Old 29-10-2013, 01:36 PM   #1
mif73
CNC fixer guy
mif73's Avatar
Question Seperate thread / sticky for au IRS info or issues?
Hi guys,
Considering the minority of au's with irs and the lack of knowledge or even it's existence, would it be a good idea to have a thread or sticky just for this case entailing info, problems and solutions for au irs?
What do you think?
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2013, 04:42 PM   #2
mif73
CNC fixer guy
mif73's Avatar
Default Re: Seperate thread / sticky for au IRS info or issues?
Ok so i take it its not a good idea then.
The other issue i have is the rear end skipping sideways a little over small bumps or joins in the road etc.
Old 04-11-2013, 05:03 PM   #3
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
I have the same,
My Steering joint told me to check my swaybar links as they looked worn!
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2013, 07:36 PM   #4
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Check your upper control arm outer spherical joints, that's what was cactus on mine when it did that.
MINE- AUII Forte
Old 04-11-2013, 09:25 PM   #5
mif73
CNC fixer guy
mif73's Avatar
Hi basher. All my outer sphericals are new and the inners seem to pass the crow bar test.
Will get a 4 wheel alignment soon and see if it helps could also be rear struts a tad worn.
Upper strut mounts have been modified to fix the usual problem there.
Cheers.
