Old 10-03-2011, 05:12 PM   #1
snap
Default Are they new tyres that you are getting ??
I recieved this the other day , I am sure some will find this interesting
http://abcnews.go.com/Video/playerIndex?id=4826897
BF XR6 N/A
CPV CUSTOM TUNE , CERAMIC COATED HURRICANE EXTRACTORS , 2 1/2 INCH SYSTEM FROM RAPID FABRICATION ,
20%UNDERDRIVE , TURBO SNORKLE , F6 LOWER SNORKLE , K&N FILTER.
166.2RWKW.
CHEERS SNAP
snap is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 05:23 PM   #2
chrisfpv
Browsing here and there..
chrisfpv's Avatar
Edit: Ignore what I said previously, just watched the vid. Interesting.
chrisfpv is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 07:06 PM   #3
NAFairlane
NAFairlane's Avatar
actually, thats quite an eye-opener, i should keep an out for that at work, its probably more rare than they showed but i will definately keep it in mind
NAFairlane is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 07:16 PM   #4
Jason[98.EL]
Jason[98.EL]'s Avatar
would love to know how to date a tyre
no longer have a ford but a ford man at heart
R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN
[SIGPIC][/SIGPIC]
Jason[98.EL] is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 07:35 PM   #5
flappist
There might be a special section in RSVP........
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 07:47 PM   #6
MexicanBatman
MexicanBatman's Avatar
Didn't watch the video
But the date code can be found on your tyres sidewall
It's 4 digits first two month then second two for year so 1208 means December 2008 your tyre was born..
MexicanBatman is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 08:03 PM   #7
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Haven't seen the VID, but you've got the otherside of the coin to consider.
How many tyres are made by a manufacturer for the world market? Or do we reduce it to the Aussie market?
How many different sizes are available?
How many are produced per day?
What and how many of each size do you make in that day to keep up with demand?
These are the things that don't get considered when these sorts of things hit the interweb
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 10-03-2011, 08:07 PM   #8
chrisfpv
chrisfpv's Avatar
svo, I had a similar post to yours before I watched the vid.
It's directed at brand new tyres just sitting around in shops, not getting put on cars for years.
They grow weak and frail because of this and when they're finally put onto a vehicle, at high speeds they become weak and basically strip. It's not a boring video, draws you in and's worth a look imo.
Old 10-03-2011, 08:10 PM   #9
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
There is also more than 1 system or standard with tyre date stamping if memory serves. (or there was an older system and a newer system).
Having said that, can 'new' tyres de-laminate like that, I always thought that the carcass and tread where moulded at the same time? Or heat treated (vulcanised??) then chemically bonded to pretty much make them 1 hunk of rubber?
A lot of those tyre failures look to be the de-lamination of a retread???
I'm obviously no expert on this... just the first thing that came to mind.
Old 10-03-2011, 08:12 PM   #10
JBomb3000
So that makes it ok to put peoples lives at risk? Anyone would think your a tyre dealer.
JBomb3000 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 08:16 PM   #11
MexicanBatman
i look at it like this, if its fine for a large passenger jet to have bald tyres with exposed steel belting and be re treadded, its fine for cars too LOL
yes on your next interstate flight or overseas flight, remember as 100+ton is about to hit the deck at 150+mph your running on re treads that are bald and its wet... OMG...
anyway back on topic, my pirellis are 2 years old, apparently the oils leech out of the carcass and they become hard... next time you buy new tyres make sure they aren't parallel import and request new ones, SIMPLE really
Old 10-03-2011, 08:24 PM   #12
kramo
The first two digits are the week of the year and the last two digits are the year. 1208 would be manufactured in the twelfth week of the year 2008.
'03 BA Falcon XR8
'06 SY Territory Ghia RWD
kramo is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 08:30 PM   #13
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Thanks for posting this mate ..
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 08:32 PM   #14
MexicanBatman
there you go, i was going off memory i cbf googling it... week and year!
Old 10-03-2011, 08:35 PM   #15
chrisfpv
chrisfpv's Avatar
Did not know that, thanks for posting.
Curiously walks outside to car with torch in hand...
Old 10-03-2011, 08:57 PM   #16
Tanksenda
Tanksenda's Avatar
Absolutely correct!
I live with fear every day....sometimes she lets me go to the pub!
Tanksenda is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 10:30 PM   #17
sudszy
Did anyone check the date on the video, its three years old, current affair ran the stereo here in Aus about that long ago too.
Im a little more concerned with how long we keep them on our cars rather than how old they are when bought from the tyre shop, though Ill be definitely checking what Im getting next time I roll up for new tyres.
Cars that only do small mileages and are driven gently are going to end up with 10-15 year old tyres on them and most likely the tyres are being exposed to harsher conditions than the inside of a tyre shop.
What about your trailer you use once in a blue moon, never going to wear the tyres out on it, mandatory we should have no older than six year old tyres on them too?
There American rubber guy was right, there wasnt any real science/tests presented on just how more likely a tyre was to fail when it became older, the video just showed us a whole lot of truck retread failures lying on the roads, not the same thing.
Either way if we are going to turn over our tyres more often and have old stock chucked it will make the general cost of motoring more expensive(not complaining)
sudszy is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 10:43 PM   #18
XR6Runner
Sling Shot
Hahaha oh boy I really needed that laugh, thank you!
XR6Runner is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 11:33 PM   #19
svo supporter
Not a dealer. Just been round the industry for years.
Tyre ordering is done in 3 month cycles, from O/S. It is difficult to anticipate how many tyres and how many of each size to order in advance, because of how many different sizes are available. Just about every car has a different size for it. The BA, for example, has about 6 different OEM sizes. Multiply that by how ever many other cars are out there, with a few different OEM sizes and then the bigger picture should emerge.
It's because of this, sometimes tyres are sitting around for ages. But what do you do?
So there is more to it than what has been posted.
Old 11-03-2011, 09:02 AM   #20
aussie muscle
aussie muscle's Avatar
retreads definately delaminate like that, i'm not sure on un-retarded tires, but i guess they can.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2011, 11:54 AM   #21
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Is there something wrong with the video now? I tried to watch it and its all about some air freshener???
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2011, 02:11 PM   #22
snap
Ha , wait till the add finishes mate then video starts.
BF XR6 N/A
166.2RWKW.
CHEERS SNAP
Old 11-03-2011, 07:11 PM   #23
Jim Goose
There were calls once to make a mandatory retirement age for tyres.
I believe that they said anything over 8yrs old should be removed from vehicles or removed from tyre shops.
This was on a news show a few yrs ago where some of the story had orginated from the USA.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 06:24 AM   #24
HSVKILLA
moonlight rider
HSVKILLA's Avatar
If i had never watched that video i would have gone on with my life thinking that any tyre with a good amount of tread was ok(i still look for sidewall cracking etc)so thanks for posting that vid up,very helpful info.
HSVKILLA is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 11:20 AM   #25
Silver Ghia
Silver Ghia's Avatar
LOL thats funny.
Yes, the concern is for lower mileage cars and includes hobby and classic cars, that have their tyres fitted for years. Shelf time before fitment adds to that time.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 02:39 PM   #26
Elks
Elks's Avatar
Comedy Gold there Flappy, Comedy Gold
Oooh baby living in Miami....
Elks is offline   Reply With Quote Multi-Quote with this Post
