Old 18-06-2009, 11:19 AM   #1
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Question Toyota Aristo
Yeah yeah
It's a Toyota _
An import Toyota at that. I have a general disdain for the turbo Skyline imports and other of that ilk however I had never seen one of these before until yesterday and what I saw was a luxo, 4 door sedan that was REAR WHEEL DRIVE. So I did a little googling on this car and strike me pink - they also made an AWD, V8 version!! Using the 4.0L V8 from the Soarer and other Jap-only Toyotas and Lexuses (Lexii?)
At 1740kg the AWD V8 is a little bit on the porky side and the motor 'only' has 191kw to move its chubby **** around, but a blower will soon sort that out. The 4.0L V8's tough bottom end should have no trouble dealing with the extra power.
Not too many luxo AWD V8 sedans getting around.
So does anyone know anything of these cars?
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 11:28 AM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
Fitting one of Lexus V8 to a Mustang shaped Celica, RA28 ...
Then there's this CRAZZY Kiwi fitting one into a Starlit !!!
http://www.lextreme.com/forums/attac...3&d=1244530499
Daily driver GTE FG..
Old 18-06-2009, 11:34 AM   #3
PepeLePew
Workshop & Performance
PepeLePew's Avatar
Nothing except a lass at works' boyfriend has one she brings in occasionally. I just cant get past the looks of the thing, it has no redeeming features including the interior (unless there is some sort of base version and this is it?)
When close is good enough and the 6 MPS in the driveway has FoMoCo written all over the place. Xr5 for sale shortly...just not a hatch guy
PepeLePew is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 11:34 AM   #4
Fairlane
V8 Powaah
Fairlane's Avatar
They are essentially just a Lexus GS series just in different levels of trim for the JDM. Virtually everything in Japan has an AWD option, most of them imported to Australia would be just the RWD ones.
There are quite a few of them around, some of them with LExus badges, pretty sure you had a choice of N/A 2JZ, Turbo 2JZ and 1UZ-FE. Im personally not a fan, I prefer both the Crown and the Cresta/Mark2/Chaser.
They were more of a Luxo barge in Japan- Sort of slotted between the Mk2 and the Crown.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 11:37 AM   #5
Kieron
Dunno much about them except they are damn quick. There's a dark green one I see up around the Whitfords area in Perth and he 'demonstrated' it's performance a few weeks back..
Kieron is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 11:41 AM   #6
ottoS13
Rat
ottoS13's Avatar
i looked into these in the past. check out this link for more info on importing them and options available.
http://www.prestigemotorsport.com.au...php?storyid=11
1965 XP Rat Rod Project
ottoS13 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 11:42 AM   #7
Road_Warrior
Pity the fool
Could be - the one I saw had leather and full electrics inside, but not as trick as the Soarer is inside.
Could be the 3.0L turbo one, it's probably the most popular model (of that type) with the rice box brigade, being a turbo and all.
Old 18-06-2009, 11:47 AM   #8
ottoS13
Rat
ottoS13's Avatar
Twin turbo JZS147 2JZ-GTE 3 litre 206KW/1680kg IL6 Engine -122kw/tonne.
Non turbo JZS147 2JZ-GE 3 litre 169kW/1580kg IL6 Engine - 107kw/tonne.
4WD UZS143 1UZ-FE 4 litre 191 kW/1740kg V8 Engine -109kw/tonne.
think it's obvious which one to go for if you had the choice.
Old 18-06-2009, 12:05 PM   #9
ebxr8240
ebxr8240's Avatar
Yea the V8 has better cruising ability though..
Designed to pull lard arss cars around..
These cars are luxo cruisers..
Even the soarer is a luxo 2 door..
All too heavy with heaps of elect goodies.
The 2J or [t] doesn't have masses of low end torque...
Old 18-06-2009, 12:50 PM   #10
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yeah i have seriously considered on many occasions buying an Aristo.
Seriously, they're quite possibly the ultimate car.
RWD, Plenty of poke, luxurious, Jap quality, sedan, fairly good economy considering, just slightly smaller than a falcon/commodore.
I wish i wish i wish i wish they would bring back a mid sized RWD car with a small-medium six. Call it torana or cortina or whatever you like, but i'm sure there is a demand for it.
i'm an import nissan hater, big time. i'm a german (kraut) car hater too, so that knocks off MB and BMW.
pretty much leaves the the Lexus GS300 and the Toyota Aristo as the most desirable practical cars for me.
Old 18-06-2009, 01:10 PM   #11
Road_Warrior
Pity the fool
I almost bought a Soarer V8 before I bought my BA, because it was around the same price range, power and fuel consumption, the only thing that put me off was paying $15K for a 10 year old car when I could (and did) buy an 18 month old car with remainder of NCW for the same. And the issue of the odometer reading on some of those imports being not quite truthful...
Old 18-06-2009, 02:00 PM   #12
5L
[ 5L ]
5L's Avatar
my mate had one with hks dump pipes and hks cat back exhaust and a decent air intake setup. imported it with the exhaust gear, coilovers and a nice set of lightweight deepdish wheels.
i wasnt that impressed by the looks at first, but with the coilovers it handled well, with the 2jz tt in it was quick when it got moving. and had a nice comfy feel when driving.
id imagine his would of done a mid 13 second 1/4, put on a nice front mount intercooler setup and up the boost for 12's id imagine.
www.ignitionimages.com
Old 18-06-2009, 02:36 PM   #13
Mr Hardware
the only thing that put me off was paying $15K for a 10 year old car when I could buy an 18 month old car with remainder of NCW for the same. And the issue of the odometer reading on some of those imports being not quite truthful...
Exactly the same for me mate.
Oh and the fact that one day i came home at 9pm at night only to find that i'd split a radiator hose and nearly all my coolant was gone. Because it was a falcon, i was just able to go down the road to supercheap at 8am the next day and get a hose, fit it, refill coolant and still get to my meeting 60km away at 9:30am. Try doing that in an aristo/soarer/random poser import
Old 18-06-2009, 04:24 PM   #14
ottoS13
Rat
ottoS13's Avatar
you could actually do the same thing if there was an australian delivered equivalent. i had a 'random poser import' (1990 s13 silvia) but because the later model (mid 90's s14/200sx) was australian delivered i could basically replace any part walking into repco or whatever.
Old 18-06-2009, 05:12 PM   #15
Road_Warrior
Pity the fool
But that's not a Soarer or an Aristo is it...
Old 18-06-2009, 05:32 PM   #16
loosey
Aristo's are good, I've only ever seen one v8 aristo in australia for sale though (not that I've looked hard)... So you might want to check they can be imported (the one i saw may have been brought over on the ownership rule...) If you're serious about it get in touch with ironchef imports, he really knows his stuff...
Your average 'poser import' wouldn't break down in the first place :P.
loosey is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 08:56 PM   #17
ZA-289
ZA-289's Avatar
I like aristo's, the TT 2J is freaking quick with a few mods. Some had a fold down car phone etc in the rear seat armrest.
ZA-289 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 09:02 PM   #18
Windsor220
Now Fordless
Windsor220's Avatar
2JZ no . Will decimate all if you put about 15 grand in it or more...
Old 18-06-2009, 09:16 PM   #19
duaned
duaned's Avatar
I'm pretty sure a mate had an Aristo, it certainly was a V8. He had deep dish cromies on it, and air bag suspension at the touch of a button. What freaked me out about this thing as it had a refridgerated compartment at the rear, ( we coudn't fit a sub behind the back seat due to the compressor etc., tv screen and tuner, and an amazement of other electrical goodies that were stock for a car of it's year of manufacture. Unreal.
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 08:53 AM   #20
Mr Hardware
you sure that wasn't a celsior, duaned?
Oh right, because rubber hoses on jap imports are so much better than rubber hoses on falcons. My sarcasm meter better be broken.
Old 19-06-2009, 10:42 AM   #21
Road_Warrior
Pity the fool
lol
Yeah Duaned I think your mate may have had a Toyota Celsior. Basically an early Lexus LS400 but with Toyota badges. Had all sorts of weird s--t like a cooler box in the back seat armrest and TV in the dash.
Old 19-06-2009, 11:12 AM   #22
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
The Aristos were available as a straight 6 N/A, straight 6 TT and a pretty rare V8 4WD.
I could’ve got a nice black one 3-4 years ago with 75-80k (who knows if it was genuine mileage) for $11k.
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 11:25 AM   #23
Joshvee
A New Convert
Joshvee's Avatar
Whats wrong with a Falcon?
And did you really have to put the word Kraut after German? It is a derogatory term u know.
FG FPV F6 310 Dash
12.836 @ 174.29 Kph Factory Stock tune.
Joshvee is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 12:34 PM   #24
loosey
I'll admit when i first got my car (skyline) a heater hose went, luckily there's a radiator joint and mechanic across the road from my work and they had the car fixed by the afternoon.
What you'll find is a lot of the more popular imports be it skylines/ stageas, soarers/ aristos, 300zx's, silvias etc will have spares readily available. It's only when you get into the slightly less popular imports such as cimas, gsr's etc you'll have trouble. The other thing is look how often aforementioned imports get written off.
Old 19-06-2009, 12:50 PM   #25
duaned
duaned's Avatar
You maybe right mate, I'm just not into the import scene myself. Did the Celsior come in V8 guise?
Old 19-06-2009, 12:59 PM   #26
Road_Warrior
Pity the fool
Yep. Had the same 4.0L V8 as the Lexus and the Aristo (I think)
Old 19-06-2009, 01:07 PM   #27
Matt47569
Matt47569's Avatar
1UZFE.. Great smooth engine from toyota would have so much potential if it wasnt stuck in a 1800kg car.. search it on youtube there is a video of it been revved to 6500rpm with a 50 cent coin standing upright on the block, and it doenst fall over.. also they come already with some forged internals so they have no trouble revving over 7k stock, once the limiter is removed
Matt47569 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 01:15 PM   #28
Fireblade
Wizard Member
Fireblade's Avatar
And a freshly imported one will have new hoses anyway, they have to be changed for compliance.
Frosty and FPR - Bathurst winners 2013
Fireblade is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 09:12 PM   #29
ebxr8240
ebxr8240's Avatar
Here's the bottom end of a 1UZ-FE 4.0 V8 same engine in Aristo.. One of them..
This one has Aussie Argo rods.. The sump is very much the same as new engines where it doubles up as mains support.. Not fitted yet..
Top end..
Complete..
Old 19-06-2009, 09:42 PM   #30
Mr Hardware
yeah true that.
Nothing. I'd just prefer something a slight bit smaller, but still a 4-door rwd sedan.
Yeah and they're the only ones i'm interested in. Aristo, Cosmo etc. The import market is probably 90% Nissan and i don't like nissans.
