Old 16-02-2013, 01:41 PM   #1
ryeman
Question The rotating brush car wash pre-delivery!
Porsche, after road testing each Panamera, sends it through what I used to regard as a last resort car wash.
I guess it must be a confirmation of the safety of microfibres in never trapping and holding grit....the ? is are they all the same in Oz?
Wherenoshockjocksfly
Facts or the twitterverse, your choice!
M3SR+ .......MG ZS EV
ryeman is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2013, 01:51 PM   #2
FPVF6X201
Formerly FPVwannabe
FPVF6X201's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Slotted front rotors for the TTG write-up and pics.
Default Re: The rotating brush car wash pre-delivery!
My local carwash puts Bentley's, Aston's and the occasional Ferrari through the same type of carwash!
MY14 Deep Cherry Red Jeep Grand Cherokee 6.4lt SRT.
Borla ATAK axle back exhaust.
Hawk ceramic brake pads.
CLStech Ribbon DRL mod.
X Lume illuminated grille badge.
Injen CAI.
FPVF6X201 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2013, 01:53 PM   #3
jmac
jmac's Avatar
Wow.. I refuse to use the broom device at handwash places..
Sent from my GT-I9100 using Tapatalk 2
12' FPV Mkii F6 Vixen
-= ID1000 - Venom Cat - BPR SRI - PW Stage2 Cooler - Tune=- (348Kw)
Mazda 3 MPS Aurora Blue Gone :(
-=PG SRI - PG Inlet - ETS TMIC - GFB Hybrid BOV - Best Mufflers DP - Eibach Pro - AccessPort STG2 - Autotech HPFP - ITV22 - Michelin PSS=- (198Kw/466NM ATW)
jmac is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2013, 01:54 PM   #4
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
I wouldn't put my cars through one anymore, when you have pressure wash bays.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2013, 01:56 PM   #5
ryeman
Smile Re: The rotating brush car wash pre-delivery!
Microfibres are a fabulous invention which were owned by Kenjo I think but are now out of patent protection and dirt cheap!
Old 16-02-2013, 02:09 PM   #6
Silver Ghia
Silver Ghia's Avatar
Its not just the brushes that may or may not have trapped dirt, how clean is the filtered water that is used?
A few years ago I put a rental car through a car wash with the rotary brushes, the sediment on the windscreen after it was finished was such that it put me off car washes forever.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 16-02-2013, 02:13 PM   #7
revcore
revcore's Avatar
My advice is...
If you want your car washed properly it's best to wash it yourself at home as you know what products are being used and you know what your tap water is like.
So many times I see people wash the wheels first then wash the rest of the car....Big Mistake! The wheels are the last part of the car I was before giving the entire vehicle a final rinse over.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2013, 03:58 PM   #8
ShootsWithFilm
When I did a small stint working in a servo quite a while ago now, we used to have to do a walk through at the start of each shift. Some of the little ****** used to tie bolts and crap to the brushes in the middle of the night. This alone is one reason why I would never use one.
ShootsWithFilm is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2013, 05:29 PM   #9
2011G6E
2011G6E's Avatar
I would have no problem putting my car through the brush type car wash...the one at Porsche that they put the Panamera through of course...not the corner-service-station type ones. The one at Porsche would obviously be a high-dollar super clean and filtered water system a thousand times better than your usual car wash, you can be assured of that.
Old 16-02-2013, 06:20 PM   #10
Smoke Pursuit
Originally Posted by revcore View Post
My advice is...
I wash the wheels first... Then I wash the car. If you do it the other way the car dries while you washing the wheels and you end up with water marks. I use different equipment on the wheels.
Old 16-02-2013, 06:32 PM   #11
ryeman
I think 5th Gear did a comparison test of different systems, they decided the rotating brush system was the least worst....then again, they used the brush provided in the pressure washing system, so that was a bit dubious.
Old 16-02-2013, 06:40 PM   #12
revcore
revcore's Avatar
This is how I was my car...
Hose it down, Then using car wash liquid in warm water I wash a small section of the car then hose it off so it doesn't dry and leave streaks. I continue doing this until the car is completely washed. I then do inside the door jams etc and my final step is washing the wheels. Again I hose down a wheel, Wash it then hose it off and do all 4 wheels finishing with a complete rinse off then allow it to dry. This method works well for me and I never get streaks on the car left by drying car wash liquid.
I understand that other people may choose to was their vehicle a different way to me and thats great... If you find a method that works best for you then stick with that.
My Ride...
Old 16-02-2013, 08:19 PM   #13
baboon
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
My advice is...
.... unless they're chrome 20's on a dumped VN!....
baboon is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2013, 12:05 PM   #14
Djrystofer
Djrystofer's Avatar
Then I think they have bigger problems than which part of the car they wash first.
Djrystofer is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2013, 06:04 PM   #15
IceValk85
MY2010 SV6 SIDI -Black-
i wouldnt wash it....
sir, the only thing holding her together, are the bird droppings....
ice
IceValk85 is offline   Reply With Quote Multi-Quote with this Post
