Furious Performance
Old 20-05-2013, 12:02 PM   #1
123Cat
Default Hydrodynamic Bearings
Have a guess how much pressure is built up in say for example your crankshaft bearings ,
the pressure that mostly seperates moving parts
so they dont rub together and destroy themselves
Fords are cool
123Cat is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2013, 12:40 PM   #2
mik
mik's Avatar
Default Re: Hydrodynamic Bearings
No idea mate, give the good oil !
Old 20-05-2013, 01:00 PM   #3
madmelon
It'd depend on the load, oil viscosity and relative speed but somewhere in the MPa (ksi) range. There's only a minute film of oil at the point of nearest contact though.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2013, 02:48 PM   #4
123Cat
Your bearing clearance and surface finish play a part too
It can be over 6000 PSI at the thin part of the oil wedge ,
oil pumps and oil pressure have nothing to do with it , they just supply oil to the area needed, the rotation of the part does the rest
When you have 6 tonnes of load coming from the rod you need that pressure
Fords are cool
