Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
15-06-2023, 05:27 PM | #1471 | ||
15-06-2023, 06:37 PM | #1472 | |||
I believe the bolts are unique with special taper and shank. Suggest try get good secondhand ones or try someone like Hardy Spicer or a driveshaft specialist alike. 6A758 is available: $15 6C758 is also available: $36 6758 is on back order but should be available soon: $180 Cheers, GT |
17-06-2023, 12:33 AM | #1473 | ||
Sprinting Everywhere!
Hi GTLEGEND I Was pretty disheartened when my local ford spares told me, they are no longer making genuine ford green coolant for falcons. Can you confirm this before I start trying to find an alternative? Thanks as always
17-06-2023, 12:40 AM | #1474 | |||
Concentrate: Volume/Part Number 1L/ R132C1L 5L/ R132C5L 20L/ R132C20L 205L/ R132C205L Pre Mixed: Volume/Part Number 5L/ R132P5L 20L/ R132p20L GT |
17-06-2023, 01:36 AM | #1475 | ||
Tickford
G'day - long shot... but are AU stone trays still available? I believe T3 TS50 is same as other models.
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD BA XT SZ Territory TS RWD TDCi |
17-06-2023, 05:50 AM | #1476 | |||
Thank you kindly for the info mate, really appreciate. The team over at SRP came up with the goods! Dropped a fresh set of bolts off Thursday! Bloody legends With respect to PCV, I just purchased another spare engine and looks like its got most the pieces i need. But i'll be going the catch can route anyway and it'll better serve the turbo kit that just landed. Plus i don't trust myself with those finicky little connections haha But brother, thanks again for the follow-up and info, testament to the community! |
17-06-2023, 08:01 AM | #1477 | |||
Thank God for interpreters like yourself that look outside the box. Much appreciated |
17-06-2023, 11:31 AM | #1478 | ||
17-06-2023, 11:31 AM | #1479 | |||
17-06-2023, 11:32 AM | #1480 | |||
I will need to confirm early next week but I am sure its around $85. GT |
18-06-2023, 02:21 PM | #1481 | ||
GT,
Are those 2 Watt original instrument cluster panel bulbs still available? Apparently some of the LED's I've replaced them with tend to flicker of late. Thanks. Bondy |
18-06-2023, 08:48 PM | #1482 | ||
23-06-2023, 12:50 PM | #1483 | ||
23-06-2023, 03:05 PM | #1484 | ||
Hiya, are there any flag nuts on the parts list? I found one sitting on the plastic tray under the engine, no idea where it came from!
23-06-2023, 03:16 PM | #1485 | ||
23-06-2023, 03:20 PM | #1486 | ||
I posted the pic in this thread
https://fordforums.com.au/showthread...=1#post6821973 |
23-06-2023, 03:30 PM | #1487 | |||
Former BTIKD
23-06-2023, 03:34 PM | #1488 | |||
regards Blue Last edited by aussiblue; 23-06-2023 at 03:51 PM. |
23-06-2023, 04:05 PM | #1490 | ||
In fairness they do seem to have gone out of vogue perhaps replaced with captive nuts. Used to come across them more often in vehicles and farm machinery I worked on in the 60's and 70's.
regards Blue |
23-06-2023, 04:42 PM | #1491 | ||
In post 1487. I've seen them on the lower control arm unit on the AU2. I know I had both lower control arms replaced and seen them. Instead of the nut type, mine was part of the bolt head.
23-06-2023, 04:44 PM | #1492 | |||
24-06-2023, 05:01 PM | #1493 | ||
I wonder if modern OHS practices is why the went out of vogue; as I, and doubtless many others know from experience, however careful you are, it's all to easy to catch your fingers and crush them between the flag and whatever part they were designed to stop against while holding them out of sight to start them on the bolt you are turning. Jeep in particular seemed to like using them.
regards Blue Last edited by aussiblue; 24-06-2023 at 05:09 PM. |
27-06-2023, 11:59 AM | #1494 | ||
Ack!!! It got me to near work but that’s about it…
GT, hombre, can you help? The hose has green bands on it - not sure if that means it’s original or one of the recall era. |
27-06-2023, 02:28 PM | #1495 | |||
Hose is $104, could most probably get one for you tomorrow pending stock. If not wont be till end of week. PM me if you want me to organise for you. |
27-06-2023, 02:49 PM | #1496 | ||
Does anyone know the part numbers for door actuators on an XH Falcon Ute 1999, I can't see any. I'm trying to hunt them down as mine broke (door locks keep cycling)
27-06-2023, 03:13 PM | #1497 | ||
Both sides take 96DA220A20BA, its just screwed on the bracket differently pending on which side.
27-06-2023, 03:36 PM | #1498 | ||
27-06-2023, 04:51 PM | #1499 | ||
Thanks - waiting on a local manufacturer to get back with their suggestions, else will hit you up. My workmate looked at the mess and casually said “Air brakes; nice”.
28-06-2023, 06:13 PM | #1500 | ||
[QUOTE=GTLEGEND;6822819]Both sides take 96DA220A20BA, its just screwed on the bracket differently pending on which side.[/QUOT
I have some if interested Gassa |
