25-11-2020, 10:44 AM | #1 | ||
I have an old Rotary/ tiller which now has a wrecked 6 HP Tecumseh engine.I would like to keep it going,but problem is can’t get Tecumseh crank anymore.Honda is too pricey as is B&S.A Chinese 6.5 engine is priced under $200 which is the price point to make it viable to get it going again.Question is,have many of you on this forum had any experience with these cheaper engines.
25-11-2020, 10:55 AM | #2 | ||
Tassy, PM sent
25-11-2020, 11:09 AM | #3 | ||
horizontal or vertical shaft?
you can get a 6.5 horizontal for $160 https://www.ebay.com.au/itm/6-5HP-OH...frcectupt=true rebuild kit for your engine below: https://www.ebay.com.au/itm/6HP-Engi...frcectupt=true
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
25-11-2020, 11:28 AM | #4 | ||
Thanks Coo. Besta007 Yes I can buy a kit,but,the problem I have is that the crank big end journal is worn about 20 thou,fair bit more than the 2 or so it should have.Yeah Horizontal,I have seen them for as low as just under $140,don’t if they are all comparable in quality etc,because they all look exactly the same externally
25-11-2020, 11:34 AM | #5 | ||
I've had a bit to do with a few of those "Chonda" Motors. & they're fine. Parts are interchangable with the real Honda's. Only Problem I've had is don't run E10 in 'em as the rubber fuel line & seals in the Carby get eaten by The ethanol.. Run Premium in them & you'll be fine.
25-11-2020, 04:38 PM | #7 | ||
RS The Faster Fords
Much the same experience, the engines themselves aren't bad but the fueling side isn't great.
Escort RS2000 Restored factory a/c and alloys. TD Cortina Unrestored 35 000km 6cyl manual. Mk1 GT Cortina Project. FG XR50 Daily. |
25-11-2020, 05:38 PM | #8 | ||
🚫⏰4️⃣🐃💩
Have a look at Torini engines. Very good quality engines.
6.5HP: https://www.revolutionindustrial.com...e-petrol-6.5hp 7.0HP with electric start: https://www.revolutionindustrial.com...electric-start 13HP: https://www.revolutionindustrial.com...ne-petrol-13hp 15HP: https://www.revolutionindustrial.com...ne-petrol-15hp Torini also build a race version used for Go Kart racing. I can personally vouch for the race motors. Super reliable and can take a beating. Most parts are interchangeable with the industrial versions in case you want to "upgrade" components. http://www.torini.com.au/documents/o...axx_manual.pdf The Chinese "Chonda" is nothing but trouble. I would advise to stay away. |
25-11-2020, 06:17 PM | #10 | ||
25-11-2020, 07:09 PM | #11 | |||
I had a Morison mower with a Tecumseh engine for years everything fell apart but the engine was still good when it went out last hard rubbish. for a Rotary/ tiller that's used one or twice a year they will do the job
25-11-2020, 08:48 PM | #12 | ||
The machine is old, then don't over-spend on it, I'm sure you will get years from a new no-name Chinese engine.
I wouldn't read to much into the made in China thing. You can imagine my disappointment, but not surprise to learn my brand new mower with a Honda GXV160 engine was made in China, most likely in the same factory that also produces "Chonda's". And Briggs & Stratton engines have been made in China for year, some are labeled "Made in the USA from Global parts", ie assembled by Chinese components.
The Fleet - 2016 PX MK II Ranger Cool White 2008 FG XR6 Sensation Blue 2014 FG X XR8 Emperor Red 2024 Mustang GT Race Red The Departed - 2002 T3 TS50 Blueprint 2017 Mustang GT Race Red |
2 users like this post: |
26-11-2020, 01:28 AM | #13 | ||
A lot of guys on a mower forum I'm on seem to think the Chondas are pretty good value for money. Popular for old Scott Bonnars etc with a dead Briggs.
FG XR8 289rwkw ED Fairmont Ghia 5.0 broken |
26-11-2020, 06:29 AM | #14 | ||
You can get a second-hand 2' pump for a couple of hundred, throw the pump away.
bye |
26-11-2020, 06:29 AM | #15 | ||
bye |
26-11-2020, 01:37 PM | #16 | ||
I've had a few Chonda motors over the years. One in particular is on a compactor. Left outside, neglected, stale fuel and still starts first pull every time, even after 6 months.
If you look up John and Johnno, they have a good range of very reasonably priced engines. They are in Ballarat but will freight. |
27-11-2020, 10:59 AM | #17 | ||
Hi,
I find a good source of real Honda engines (and some Chonda's) at your nearest recycling centre. In Perth I can pick up various machine with a small motor for typically $50 to $100, and in average the engines only need a small repair to get going again, The last one I picked up for under $100 was a 24hp, sitting on a carpet cleaner. It had nothing wrong with it, hooked up power to the fuel pump and started it. Cheers,
'11 FG Turbo '08 Territory SY RWD And some non-fords: E90 M3 build, '07 Rocket III, |
