Old 19-02-2007, 02:48 PM   #1
Night Runner
- V8 ENTHUSIAST -
Night Runner's Avatar
Question Sequential Shift T56?
used:
I was just browsing the forum and saw somewhere that a T56 can be converted to a sequential shift? I tried searching for it but that was the only post about it. If that is true, how does that work? Sounds quite neat, has anyone done this conversion? Cost & what's involved?
I'm guessing it works like this: Clutch from standstill like a conventional manual then clutch-less shifting through the gears? Maybe disengage the clutch to downshift? Does it work with the common H pattern or is it push [up] for down and pull [down] for up or vice-versa - (in gate type shifter)?
Thanks, just curious, that is all.
Cheers,
Carl
Vehicles: 4 V8s & 1 V10
Night Runner is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 04:42 PM   #2
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
I'd also like to hear about this.
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 04:52 PM   #3
philstoj
philstoj's Avatar
Most likely it would be just a sequential shifter for the gearbox, where the shifting is in an up or down motion instead of H pattern.
You will find that it wont have anything to do with the clutch, you will still need to use your clutch like normal, but shifting will be an up and down inline pattern.
In saying all this, i havent heard of this for a tremec, there is a shifter for toploaders which is sequential and i believe XDC351 had one.
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 05:04 PM   #4
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
I’ve heard of it for 4-spd gearboxes (top loaders, Muncie rock crushers, etc). I heard that they were working on 5 spd versions (so I guess they went for 6 spd as well).
As Philstoj said you still need to use your clutch but all of the movements are in the vertical plane without having to cross gates for 2-3, 4-5 shifts.
http://www.renagate.com/info.htm
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 05:07 PM   #5
Night Runner
- V8 ENTHUSIAST -
Hmmmmm, that sounds quite awesome. Possibly something I myself would look into if the 5-speed is made.
Wonder what something like that would cost? Hopefully under a grand.
Thanks guys.
