Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > F6 Owners Club of Australia
Old 20-08-2010, 12:15 AM   #1
ridebmx14
Default problems eb falcon series ll ???
hey i bought a eb falcon gli series ll, it was running fine when i bought it. when i was driving back into town run low on tank coughing and spluttering, only just made it home. The next day put 30 litres in axidently put 10 litres of 2 stroke , idiling like **** give it a bit of gas and it would splutter and take a while to respond but sounded fine after that besides it use to blow my air box off backfiring through airbox alot drove around 1 full tank. I replaced fuel filter nothing. Then i checked fuel pump runnig fine plenty of fuel going to injectors. some1 suggested fuel pressure reg. replaced that no good. check compression in all 6 cylinders all good. Then started to run really rich, start her up and foul plugs out in bout 1 minute and stall. replaced leads and spark plugs. Found a leak in vacuum hose from map sensor fixed that Now it wont start it was firing a bit but now i try and it just turns over it doesnt fire. some 1 even suggested the cat convertor took unbolted whole exhaust sytem from header pipes nuthin. please any1 got any ideas im out of ideas and dont wont to spend a heap at the mechanic always fixed my cars myself. but im stumped. Thanks
ridebmx14 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2010, 12:18 AM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
Hey mate,
Welcome to AFF..!
You'll get a better reception posting that in the E series area..
here----- http://www.fordforums.com.au/forumdi...aysprune=&f=64
This area is for F6 owners..
Kris
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
