Adams Polishes
Old 28-05-2013, 08:07 PM   #1
stazza
stazza's Avatar
Default Rear Wheels Not Lining Up
I noticed after fitting my new wheels, the rear right hand wheel seems to be nicely in line with the guard, whereas the rear left hand wheel sits in about another 7 or 8 mm. Both wheels are measured to the same spec offset-wise.
I noticed when putting on the centre caps, one side wouldn't go on, but the other went on fine. It's as if the threaded stub coming out the center of the hub is slightly longer. Anyone else seen this?
My FG XR8 ute has the same problem, only it was about 13mm, so much worse.
I appreciate any help.
I'm thinking on just rectifying it with a 5mm spacer, but that's not the point.
Cheers.
2011 SILHOUETTE FPV GS 315 #0275
20x10", 20x8.5" Lenso D1R's
Pedders XA Coilovers
Brembo 4/1
Pacemaker 1" 7/8 Headers
Twin 3" Stainless Manta Catback
XFT Built Motor
XFT Custom Surge Tank
XFT Stage 3 ZF
Final Drive Chromoly Tailshaft
KPM Twin Air Filter
KPM Stage 2 Intercooler
KPM Twin Throttle Body
2.6L Kenne Bell on E85
BlueStreak Circle D Converter
900+ rwhp thanks to Xtreme Ford Tuning
stazza is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2013, 08:38 PM   #2
MDS69
MDS69's Avatar
Default Re: Rear Wheels Not Lining Up
Car hasn't been lowered more than factory has it. I am not familiar with the underside of a Falcon but if you lower a Commodore you need to fit an adjustable panhard rod to bring the body back to centre with the diff.
MDS69 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2013, 08:40 PM   #3
stazza
stazza's Avatar
Yeah mate it's on dobinson ultra lows
Brembo 4/1
XFT Built Motor
XFT Stage 3 ZF
KPM Twin Air Filter
Old 29-05-2013, 07:47 PM   #4
OzJavelin
OzJavelin's Avatar
Is it the same with the original wheels; to eliminate one variable in the equation?
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2013, 08:51 PM   #5
Ford17
Ford17's Avatar
It was explained to me at the tyre shop this was a fairly common problem, caused by the FG Diffs not being 100% centered in the vehicle.
Ford17 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2013, 09:24 PM   #6
Mont5.0
Mont5.0's Avatar
Is the tub on 100% straight?
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2013, 10:39 PM   #7
kempy311
BEN
kempy311's Avatar
The diff cradle isn't centered.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 07:17 AM   #8
Trump
bitch lasagne
Trump's Avatar
This. Someone forgot to use the aligning pins when the cradle was (re)fitted.
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 08:31 AM   #9
GTP534
GTP534's Avatar
Is this difficult to fix?
Currently no V8 in the garage!
GTP534 is offline   Reply With Quote Multi-Quote with this Post
