So what are the chances of an FG upper intake / snorkel / tube assembly how ever you say it..
The inlet from ontop of rad support to airbox. Will it fit onto the AU airbox? |
mechanical novice hopeful
![]() Join Date: Feb 2018
I haven't done any of this myself, so I don't know.
But I am sure I have read about it previously here on this forum; "What may work better for these is getting a B-series airbox ... they fit from my understanding ... and the F6 lower snorkel .... which will pull clean/cold air from around your headlights in an AU XR. You'd get more benefit from this than the over-rad snorkel." Maybe try searching amongst these; https://fordforums.com.au/showthread.php?t=97039 https://www.google.com.au/search?q=fordforums+What+may+work+better+for+these +is+getting+a+B-series+airbox+site:fordforums.com.au&sxsrf=ALeKk00 oY6kBjDtPo8JMZeX4bUZeiCE-hg:1620512505438&sa=X&ved=2ahUKEwiskvbBj7vwAhXOzjg GHfk_Bm4QrQIoBHoECAYQBQ&biw=1920&bih=938 |
#3 | |||
Regular...with metamusal
![]() Join Date: Oct 2009
welll i know the AU will fit the BA/BF as i'm using one ..... so . . i think the airbox side will fit on, not sure of the rad support side tho. i do know where there's some AU's/FG's that i could try it on ....... earliest would be wednesday arvo tho before i could test fit. |
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
I did this...
It was cheap and simple. You could use a larger diameter connector if you wanted to.
