Old 03-02-2010, 12:04 PM   #1
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Originally Posted by outback_ute
Surely the Gen III was new block and heads at the same time?
Third generation small block was a clean sheet design, yeah.
Also, I would take whatever Bob kLutz says with a pinch of crap.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 12:37 PM   #2
burnz
VFII SS UTE
burnz's Avatar
Are you sure? Not aware of any engines pre-1900 that didn't use pushrods.
otto engine 1876 i think, OHC
1912 for a 4V DOHC.
1949 oldsmobile OHV
not shure what year with the ford flathead tho.
GO SOUTHS
Old 03-02-2010, 03:05 PM   #3
Bud Bud
1912 for a 4V DOHC.
1949 oldsmobile OHV
Why do people think that overhead cams are recently new???
Bud Bud is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 06:28 PM   #4
Ryan
I guess, because alot of manufacturers didn't adopt it until later on.
Ryan is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 03:25 PM   #5
Wally
XP Coupe
1912 for a 4V DOHC.
1949 oldsmobile OHV
Wasn't the first production OHV by Buick in 1902? Before that, side valve engines were the go.
Wally is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 03:49 PM   #6
Jeddak
Over head cams? multi valve?
try 1929 with Deusenberg's 420cubic inch straight eight
twin-cam,4 valves per cylinder,and twin spark,
and if that's not enough ,this engine was available with supercharging as well
as King Solomon said "there is nothing new under the sun"( sorry Toyota ....not!)
O5 / 05 SX TS RWD Winter White, Driving Lights, Flaps, Racks, Turbo Grille, Ghia Bumper Trims and tailgate chrome , Colour Coded Mirrors,Tint,h/d towbar and chrome tow ball ,Sy chrome Beltline molds , leather and chrome shifter and Ghia Leather bound steering wheel
Stainless steel number plate frames and shifter quadrant, leather arm rest
All reconditioned SZ front suspension now in place
Chrome door pull inserts with chrome inner latch handles done
Jeddak is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 07:06 PM   #7
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
1912 for a 4V DOHC.
1949 oldsmobile OHV
Looking at the video of the Otto engines on http://en.wikipedia.org/wiki/Otto_engine the cams are on the shaft running beside the cylinder.
From what I can find with a quick search on OHV - a 1886 Daimler patent for an engine included an ohv exhaust valve. 1902 David Dunbar Buick developed and engine with both valves ohv. 1904 Lanchester cars with ohv sold commercially. Even in the US there were plenty of ohv used prior to the Olds V8 - but in manufacturers no longer in existence hence lack of info on Wikipedia. From a practical point of view the ohv had to be invented before you could have an ohc!
More relevant to the topic, when looking at that I came across the CamInCam system used on the Viper V10 which could be further developed to give TiVCT, and refers to GM having it already - http://www.sae.org/automag/technewsl...ertrain/04.htm
Old 04-02-2010, 12:26 AM   #8
burnz
VFII SS UTE
burnz's Avatar
interesting little tidbit
http://www.motorera.com/history/hist03.htm
The T-head engine gave way to the L-head (also called the flat-head or side-valve) engine in which valves were placed on one side of the engine. The L-head dominated the scene for years. Ford used it on V8s until 1953. But waiting in the wings was another design, introduced in 1898 by Wilkinson Motor Car Co. -- an engine that had the camshaft and valves in the cylinder heads. You know it as the overhead-cam (OHC) or overhead-valve (OHV).
GO SOUTHS
Old 07-02-2010, 12:51 PM   #9
castellan
The gen III also has a iron block version as well for trucks.
The design of a motor being OHV or OHC or DOHC has to do with it's function. just like springs being leaf springs they have there positives & negatives.
Do you think a ford v8 5.4L is better then a gen 4. why!
castellan is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2010, 01:14 PM   #10
chevypower
chevypower's Avatar
For low-end torque, yes. For high revving power, no.
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2010, 05:57 PM   #11
outback_ute
Ute Forum Moderator
Contributing Member
Did that use the same heads, was it a new block? Just curious re the statement they've never changed both at once.
Pushrods do have their advantages, but maximising efficiency is not one of them and that is what manufacturers have to work on.
Why use the Boss motor as an example, we all know that is hampered by the stroke dimension and restriction on revs that results. Nothing to do with DOHC/pushrod.
Old 03-02-2010, 09:18 AM   #12
burnz
VFII SS UTE
burnz's Avatar
you can VVT pushrod a 4Valve unit, nothing new cummins, cat, have been doing it for years.
GO SOUTHS
Old 03-02-2010, 09:59 AM   #13
irlewy86
Meep Meep
irlewy86's Avatar
Pity GM put all their eggs in the Volt basket and the next line of V8's will be developed on using money psyphoned out of other business units.
Take a look at what Lutz is saying, either the small blocks getting a new block or its getting new heads. But he cant develop a whole engine at once.
Thundering on....
irlewy86 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 10:04 AM   #14
4Vman
4Vman's Avatar
"Grandads axe" was a very apt description...
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 10:31 AM   #15
Bad Bird
Watts a panhard.
Bad Bird's Avatar
Sorry, wrong thread...
I don't have low self-esteem. I have low esteem for everyone else.
Bad Bird is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 11:48 AM   #16
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
I thought GM had already developed VVT pushrod engines as well as ones with 3 valve heads. I remember the LS7 was originally supposed to have a 3 valve head.
Also doesn't BMW and Moto Guzzi already succesfully run motorcycle engines with 4 valves per head?
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 12:09 PM   #17
boris
Also doesn't BMW and Moto Guzzi already succesfully run motorcycle engines with 4 valves per head?[/QUOTE]
As do most other motorcycle companies, for a long time!
boris is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 12:15 PM   #18
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
And Yamaha ran five valve head for nigh on 20 years. And then of course there was Honda with an eight valve per cylinder design...
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 11:53 AM   #19
sleekism
sleekism's Avatar
What I meant was that Moto Guzzi have an engine that runs 4 valves per head using pushrods so why can't car manufacturers?
The Moto Guzzi is a 1200cc pushrod V-twin with 4 valves per head making 80kw@7500rpm times that by four and you have a 4.8L V8 making 320kw! :
Old 04-02-2010, 02:13 PM   #20
Wally
XP Coupe
I guess to do that the complexity of head design and manufacture starts to approach that of a DOHC and thus the cost benefit diminishes. It would probably also require a double up on cam lobes and push rods, which may add even more mass and flex to the valvetrain. The cam tunnels would need to be beefed up and the block revised for increased rigidity and consequential weight.
Old 04-02-2010, 02:15 PM   #21
4117kev
[QUOTE=sleekism]What I meant was that Moto Guzzi have an engine that runs 4 valves per head using pushrods so why can't car manufacturers?
These heads are out there and available as straight bolt on's so as you say why don't the manufacturers use them.
i think a 6.2lt 4valve motor would sound pretty wicked and to throw in a new cam (aftermarket) would not cost you 4 grand as it does with the overhead cams.
Don't get me wrong on here I love my boss motor but why would I spend 25-30 grand on it for 500hp when i could get 700hp for the same money by doing a SBC using the same fuel.
4117kev is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 03:21 PM   #22
olds
The future doesn't involve 8 cyls
olds is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 04:12 PM   #23
xbgs351
12 or 16?
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 05:31 PM   #24
Chilliman
Chilliman's Avatar
At this late stage in the game I can't see GM going in a totally different direction to the current push-rod small block architecture - they don't have the cash anyway. Isn't the new V8 that this article is alluding to the GEN V 5.5Litre OHV V8 with direct injection? I think the variable timing statement maybe a bit of a furphy or something that won't be available until much later. GEN V is supposed to be production ready by 2012?
From www.motortrend.com
"Torque is the new horsepower"
Chilliman is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 05:43 PM   #25
olds
Originally Posted by xbgs351
12 or 16?
Electric
Old 03-02-2010, 05:53 PM   #26
ebxr8240
Performance moderator
ebxr8240's Avatar
Isn't the block they use in V8 series a twin cam engine as well ???
They will make a new V8 when Daewoo make one ???
Daily driver GTE FG..
Old 03-02-2010, 06:42 PM   #27
mickyyyy
Pushrod engines sound better and are so easy to work on and last forever. throw on a Direct injection system to make them more eco friendly and away u go again. Only OHC engines i like are ford inline 6, Barra & toyota 1JZ & 2JZ.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 06:55 PM   #28
CobraJet351
CobraJet351's Avatar
My future involves lots of them
CobraJet351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 10:48 PM   #29
Saraco
Saraco's Avatar
I'm Talking About High Rpm Reliability, Not About Prodution Cars.
Saraco is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2010, 10:54 PM   #30
4Vman
4Vman's Avatar
He was talking about production cars, not race engines....
