Old 27-02-2009, 06:35 PM   #1
malazn mafia
Boss 335
malazn mafia's Avatar
Default Would you mind an electric car, if it looked like this?
http://www.motortrend.com/auto_news/.../photo_03.html
Wondering when some bright spark Down Under uses the same concept to power a RWD falcon. Small generator hitched to the back in a trailer, or even sitting in the back of a falcon ute should work for long distance runs?
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2009, 06:40 PM   #2
bloggs24
Damn thats nice, but id think id be embarrased if people knew it was eletric powered. I'd never touch an eletric car, dont even like the idea of lpg powered.
If i had to pick that or the petrol powered equivalent, petrol it is.
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2009, 06:44 PM   #3
malazn mafia
Boss 335
What if a big v8, maybe a 351 under the hood was modified to just run as a generator. Still get that tough engine noise to fill in the silence, and probably not use much fuel as it would hardly need to rev to produce decent voltage. The electric motor/assembly could be hitched directly to the trans or rear axle.
Old 27-02-2009, 07:46 PM   #4
sgt_doofey
sgt_doofey's Avatar
The bags of torque that you get from electric from basically zero RPM is what will blow away the petrol version easily.
Petrol gets the sound and the bigger distances traveled.
Cheers,
Sam.
sgt_doofey is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2009, 07:56 PM   #5
snappy
snappy's Avatar
I would like that but come on It last 1 hour unless you plant the foot then it only capable of going a distance of 1 mile and then takes 3 hours to charge . It is utterly useless get further on a tredly. Look good in the garage but its all its good for and driving to the letterbox
snappy is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2009, 08:03 PM   #6
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
It would be good someone like for Clint Eastwood in Gran Torino.
The battery lasts long enough to back it down the drive way so he can look at while knocking back cans on the verandah.
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2009, 09:20 PM   #7
WRP11
NF Fairlane ghia
WRP11's Avatar
Naaaa, its only half a car if it doesn't chirp, i like 8 cylinders in a v formation thanks.
WRP11 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2009, 01:56 AM   #8
Poidevin
I doubt electric cars will become commonplace anytime soon simply due to the fact that the furthest one can go is around 50km, I used to do double that a day going to work and back.
But saying that, if electric cars were to become commonplace (meaning they can go furhter than 50km) then I would want an electric car that looked like that.
Poidevin is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2009, 02:14 AM   #9
SM1DY
LIKE A BOSS 351
SM1DY's Avatar
Where do you fit the S/C?
SM1DY is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2009, 09:59 AM   #10
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
Mate, you need to look around a bit, they are achieving way more than 50km range. In fact the Mini E has a range of 150 miles (240 km), a charge time of 2.5 hrs from dead flat and more power than a Mini Cooper S.
Having said that, I could not imagine a mustang with no V8 rumble.
This car is obviously not a car they will be build, more likely just a demonstration that anything can be made into an electric.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2009, 04:10 PM   #11
WayneHadfield
Don't move to WA then....
WayneHadfield is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2009, 04:25 PM   #12
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
I'd buy one if there was a way to re-charge the batteries while the car was operational. 1 hour of use is crap. Other than that, the performance figures are impressive.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2018 Hyundai Santa Fe Highlander
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is online now   Reply With Quote Multi-Quote with this Post
