30-10-2009, 01:41 AM | #1 | ||
Getting Sideways
can any one tell me where to attach my tach signal sensor wire
i got a DRIFT digital tach its got the + - and signal wire and the AWESOME little cut into the wire joiners but anyway what wire should i attach the signal wire to there has to be something but there is a tach in the dash and it has to get it some how i got the new one because when i give it some the dash tach jumps up in like 1500 rpm lots and its REALLY annoying :(
Ford Falcon AUII - 3" Exhaust, 18" Wheels, Full TS50 Kit, Custom Air Intake, LSD, Sony Audio 2x 12 Subs, Twin Thermo Fans, K&N Air Filter, Polished Aluminum Rocker Cover, Pacemaker Headers, High Performance Tune, Blue Interior Lights + Neons. 0-100km 6.42s 0-180km 22.1s. Not to bad for my second car. Next Mod: TURBO : Any Holden drive could tell you exactly what the back of my car looks like yet no idea what the front looks like. |
30-10-2009, 02:23 AM | #2 | |||
A cheaper solution to installing a second tacho is fixing your current one - my bet is the cluster has been out at some stage, and the needle has been pushed back on too hard; just get a fork under the needle and lift up slightly, and it should work nice and smooth. If you're not sure how to remove cluster and get the clear plastic cover of, do a search in the AU section on "cluster" (there's plenty of threads covering how to remove etc). Is yours a 6 or an 8? If the former, I'd be interested to know how you got the 0-100 time in your signature.
30-10-2009, 07:38 AM | #3 | |||
30-10-2009, 08:46 AM | #4 | ||
Back on the road
Yeah, its a pink wire and referred to as Clean Tacho Output. Its pin 45 on the V8, not sure about the i6.
Looks like that 0-100 time was measured with a G-Tech
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
30-10-2009, 09:01 AM | #5 | ||||
06-06-2014, 03:27 PM | #6 | ||
Au 2 i6 what counts rpm? Ie how does the car verify. Thanks besides the tachometer, where does tachy get it's reading?
06-06-2014, 10:31 PM | #7 | ||
Auto Nerd
Most likely the crank sensor via the computer. The computer would convert the analogue signal to a digital pulse.
