Old 24-03-2014, 08:47 PM   #31
aw0303
Default Re: Holden SSV Redline drive impressions.
Cam and springs on a redline should be around north of 300kw? I have a 09 VE SSV wagon with full exhaust, cam and valve spring upgrade makes around 320rwkw with a good tune (manual).
Cheers.
aw0303 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2014, 07:10 AM   #32
Rodge
Rodge's Avatar
^^ I spoke with Eastern Automotive here in Auckland and yeah, they reckon with the Walkingshaw 310 package plus a cam and I guess they fitted the different valve springs and maybe one or two other bits and pieces there's is making ~ 400 fwkw's, so I guess that's about 320 rwkw's allowing for 20% driveline losses and that supports what you've just said so it is possible to extract good power out of these 6.0L engines, albeit with significant modifications.
Rodge is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2014, 09:30 PM   #33
aw0303
Yeah mate, I'm happy with mine still has good fuel economy for such a big heavy car, around 14-15l/100km around town 8-9l/100km freeway run. I guess it depends if you like the sound and manners of an old school pushrod cammed V8 or the forced induction rush of the newer tech ford engines. They are both good things I reckon but I must admit, I like a lumpy idle! (Starting to show my age!)
Cheers.
Old 26-03-2014, 07:42 AM   #34
Rodge
Rodge's Avatar
Cheers.
On the same page with you there mate .
Old 26-03-2014, 05:59 PM   #35
2242100
HI Rodge
You might find it worthwhile to ask EASTERN AUTOMOTIVE about the revs needed to get 400 FWKW.
To calculate torque in Nm the formula is as follows:-
T = kW x 9549/RPM (For power in kW its........kW = Nm x RPM/9549).
I believe the standard 260 kW Auto engine has it's claimed max power at 5700 RPM so we are looking at around 435.6 Nm at these Revs.
If the suggested mods can give 400 kW at these revs then we are looking at around 670 Nm which is around a 53.8% increase and I'd say that's a great engine, more likely though, I suspect they may say something like 6500 or 7000 RPM. If it was 6500 RPM then that's around 35% more torque and if it's say 7000 RPM then it's around a 25% rise which to me would seem more likely.
Now if the engine has to go to 7000 RPM to make the power, you might ask yourself what sort of overall driveability/economy/noise and long term reliability issues would their be? Personally I think the current V8 Commodore is a very good car, but equally I think the above highlights the limitations of N/A engines. Remember standard air is only 14.7 Psi.
One thing I can say though, is that my standard, untuned FG Turbo has bags of torque as demonstrated by the following 0-100 kph run that it managed with the Auto locked in second gear and that's a gear that's high enough to run beyond 110 kph. I was particularly pleased with the 0-60 kph time (revs are about 3275 RPM at 60).
0-20..............0.88sec
0-40..............1.68sec
0-60..............2.64sec
0-80..............3.74sec
0-100kph.......4.90seconds.
2242100 is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2014, 07:01 PM   #36
strik9
aka fpv747
rodge from everything i,ve read from you. go to the top mate,gts if you get anything less you won't be happy. just knowing somthing better is out there will drive you crazy and you won't be happy
stop torturing yourself fpv is done mate( mind you i,m many beers in and may not even be relevant . but pretty sure it is)
2012 nissan gtr tuned by willall racing 370awkw
2014 ford raptor supercharged 490hp
1969 chevy pickup
strik9 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2014, 07:40 AM   #37
Rodge
Rodge's Avatar
There's an old saying that a few beers the truth comes out , or words similar to that, I can't remember.
I'm presently trying my best to get HSV N.Z. too see my point of view about their Kiwi pricing. Might as well bash my head into a brick wall for all the good its doing.
