Old 01-04-2009, 11:22 PM   #1
smasht
smasht's Avatar
Default Curiosity!
Just driving home from St Kilda just now and had a Ute (if i wasn't driving mine i would have sworn black and blue it was mine) fly past me like i was standing still and it got me thinking (other than if this dude will still have a license let alone be wrapped around a tree up infront).........
Does the kw / rwkw rating directly correlate to max speed (i.e more rwkw = faster top speed) or is it mainly about the speed in which the cars will get to ITS to speed?
Sorry if this has been covered :S
Mr Curious just b4 bed time
BA XR8 Silhouette Ute
Premium Sound
BPR CAI
Highflow Cats
Cat back + rear muffler removed
Custom tune (HP) by Chris BPR
DBA's + Bendix Ultimates
230.6 rwkw!
!NO HEADERS!
Mods to come (on a budget) -
Tripod and gagues
Lowered
Oil Pump Gears
Diff Ratio Change (3.7s?)
Underdrives
DF / Pacemaker headers?
Cams?
Sunroof
~Soon to be a weekender~
smasht is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2009, 11:27 PM   #2
gcg2503
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always adding valued comments,  never involved in any disputes. A credit to this forum.
Tautology - Guilty as charged
The act of repeating the word speed 4 times in the one sentence
gcg2503 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2009, 11:27 PM   #3
Windsor220
Now Fordless
Windsor220's Avatar
It relates to acceleration to the top speed. It might make a bit of a difference to top speed but thats more controlled by gear ratios, aerodynamics etc
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2009, 11:28 PM   #4
mikestp
EF Ghia
mikestp's Avatar
It depends on the gearing, If it reaches it top speed and is bouncing of the limiter then more power would only make it get there faster.
however if the top speed is caused by lack of torque then more power should give it a higher top speed
mikestp is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2009, 11:30 PM   #5
smasht
smasht's Avatar
:( my bad, I'm sorry I'm not the best at English - fitness and sport are my fields!
Premium Sound
BPR CAI
Highflow Cats
230.6 rwkw!
!NO HEADERS!
Tripod and gagues
Lowered
Oil Pump Gears
Underdrives
Cams?
Sunroof
Old 01-04-2009, 11:30 PM   #6
woodsy109
No there is a lot of factors involved in determining a cars top speed. The two largest factors are aerodynamic resistance and power output. As a general rule the faster you go, the faster the air around the car is moving and thus creating resistance against going faster. So the faster you go, the more power you need to overcome this resistance.
edit: yes gearing does come into this equation however the above statement is assuming optimum gearing setup.
woodsy109 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2009, 11:32 PM   #7
smasht
smasht's Avatar
Torxteerm, mikestp, woodsy109
cheers for the answer guys.
time for bed now for me
thanks again
Premium Sound
BPR CAI
Highflow Cats
230.6 rwkw!
!NO HEADERS!
Tripod and gagues
Lowered
Oil Pump Gears
Underdrives
Cams?
Sunroof
Old 02-04-2009, 12:54 AM   #8
madmelon
The power absorbed by pressure drag increases with the cube of increase in speed.
eg, increase speed by 10% (=1.1) then increase drag power by 33% (1.1 x 1.1 x 1.1)
Can get detailed formulas for you if you want.
Skin friction drag is added to this but will not be nearly as significant on a car.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 02:14 AM   #9
Zed7fiddy
Temporary Australian
Zed7fiddy's Avatar
Mate RWKW has nothing to do with it, my bike has aboout 90rwkw, and it will out perform your stock xr8 anyday, power to weight and acceleration is where its at ;)
Zed7fiddy is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 03:44 PM   #10
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
theoretically a dodge viper will do 400+km/h in top gear, if you had a stretch of road long enough and the conditions were optimum for it.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 04:17 PM   #11
madmelon
...yeh if those conditions were a 100km/h tailwind.
the formula for drag force is F(d) = 0.5 x fluid density x cross sectional area x drag coefficient x velocity x velocity
F(d) = 0.5pA(Cd)V^2
for drag power, multiply by velocity again...
P(d) = 0.5pA(Cd)V^3
velocity in m/s, density in kg/m^3, Area in m^2, force is in N and power is in W
so taking the XR8 with a Cd of approximately 0.3, frontal area of about 2.5m^2, air denisty of 1.224kg/m^2 and rear wheel power of 190,000W, you can solve for a theoretical top speed of: ~74.5m/s or ~268km/h
To actually reach that speed, the drag power curve must intersect the wheel power curve at exactly that point- it often doesn't and so the maximum speed is reduced. That also neglects skin friction drag which reduces top speed further.
The falcon actually has quite a good (low) drag coefficient compared to many high end cars like Astons, Lambos and Ferraris. They're usually up around 0.36, due either to their coolong requirements or appearance requirements.
The easiest thing to change to increase top speed (apart from maybe a speed limiter...) is power output of the vehicle. This will also improve acceleration.
Old 02-04-2009, 08:42 PM   #12
mrbaxr6t
mrbaxr6t's Avatar
F(d) = 0.5pA(Cd)V^2
P(d) = 0.5pA(Cd)V^3
WOW what a detailed response - if we distill this are you saying the aero package on a Falcon offers less drag than that of a Ferrari? and if so can you crunch the maths to prove this? Assuming this holds then in theory it would take less power in a falcon body to achieve say 300kmh than in a Ferrari?
Have I got this right it feels wrong to me. Ferrari have been building fast cars since, well forever they would have to know what you have written and change their cars to exploit this theory.
Phantom, T56, leather and sunroof BAmk1 :yeees:
Holden special vehicles - for special people
mrbaxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 11:58 PM   #13
madmelon
No this is actually correct- I've emailed Aston Martin about why theirs is so high (0.36-0.38) and they said it's about the car LOOKING NICE. The Fezzas and Lambos are a bit lower than that, more like 0.33-0.34. The Falcon (in base model with Cd of 0.29) offers a more aerodynamic SHAPE than most of those sports cars. The thing they offer is a lower frontal area- they may be wide but they're generally very low.
Additionally, their aerodynamics produce some semblance of downforce at speed. I'd rather do 300km'h in an Aston than a base model Falcon.
