Old 01-10-2006, 12:14 PM   #1
fordperformance
Default Help with au2 forte please!!
Last night i was driving and my left headlight went out and so did the instrument panel lights for about 5 seconds then came back on and the whole time engine kept running then the battery light came on and stayed on. I got back in it this morning and it started fine but the battery light came back on and the windows where moving really slow and everytime i went around a corner or hit a bump the radio cut out then came back on, so when i got home i checked the battery connections and they where fine... i checked the battery water level and it was fine too.. so i tried to start the car again and it wouldnt start all i got was about 5 clicking sounds from the engine bay ( kinda sounded like the starter motor engaging but not turning the motor ).. what i wrong ?? any help would be great thanks... oh and i took the globe out that burnt out but havent replaced it yet... does that have anything to do with it ?.
fordperformance is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2006, 12:24 PM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
I know your not having much luck mate but your alternator has died
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2006, 12:33 PM   #3
fordperformance
so thats why it's makeing the clicking noise ?
Old 01-10-2006, 12:38 PM   #4
Racecraft
they call me Tibbo
Racecraft's Avatar
the clicking noise is due to your battery not being charged enough to crank the engine over... Because your alternator is not charging, the battery continues to loose voltage and the elctrics start to fade, just like your described...
Old 01-10-2006, 12:41 PM   #5
fordperformance
thanks mate appreciate it....
Old 01-10-2006, 12:47 PM   #6
fordperformance
does anyone know a rough estimate on the price to replace this ????
Old 01-10-2006, 12:59 PM   #7
Smoked
Burnin Rubber
Smoked's Avatar
Depends on what you get done.
Replace or rebuild the Alt. Personally I would replace it with a New Bosch, probably aroud $400 plus.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2006, 01:07 PM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
you are not going to like this but you seriously need to check the alternator is not covered in oil.. It is well worth fixing the power steering pump and/or high pressure lines because they leak straight into the alternator.. 90% of the times your alternator fails is because it fills up with oil :(
Old 01-10-2006, 01:19 PM   #9
satria
FOXWHO
satria's Avatar
yep, damn alternators...they cark it when you least expect it.
had it happen to me before too
satria is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2006, 09:40 AM   #10
f6 typhoon
i have priced up a new one about $650 dollars better off rebuilding it i think
f6 typhoon is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2006, 11:05 AM   #11
Chippar
The Ancient Warrior
Chippar's Avatar
Mate, I just checked on eBay where you can get a genuine ford alternator for $240 plus $25 postage.
http://cgi.ebay.com.au/Ford-Genuine-...QQcmdZViewItem
Chippar is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2006, 05:16 PM   #12
fordperformance
haha ebay... thanks man.... my powersteering fluid does leak.. so maybe thats what has happened. Is it worth just takeing the Alt. out and gettin a rebuild ?.
