Old 09-05-2006, 12:08 PM   #1
chalkys1966
Fly Boy
chalkys1966's Avatar
Default engine not running hot
1987 LTD - 6 cylinder EFI. problem - engine does not get hot. radiator seems 'cold'. this is an issue as heater pumps out no heat. have replaced hoses and thermostat. what can cause an engine to run cool like this?
chalkys1966 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 12:24 PM   #2
charles_wif_xf
Purveyor of filth
You changed the thermostat and still cold? What thermostat did you put in? It has to start opening at 80C and be fully open by about 85C.
How long has the engine been running before you turn the heater on? Grab both radiator hoses after a longish drive. They should be quite warm to the touch, even hot. If they are still cold, your thermostat is either opening at too low a temperature or stuck open (happens with new ones once ina while).
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 12:24 PM   #3
falcon91
falcon91's Avatar
Does your engine feel very hot to the touch??? If it does there is a blockage in the radiator system. Get it fixed quick!
falcon91 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 12:33 PM   #4
chalkys1966
Fly Boy
thanks for the replies. its not my car its a friends. i think you have put us on the right track. the engine block does not get very hot. its like its a cold engine. quite weird. :
Old 09-05-2006, 12:34 PM   #5
charles_wif_xf
Purveyor of filth
No worries glad we can help.
Old 09-05-2006, 12:41 PM   #6
BlackLS
Posts: n/a
Make sure the cooling system is well purged.
Old 09-05-2006, 12:44 PM   #7
gozza
gozza's Avatar
my engine doesn't usually get past the N of Normal
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 02:37 PM   #8
Mike Gayner
Mike Gayner's Avatar
My money is on a stuck thermostat. Thermostats are temperamental little bastards and it's not unheard of for a brand new one to stick.
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 02:50 PM   #9
all4ford
XW 351
all4ford's Avatar
A good thing to do is to get the thermostat out and boil it in water on the stove to ensure that it opens.
all4ford is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 03:04 PM   #10
gozza
gozza's Avatar
i checked mine and it wasn't stuck open...maybe its just a dodge one
Old 09-05-2006, 03:50 PM   #11
vino3o2
owning V8=having no $$$
vino3o2's Avatar
That would be my guess...ive had a brand new one stick on me before
Weekends - 1965 XP 302 sedan... :
Weekdays - 1980 323 Mazdabator complete with cheese cutters & FF sticker :dr_Evil:
The Reality: 13.1 @ 106mph.... The Goal: somehow get into the 12s!!! :sm_headba
www.qldsuperkart.org
vino3o2 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 10:15 PM   #12
XD 351 Ute
Excessive Fuel Ingestion
XD 351 Ute's Avatar
Ignore the following if you've already done this or know about it:
Make sure you bleed the air out of the head/thermostat area with the bleeder screw.
They get an airlock that can be terminal.
Make sure the heater is turned on when filling/bleeding, etc.
Ed
XD 351 Ute is offline   Reply With Quote Multi-Quote with this Post
