Old 01-09-2016, 10:07 AM   #1
mrfalcoon
Default audio sub amp help
Stereo connection help
has 2 front and rear RCA which be connected to 4x amp,front and rear speakers.
Than I got
Sub RCA
Center out RCA
These are just one RCA out.
Can I connect sub out and center out to one amp and run two 10 inch subs off ?
how best way to wiring it up ?
thanks
mrfalcoon is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2016, 01:52 PM   #2
Falcon SXR8
Falcon SXR8's Avatar
Default Re: audio sub amp help
Just run the one sub rca to amp then wire both subs to the amp. Google wiring 2 subs together to get the right ohm rating for your amp. I think that's what your asking anyway
Had
EB XR8
AU XR8 220 (awsome car )
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
Falcon SXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2016, 02:33 PM   #3
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Chuck that stuff in the bin. Fit supercharger. Done.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2016, 03:10 PM   #4
mrfalcoon
my subs were working off a 4 way amp bridged.
now new head unit.
I have an Amp Out (black)...1 rca cable out... Do I get a (Y) connector so split it to 2 rca cables red and white and run to amp and bridge the subs ?
clearly best way buy new mono amp but $ but use what I got?
Old 01-09-2016, 05:53 PM   #5
Falcon SXR8
now new head unit.
Best to read the amp manual it will show the correct way to do it, but yes sometimes you need an rca splitter to connect to the amp
Had
EB XR8
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
