Old 03-10-2006, 12:22 AM   #1
Kryton
Kryton's Avatar
Default Towing an Auto....
need to know if theres any major problems with towing an Auto about 1km in distance?
anything in particular that needs to be done?
can it be done or is it a no-no?
the VT key fob went flat and now the car is stuck at Safeway and wont start because of the flat key fob.
need help ASAP.
saying how crap Holdens are isnt going to help either....it isnt my car.
Old 03-10-2006, 12:25 AM   #2
trick_xd
I build your wish list...
trick_xd's Avatar
It dose not hurt to "Flat Tow" any car even if it is a auto for a few kms..
But if you was going to tow it 50km or so I would say remove the tailshaft ..
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 12:27 AM   #3
Kryton
Kryton's Avatar
just chuck it in neutral and it should be right?
Old 03-10-2006, 12:28 AM   #4
Lukeyson
Right out sideways
Lukeyson's Avatar
i would think that short of a distance would be fine in neutral
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 12:29 AM   #5
capriv8
Im no expert but maybe unbolt and remove the driveshaft or call a tow truck that can winch up on the flatbed. Good luck
capriv8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 05:46 AM   #6
fmc351
let it burn
Go slow, 1km isnt going to damage anything.
Ill assume its been done by now anyway.
fmc351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 02:30 PM   #7
BPXR6T
It will be fine. Stating the blindingly obvious but beware of your brakes.
BPXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 02:44 PM   #8
Kryton
Kryton's Avatar
thanks guys. its down at the work shop as we speak.
NFI whats wrong with it at all.
key fob doesnt work at all, car will start then stall straight away. all fuses seem fine so im guessing it has something to do with the immobiliser.
went through commodorecentral website and none of the fixes helped.
Old 03-10-2006, 04:37 PM   #9
Kryton
Kryton's Avatar
well it turned out it was a flat key.
thanks to Holdens forsight they soldered in the batteries and made the fob a sealed unit so we had to buy a new fob and get it reprogrammed.
another great way to spend $100.
Old 03-10-2006, 04:38 PM   #10
Creampuff
149 rwkw of Style
Creampuff's Avatar
I thought towing was illegal?
Creampuff is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 04:40 PM   #11
Dazza XLT
Back in a Ford
Dazza XLT's Avatar
While in the NT, this same thing happened to a person, while at Top Springs... About 300klm from Katherine.
Had to ge a Flat top back to the Holden Dealership.
Expensive exercise just for a small battery.
Is there any signs before the battery dies??
Back in a Ford!
2020 Ford Ranger XLT Hi Rider!
Dazza XLT is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 04:51 PM   #12
Kryton
Kryton's Avatar
yeah...its usually when you have to get closer and closer to the car to unlock/lock it. since we've had the car we have had to be within 3 metres of the car for it to unlock/lock.
over the last couple of weeks it occasionally didnt work at all and you would have to manually open the car with the key.
i think for future reference, if it gets to the point that you have to stand next to the car to unlock it....GET A NEW KEY!
