28-10-2013, 12:16 AM | #31 | ||
My EBII has just over 300 000k's and here's what has FAILED on me so far in the 2yrs since I've owned it:
Head gasket/exhaust valves/lifters leads/dizzy/tfi/coil/entire ignition system the brand new bosch dizzy in less than 6 months (top bush failed) alternator harmonic balancer exhaust and cat fuel injectors/fuel pump basically every sensor diff tailshaft (uni's) front/rear shocks every bush besides the massive ones (upper/lower arms etc) ball joints/tie rods absolutely everything in the front end needed replacing master cylinder heater core welsh plugs fuel pump 12v in the lpg switch accelerator cable x2 map sensor seized calipers and slides lpg converter (diaphragm ruptured) steering column (both bearings collapsed) blend door motor millions of interior bits/electricals heaps more crap I forget And it will need a new auto very soon, power steering rack and preferably another diff. Looking forward to the BEM leaving me randomly stranded one day too. Somehow the car has always made it home and I've never needed a tow truck lol.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! |
28-10-2013, 07:55 AM | #32 | |||
They are cheap to buy,easy enuf to fix,cheap for parts,$150 for a new alt delivered,cheap to run,average just under 10 L/100Ks across board,city,hiway,loaded,unloaded good enuf for me, and when the need arises stick the boot in and watch em go |
28-10-2013, 08:22 AM | #33 | ||
was danny888
I never really had an unreliable Falcon, but my lot of E series i had EF XR6/8 DC LTD were extremely reliable.
28-10-2013, 08:31 AM | #34 | ||
ask any older cabbie and the winner will be the good ol XF still see heaps around and they still pull good money !!
clevo mafia (sadly sold) 351c xe manual (now with short shifting 5sp goodness) xc gs coupe project...hmm more clevo for me new daily 2005 ba sr |
28-10-2013, 09:37 AM | #36 | ||
Boss 335
EL Fairmont. 3 Years. Bought for 4950 with 202,000km sold for 4950 with 242,00km. Two breakdowns: dead coil, ruptured fuel line at pump (not car's fault, rubbish woolworths E10 fuel).
28-10-2013, 09:58 AM | #37 | ||
SY TS AWD LPG TEZZA
My old EL was an extremely reliable car and cheap to run being dual fuel. I bought it from a government auction at 37500km as it was a police car. Never gave me any trouble right up until 295000kms when someone ran into the side of it and wrote it off.
In the end I stripped the motor down, changed all the gaskets, checked it for wear internally (it had none) and ported the head and put a cam in it and now it resides between the guards of my XG ute, (which is a glorified XF) and expect to get another 300000kms out of her. The AU appears to be the winner here, and for good reason. Ford reportedly got Jaguar engineers in to redesign the AU engine for better NVH, with bigger crankshaft bearings, longer con rods and shorter pistons etc. The coil pack issue was sorted, the overheat cylinder shut down feature was introduced. The head was redesigned, with stronger head bolts and MLS head gasket which sorted the head gasket failure issue that plagued the E series from the beginning. Technically it was brilliant, but the styling was not accepted by the general public who only understand litres to mean the unit of measurement you buy milk and juice in. They couldn't see the innovations so they went unnoticed. I remember the time when the EL was being run out and we were all waiting for the "new Falcon". It was a bit of an anticlimax when we saw the first AU come out. It instantly reminded me of the "Probe" or the "Taurus". But the AU was a great car. And an AU XR has a really nice unique appearance that is unmistakable.
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
5 users like this post: |
28-10-2013, 11:39 AM | #38 | ||
XF for sure. If there was one Aussie built car that should have been turned into a "London Cab" its the XF. End of the line for a well and truly sorted chassis, engine and auto and light years ahead of an E series Falcon reliability wise and dare I say it, better than the AU which still suffers from stuffed door locks and falling headlining.
28-10-2013, 11:46 AM | #39 | ||
Adapt or perish...
AU for sure.
Had one for 5 years, only servicable items I needed to replace was a radiator, steering rack and thermostat housing.
Carless
28-10-2013, 11:57 AM | #40 | ||
IU am going to say FG.
250,000km of hell on mine (now with 400+rwkw) and no major trouble. slighly leaking water pump (top up every 10,000km) and a thermo state - oh and the heater core blew but is bypassed atm) might get to 600,000 one day |
28-10-2013, 12:28 PM | #41 | ||
All of my falcons have been good , XR 289.....bloody grouse car, XC 351 ute also a good car, xd wagon 6cyl also had a good run, i look after them with the servicing, but the Au 2001 XR6 s2 with very very minor issues aside that you expect of any motor car, it has been the rock of the family fleet no doubt about it, i work the *** of it and it is still a good daily ..
28-10-2013, 01:13 PM | #42 | ||
Our family's first taxi was a HK... nothing but dramas.
Swapped it for an XY and been Ford ever since up to BF. The steel bumper cars were the most hardiest body wise, the newer cars cost $$$ for a 20km/h bump. All the X series needed welding at some point in their life like cross members, doors on XD-XF etc The only cars we haven't spent much on maintenance is the BA-BF, only fuel. And no, the gas Falcons are not more economical than a 4cyl Camry, not for cab use that is. We bought a Hybrid Camry and Prius to compare the Falcons, and it is sad for me to say that they are better overall except comfy ride. Their reliable, lighter, stop instantly, less accidents in the wet, efficient etc. Only a big hit will write them off easily... Anyway Most reliable Ford we have had is the BA-BF An old BA ex cab we sold to a friend had close to a million km. When he got there we were surprised to find that the odometer doesn't go back to zero, but goes back to 997000 odd k's. |
28-10-2013, 01:28 PM | #43 | ||||
Life begins at 40
Location: Melbourne. Socialist capital of Victoriastan.
Why am I reminded of Al Bundy and his Dodge?
Justice is what you get when you run out of money.
28-10-2013, 01:29 PM | #44 | ||
Out of the 3 cars I have owned a eb,au and ba the au wins hands down than my eb second, and last my current ba, I have had nothing but trouble with it, its been a peice of junk.
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
28-10-2013, 03:02 PM | #45 | ||
Racing improves the breed
AU for me, i'm on my third now and they have all been ultra reliable, a lot more so than my BA and BF.
1970 Mini Cooper S Historic Group Nc Touring car 1964 Mini Cooper S Historic Group Nb Touring car 2024 Subaru Outback Touring XT Victorian Hill Climb Championship |
28-10-2013, 03:39 PM | #46 | ||||
Life begins at 40
Probably a good time to update to an AU if your finances allow.
28-10-2013, 04:16 PM | #47 | ||
Pity the fool
The AU wagon we had before we bought the Tez cost me more money to keep on the road in 18 months of ownership than in 7 years of owning my BA. It was just one problem/failure after another. Couldn't wait to see the back of it.
My BA or probably the EBII Fairmont I owned years and years ago would have to be the best and most reliable for me. Neither gave me trouble in any meaningful way.
Fords I own or have owned: 1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD Proud to buy Australian and support Ford Australia through thick and thin |
28-10-2013, 05:57 PM | #48 | ||
BLUE OVAL INC.
Too hard to choose between XF and AU, nothing else comes close to these 2.
The XF in ULP Carbi form were near on indestructible when driven with respect. Door handles, hinge pins and 'C' pillar rust is all to report really. Easily a much better thought out package than an EA-D and far more reliable on average. EF/L's were well built with the exception of the dreaded head gasket issues that still plagued the OHC 4.0l. The AU, being 10 years newer than the youngest XF at time of release is easily the best accumulation of parts ever assembled on a Falcon production line. Not only is it a vast improvement on the XF, it ticks every box that was missed during the EF/L series and can hold its own against a car 10 years its junior. It should be considered first by a mile, but the build quality and effortless reliability of the XF at the time are too impressive to dismiss. In all honestly, had Ford released an XF ESP with a 5.8l Windsor V8 and T5 it could quite easily have become a halo/collector car. Its difficult to appreciate how good a nice XF looked in its day. Sure, there are plenty of nice examples around today, but its 2013, they are looked at differently to how they were received in 84. I will never forget the day I first laid eyes on a friends white 88 XF 'S'. Climbing in, the sports trim, red piping, the feel of the plastics, smooth and contoured. The digital dash which could cycle between gauges, the AC and stereo controls just belonged, as did the binnacle switches for numerous features. The 15" steelies with chrome dress rings and plastic centre caps, colour coded bars, tail light/fuel trims and grill, the decals and driving lights. I could go on and on and on.... Compared to the equivalent Commodores, it was leagues ahead |
28-10-2013, 06:20 PM | #49 | ||
Ive seen more reliable XF than the other models. basic bullet proof-boof head proof.
my driver lience was got on a manual 3 speed XD alloy head wagon that never stopped or needed service and nice to drive. my several EB/ED did let me down with spark,fuel and body module. not as quiet as the AU. I have had several AU myself and they have needed service parts like power steer pumps and suspension parts--but they havnt need a tow home. |
28-10-2013, 06:38 PM | #50 | ||
Yes its a hard decision deciding what car to upgrade to from two EF's that have really been pretty reliable overall..
Maybe worth keeping the better one thats got 250k's and upgrading the old XR wagon to an AU wagon with as low as possible k's.....theres still a few around with 150k's or so. |
28-10-2013, 07:29 PM | #51 | ||
The problem with the AU's though, is that they're a shocking rust trap. Every AU I pull up behind these days has rust bubbling through the boot lid.
The FG's seem to be pretty well sorted cars (no dramas with mine) except the god damned heat exchanger setup has me on edge.
2011 FG XR6 Sedan |
28-10-2013, 08:25 PM | #52 | |||
Yeah... I was half hoping all the lights to start flashing, horn tootin and a scrolling message on the odometer that says... "Congratulations, come pick up a free Falcon at your nearest Ford Dealer" One other thing we worked out in the taxi game... If the cars we bought were ex cop/fleet/rental, they lasted the longest if they were treated hard from word go. Ones we bought privately were nothing but drama cause of a cushy life... Al Bundy is a legend |
28-10-2013, 09:53 PM | #53 | ||
Would never happen though the Falcons have always flogged the dunnydores for reliability ( except maybe the early EA)
[SIGPIC][/SIGPIC]
2 users like this post: |
28-10-2013, 10:05 PM | #54 | ||
XR through to XB cant beat the old 250 log motor for reliability a close second would be the 289 windsor followed by the XC & early XD with the cast head 250 Xflow
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
28-10-2013, 10:32 PM | #55 | ||
Have to agree that the FG is shaping up pretty well against the super reliable AU.
28-10-2013, 11:13 PM | #56 | ||
SY TS AWD LPG TEZZA
Going back to X series vehicles the 302 Cleveland V8 was indestructible. I threw a cam into my old XB with 280000 kms on it and it pulled 6800rpm without exploding. Boy that thing revved. Just a 4 barrel, extractors and cam that's all.
28-10-2013, 11:40 PM | #57 | ||
"Flooded it mate?"
I have to agree as well, the AU gets my vote. They've just been such a good car.
Being an owner, and my parents owning my car for 10 years before me, it has performed flawlessly all of its life. No complaints at all. Never come close to letting us down, except when it spat the idler pulley last year, but that can happen on any car. It's the first car my parents have owned that hasn't been driven into the ground, and that's all up to the car staying together better than any other. With 206,000 now, ol' Skip is still great to drive, reliable as ever, and still loved. Even many of the taxis in Busselton, are still AUs. Still going, and just by watching them and listening as they drive past, they seem to be running in top shape! Even more so than the B series ones. |
29-10-2013, 05:30 AM | #59 | ||
The AU was the best Falcon of all time, only a pity the sheet metal and paint was sub par as always out of the Geelong plant, the b series and FG are/will be just as rusty. Otherwise it was spot on, even the looks came good eventually.
29-10-2013, 10:20 AM | #60 | |||
No trans or diff problems yet? |
