Old 29-09-2011, 05:35 PM   #1
Windsor342ci
The Experience...
Windsor342ci's Avatar
Default Gauges and cups..... Something doesnt seem right
Hi guys,
I imported 3 Autometer Cobalt gauges from the USA along with the mounting cups.
Now unless I’m missing something they don’t fit... Due to the copper looking thread, the cup doesn’t seem to fully fit the gauge. Using my hands only, it doesn’t seem like the thread can be removed either from the rear of the gauge.
Am I missing something or has the wrong cups been shipped?
Thanks in advance guys
Her Daily: BF XR6T ZF
His Daily: FGX XR8 ZF
Their Pride: T3 TE50 Manual
Windsor342ci is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 05:38 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: Gauges and cups..... Something doesnt seem right
I would've thought that when you put them in, you drill the holes for the bolt's to go through, then trim the bolts down once they are all fitted??...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 05:43 PM   #3
Windsor342ci
The Experience...
Many yrs ago I had a similar one, cobalt aswel and dont remember doing this....
The only thing I remember coming out the rear of the cups is the wiring....
Old 29-09-2011, 06:00 PM   #4
FreddyDUZ747
FreddyDUZ747's Avatar
Just trim them mate.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 06:08 PM   #5
aussie muscle
aussie muscle's Avatar
This makes sense.
i got some 'cheap china' triple cup and gauges, they wouldn't fit in the cup at all, as the diameter is too big (or more likely the cup is too small)
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 10:18 PM   #6
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Gauges and cups..... Something doesnt seem right
Is it a used gauge, because it should be sitting on 0psi?
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 10:21 PM   #7
nstg8a
3..2..1..
nstg8a's Avatar
this.
my cobolts are the same.
theyre just the guages for mounting in a flat panel, as opposed to a cup. no biggie at all.
should have come with a 3 sided bracket that fits over the the threaded rods, and holds it onto a panel.
edit: like this...
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2011, 11:01 PM   #8
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Yeah,had the same problem mountig my fuel pressure gauge to the cup to mount on my wiper cowl.
I just trimmed the threads short enough to fit.
The cups mounting ring holds the gauge in tight.
To get a clean look on the backs of the cups, i got the ones with a hole in the bottom, and used a right angle brass adapter thread.
Cheers,
Craig
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2011, 07:45 AM   #9
naddis01
naddis01's Avatar
A few years ago when I bought a set of Autometer gauges I had the same problem. I just cut the thread off.
If the gauges are loose in the holder just run a ring of sticky tape around the body of the gauge to make it a tighter fit.
naddis01 is online now   Reply With Quote Multi-Quote with this Post
