Old 20-06-2010, 01:03 PM   #1
russellw
russellw's Avatar
Default Weight
We've seena lot of discussion around the forum of late about weight reduction in our vehicles with the underlying view that weight reduction leads to improvements in performance and economy. Obviously.
I thought it was probably a good opportunity to have a look at the power and torque to weight ratios of various Falcon models throughout the history of Ford in Australia to see how they compared.
Note: Weights used for the purpose of this table are either averages for the model range or based on a specific variant when they match and are known.
First up weight to power, measured as kg/kW - in this instance the lower the figure the better and it's interesting to note how well the late models figure in this table although some of the hero models of yesteryear have made their way into the top half of the table, notably the XW GT in 5th and the 351 equipped XA/XB in 10th.
Next, a look at the torque to weight, measured as kg/nM and like the earlier set the lower the figure, the better. This time, the table is led by the XW GT and the earlier models figure prominently at the upper end of the table.
Russ
Old 20-06-2010, 01:05 PM   #2
Melz
Melz's Avatar
Great work once again Russ! Interesting to see the comparisons
Did you get bored while the server was being relocated??
Originally Posted by Jeremy Clarkson
“The Americans lecture the world on democracy and then won’t let me turn the traction control off!”
Melz is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2010, 01:37 PM   #3
madmelon
I think the AU XR6 VCT was alot heavier than the HP (~1530kg) due to IRS. Somewhere closer to the XR8- up around 1600kg.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2010, 02:07 PM   #4
CAMS290
trying to get a leg over
CAMS290's Avatar
Would be interesting to see the figures on the XY Phase 3. Unofficial claims said they were producing well over Fords claimed 226kw, but more like 285kw and who knows how much torque.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2010, 02:18 PM   #5
Sharka
EL SVO
Sharka's Avatar
Hard to believe the EL GT 1668kg dry
last time I was at the tip I got my EL Xr8 347 manual weighted 1655kg with the golf clubs an half tank a fuel prob round 50kilos on board car has spoilers heavy Fr17 simmons wheels etc as for torque to weight must be pretty good as it eats FPV GT 290's
Turbo terror......
Sharka is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2010, 03:11 PM   #6
mik
mik's Avatar
nice work SIR RUSS as always, imagine these older bangers with better diff ratio`s and 6 speed auto , even better the big banger late models with 70`s weight`s , .........ooooooeeeeeeeeyyyyy.
Old 20-06-2010, 03:23 PM   #7
Bossxr8
Peter Car
Bossxr8's Avatar
You need to remember that a car making 300hp back in the 70's would not really have 300hp by todays measurements.
Back then engines were dynoed minus accessories, and I think measured in SAE and not DIN?
Old 20-06-2010, 03:30 PM   #8
XR Martin
XR Martin's Avatar
I dont think the weights are right for the XD/XE V8s, that looks like the 6cyl figures?.
EBGT was 1650kg I thought too
Anyway, nice work.
Also add the ED XR8 Sprint which was 1580kg
192kw/405nm
kw:kg = 8.23
nm:kg = 3.9
2004 BA wagon RTV project.
Old 20-06-2010, 05:32 PM   #9
russellw
russellw's Avatar
The weight figures used are all from Ford brochures as printed at the time but as these were manufacturers claims and different State registration branches have used alternate ones they should be taken with a grain of salt.
Russ
Old 20-06-2010, 05:56 PM   #10
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Nice work Russ!
Incidentally, i weighed my AU1 VCT auto at the council weighbridge. 1680kg with driver and minimal fual on board. So, 1600kg kerb weight.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2010, 10:54 PM   #11
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Can't believe how light the XF's were. I remember when paying dads rego for his XF I noticed they were considered a medium sized car.. probably went by weight rather than size.
