Old 23-04-2005, 11:26 AM   #1
Filthy GT-P
Saving Water Filthy again
Filthy GT-P's Avatar
Default How can you prevent wedding Car ribbons from rubbing on the paintwork
Tomorrow I will be using the GT-P as a wedding car. I was wondering if anyone knew of a way to prevent the ribbon from creating a rub mark on the grill surround or the bonnet.
I was thinking of getting some white flannelette between the ribbon and the paintwork, but any other ideas would be appreciated.
Regards
Steven
Blood Orange BA FPV GT-P. Again, now I am complete
Filthy GT-P is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2005, 11:42 AM   #2
russellw
russellw's Avatar
The simplest way is a bit of 3M bonnet stone guard tape - I don't put the whole sheet on but have been cutting up the same sheet each time I've used it for this purpose (twice now). The sheet should last about 6 goes at this rate which is more than I'm likely to do.
Russ
Old 23-04-2005, 12:04 PM   #3
Filthy GT-P
Russ
Russ Thanks for the reply,
It's for Matt from G & D's wedding tomorrow.
To quote an annoying TV Add "Where do you get it?"
Thanks
Steven
Old 23-04-2005, 12:09 PM   #4
russellw
russellw's Avatar
Most Autorice stores should carry it - ring your local one and check.
Russ
Old 23-04-2005, 12:17 PM   #5
Filthy GT-P
It's about $51.00 from my local Autobarn
I thought I would also ring supercrap didn't know what I was talking about and suggested I ring Autobarn.
Steven
Old 23-04-2005, 12:22 PM   #6
Aussie Pete
Posts: n/a
Easier method. I ran a HSV for two years doingw eddings every weekend.
Get some Megiuars Yellow Wax PASTE. Apply liberally to bonnet and let dry thoroughly. Apply second coat. Fit ribbon and then wipe off excess either side of the ribbon.
Also, make the ribbon tight and so that when you shut the bonnet it pulls the ribbon that extra bit and preloads it.
No marks. Guaranteed. And cheap.
Old 23-04-2005, 02:26 PM   #7
Tickford Kid
Formerly known as TS 50
Tickford Kid's Avatar
Use silk ribbons only. They don't mark your paint.
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
Tickford Kid is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2005, 02:38 PM   #8
Yaw
Ford Fanatic
Yaw's Avatar
This would have been my idea too
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 08:46 PM   #9
Aussie Pete
Posts: n/a
The silk ribbons are a necessity. Agreed. But the damage also occurs from dirt getting between the ribbon and the paint. the wax keeps these from scratching the paint.
Old 26-04-2005, 10:40 AM   #10
ADZ351
ADZ351's Avatar
best way is to bend up a piece of metal with holes in it that bolts/screws to the factory holes under the hood and pokes out forward between the grille and hood, then folds 90degrees skyward witha hole in the end to thread the ribbon through. It wont get in the way of opening/closing the hood, and you can tighten the ribbon all you like and it doesnt touch the paint at all. It sits only centimeters above the hood. Somthing to consider making if you plan on doing a few weddings. I had one for my Falcon (XY) and although its design would be different to suit the BA the basic idea is the same
ADZ351 is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2005, 07:46 PM   #11
Filthy GT-P
I took Russelw's advice and it worked well. Some of the other advice is also very good, but time was very short.
The protector came off with a hair dryer and left no marks whatsoever.
Thanks everyone for your help the thread with a picture of the cars is here
Regards
Steven
