Old 21-06-2015, 09:23 PM   #1
roth
Default Incorrect line markings
I quite often encounter unbroken/double white line markings that are illogical and are probably marked in error. Specifically what I'm referring to is when either breasting a crest or coming out of a corner an unbroken line may continue for maybe a hundred metres or more beyond the point where there is a clear view of the road ahead. Many times I have been about to overtake but have to needlessly delay the manoeuvre until beyond the unbroken line. Sometimes there is a legitimate reason for an apparent "mistake" in line marking because of a side road etc so unless you know the road it would be foolhardy to ignore the markings. Furthermore it is always illegal to cross an unbroken line so I guess we just have to live with the frustration and observe the rules.
Comments anyone?
roth is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2015, 10:19 PM   #2
Itsme
Itsme's Avatar
Default Re: Incorrect line markings
Comments anyone?
Have you realised the double lines are there for the traffic coming the opposite direction towards the bend, this would make sense.
No mistakes imo.
Old 21-06-2015, 10:37 PM   #3
cs123
cs123's Avatar
No mistakes imo.
That would be a single dashed line with a unbroken line on the side that isn't allowed to cross.
Double means neither can cross the centre.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 21-06-2015, 10:40 PM   #4
Sometimes it may be because there is a dip in the road ahead that may make an oncoming car temporarily invisible; it may not be apparent to you unless and oncoming car suddenly appears to vanish for a few seconds. There is almost always a good reason for the full line even if it may not be readily apparent; and learning the hard way the reason is not a good idea.
Old 22-06-2015, 04:02 PM   #5
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
I don't cross double white lines all the time. But when I do, I make sure I'm turning into a driveway.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2015, 04:20 PM   #6
If it's safe I'll do it to pass a bicycle rider.
LG17 is online now   Reply With Quote Multi-Quote with this Post
