Old 09-06-2010, 12:31 AM   #1
tomo
Default Electrical leakage when rains
During the recent rainy days my cougar stuttered pretty seriously (twice). It seemed like some electrical problem. Spark plugs and wires are almost new. When I turned on the rear screen heater all the lights dimmed a bit. I noticed the right headlight bulb got burnt, I replaced it and 3 days later it was gone again. When it’s dry everything is fine. Any ideas what it could be?
tomo is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 10:43 AM   #2
thearrow
Tomo.....straight to an auot electrician and get him to check it....something is wrong particulary if it is still doing it in the dry.
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2010, 06:46 PM   #3
Sprocket3
I would say you have a ground wire problem (bad earth) and your current isn't taking a direct route to ground, this culd be dirty plug sockets or even loose ground bolts.
Sprocket3 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2010, 11:20 PM   #4
tomo
Hmm... ground bolts you're saying. I'd like to check them out. Would you happen to know where they are located?
Old 18-06-2010, 11:43 AM   #5
Sprocket3
The main ones you could follow your earth wire from the battery to find the others all hook up in little plastic oblong shaped boxes usually with up to 8 black wires on a connecting strip, I'm sorry I don't have a diagram but I got complete diagram set for my probe from www.diacom.ru it is a russian site but they host mitchell wiring diagrams for all vehicles.
Old 18-06-2010, 08:00 PM   #6
Sprocket3
Sorry I didn't notice before you have a link to wiring diagrams in Cougar information and the edit option didn't display.
Old 18-06-2010, 11:23 PM   #7
tomo
Any idea which one would be the one possibly causing the engine stutter? used:
Old 19-06-2010, 07:02 AM   #8
Sprocket3
Any ground wire from Ignition to motor and main earth from battery to motor Or motor to body. I would go to main ground to body 1st because you said you had a headlight problem as well.
Old 20-06-2010, 12:47 PM   #9
tomo
Thanks a lot Sprocket, will have to check those.
