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline
Old 18-05-2013, 10:25 PM   #537
XRDeeze
UTRIED
XRDeeze's Avatar
BA XR6 03
Townsville Drag 1/10/11 PB: 15.34 @ 91.09 mph
XRDeeze is offline
Old 18-05-2013, 10:39 PM   #538
devoGT
This youtube video shows the stock GT only made 286rwkw, just doesn't add up when people on this forum are getting 330rwkw+
http://www.youtube.com/watch?v=KAYxTpCgHZo
devoGT is offline
Old 18-05-2013, 11:53 PM   #539
CSV_LS1
I used to have a nice car
CSV_LS1's Avatar
If a GT runs 114mph down the quarter it doesn't matter what the dyno print out says if the GTS runs a 120mph pass lol.
CSV_LS1 is offline
Old 18-05-2013, 11:54 PM   #540
flooded one
heat and humidity effects car performance and dyno results. it is also why the best time too drive a car is early in the morning when its cool or late evening into the night. heat and humidity can effect performance believe it or not.
here an example http://forums.corvetteforum.com/c5-g...o-results.html
Closed Thread
