Old 27-10-2006, 05:21 PM   #1
cupic
Nikon
cupic's Avatar
Default 50000kms is that really old
font
Speaking to my mechanic and i ask him what does he replace in falcon oil with(10W-40) he says 15W-40 as the engine wearing.Surely 50ks isnt nothing for a big six,I asked that because i was thinking of replacing with fully synetics oil.Any one with suggestion to either the comment or oil one would choose
cheers
cupic is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 05:24 PM   #2
coyote
Paint Repairs Spoilers
coyote's Avatar
Originally Posted by cupic
font
cheers
Depends on it's use.
I certainly would not be usine thicker oil unless it started to loose it out the back.
No In my opinion 50,000 is still a baby, barely run in.
Tyre smoke - nah must be smoke from the running in oil / Sorry officer, just put some tyre shine, did not think it would do that.
Unfit - How could I be, always running off at the mouth and jumping to conclusions
coyote is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 05:27 PM   #3
max
LWBforME
max's Avatar
font
cheers
Definitely DON'T use thicker oil!! 50,000 kms is nothing.
max is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 05:28 PM   #4
Mechan1k
Mechan1k's Avatar
50,000km is "just" run-in.
Use the factory spec-oil (whatever is mentioned in your manual).
Old 27-10-2006, 05:38 PM   #5
samftr
samftr's Avatar
your mechanic might be a d1ck h3@d mate. mine still uses 10w50 or whatever gets put in it. its got 338000ks on it. your engine is run in now but it surely isnt worn!
the difference between the two oils is the first one you said is a bit thinner when its cold then the 15w40 which is a bit thicker at cold startup which can cause wear in the first place anyway.
FG
Felcen!
samftr is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 06:10 PM   #6
sgt_doofey
sgt_doofey's Avatar
I'm still using the factory spec 15w/40w in my Falcon and it has done 201,000kms. Worn, nah.
Cheers,
Sam.
sgt_doofey is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 07:51 PM   #7
Full Spectrum
Only a matter of time.
Full Spectrum's Avatar
My brother still uses the recommended oils fully synthetic for his BA with 65,000km.
"SOUNDS THAT GO BUMP IN THE NIGHT"
Full Spectrum is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 08:07 PM   #8
aquahead2001
aquahead2001's Avatar
If you were talking about something from er, directly north of here or an GenIII, maybe at 100k you'd start using thicker oils. I know people who have well over 200k on their E series and AU's. And those cars never, I repeat, never need a top up.
Just clocked over 100k on my own AU and it does its 15k without even a slight drop in oil level.
aquahead2001 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 08:12 PM   #9
Full Spectrum
Mines topped 301,000km in the VP Still use the same oil no top ups. But i use GTX2 and it was suggested too go maybe a thicker oil. But If it doesn't chew oil or smoke why change it?.
Old 27-10-2006, 08:13 PM   #10
Josh_XC
font
cheers
cmon, is ur mechanic a first yr apprentice. Unless your engine has been on the rev limiter and in the redline for the whole 50ks than and only than may ur engine be "weary". Ur engine is just past the run in stage of its life. My option is to use the oil it specifys in ur user manual.
Originally Posted by MYLO_XR6
i dont like motors that come in the same size as milk and orange juice
Bionic BF XR8 - 6 speed manual, reversing sensors, premium sound, GT starter button. 218rwkw - Got to love the BOSS!!
Josh_XC is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 08:42 PM   #11
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
Definitely!
In fact I would think it wasn't even "just" run-in.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 10:45 PM   #12
cupic
Nikon
cupic's Avatar
Cmon Guys is only a forum to voice options
I didnt say I believe hes word as gospel
just to see beside manufactures oil whats the best to keep the car tip top do forum members use that's all
OK
