Old 01-02-2011, 03:50 PM   #1
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Default Steel nanotechnology
http://www.autoblog.com/2011/01/31/s...t-of-our-cars/
Steel nanotechnology can reduce the weight of our cars
by John McElroy (RSS feed) on Jan 31st 2011 at 4:30PM
Making Stronger Steel As Light As Aluminum
The world's largest steel maker, ArcelorMital, says it has come up with a new kind of steel that the world has never seen before. Thanks to nanotechnology, the company says automakers can now match the weight of aluminum cars, but do it in steel at far lower cost.
Specifically, ArcelorMital says it can take 188 pounds out of the body-in-white of a car. The body-in-white, or BIW, refers to the basic structure of a car, including the doors, hood and deck lid. That's a big number. By taking so much weight out of the structure, other components such as the powertrain, drivetrain, brakes, etc. can be downsized as well. In other words, the total weight savings could be even bigger.
ArcelorMital is already showing this new kind of steel to automakers. It isn't yet ready to publicly divulge any of the technical aspects of the steel or how it's using nanotechnology to make it. The company says we're still two to three years away before we get those kinds of details. And that's about the time we'll see this steel show up in production. No word yet on which car company may be the first to use it, but the rumor on the street is that Ford is all over this technology.
The nano steel itself is not inherently lighter, but it's so strong that automakers can use thinner gauges and that's where part of the weight savings comes from. Another part of the weight savings comes from not having to use additional brackets, gussets or panels to strengthen the structure.
For example, A-pillars are becoming so big these days due to roof crush standards that they are actually becoming a safety hazard. The fat A-pillars can partially block your view to side traffic or pedestrians. But with this nano steel, A-pillars could be made much thinner with no sacrifice to structure or safety.
Nor is this steel cheaper than other grades of steel. In fact, it's probably a little bit more expensive. But by eliminating all those brackets and extra panels, the total tooling cost of a car goes down, and that's where the costs savings comes from.
To get the maximum 188-pound reduction in the BIW, an automaker would have to design-in the nano steel's capabilities using a clean sheet approach. But ArcelorMittal says that some applications, especially cross-members, lend themselves to running changes on existing designs.
The nano steel does require a newer manufacturing technique called hot stamping. That's where automakers heat up the steel blanks that go into a stamping press to the point where they're literally glowing red. Then they feed the red hot blanks into a press and stamp them into body panels. Heating up the steel makes it much more pliable and enables it to be formed into more complex shapes. Actually, this is a fairly common process already in use today, used to form the high-strength steels that have been available for the last decade and a half. So, while the nano steel requires hot stamping, it's not as if automakers need to make a big investment in manufacturing technology.
It's very impressive to see the steel industry delve into new technology to keep its product relevant. Aluminum, magnesium and composites definitely pose a competitive threat to steel. But they're also considerably more expensive, are not as easily repaired in most body shops, and require considerably more energy to recycle. That's why they've not found widespread use in cars, or at least not as widespread as steel.
And yet, I've heard tantalizing whispers of the new breakthrough coming in aluminum. It's called covitic aluminum, where somehow they impregnate aluminum with carbon fiber. There, now you know about as much of it as I do.
I'm pretty sure we'll get some sort of announcement later this year about covitic aluminum. But for right now at least, this nano steel seems to be the latest word in materials technology.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2011, 04:11 PM   #2
Cheese3
The BEST Falcon is the AU
Cheese3's Avatar
Interesting!
Amazed that ford was mentioned? I would of guessed high end euro sport cars to reduce weight
Cheese3 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2011, 04:15 PM   #3
vztrt
vztrt's Avatar
I know Volvo developed the technology when they were with Ford and it was about the way the steel was stamped (hence the thin gauges). I remember reading this back in 06. So they have the correct auto manufacturer.
Daniel
Old 01-02-2011, 05:19 PM   #4
flappist
Ah yes but at what cost.
These things are all good until the average tightarse is told it will cost $50 more.
Old 01-02-2011, 05:30 PM   #5
vztrt
vztrt's Avatar
Actually compared to putting in other types of material its cheap. The big cost will be tooling which is factored in on cars.
Daniel
Old 01-02-2011, 05:45 PM   #6
Airmon
King of the Fairy's.
Airmon's Avatar
If replacing Aluminium from the gist of the article it would be cheaper. And as said, in the article and after, the tooling costs could go down.
www.bseries.com.au/airmon
They say less talk more action,
I say more torque less traction!
Airmon is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2011, 06:45 PM   #7
Revolver
Big Member
Revolver's Avatar
Its not a case of tooling that is the big price jump.
It is the physical cost of the metal.
Just the same as anything else. If has more strength for less wieght, that comes at a cost. Same as a run of the mill car vs a high-po one. It's not the tooling. It's the exclusivity of this product, & what it can do. If it it's a higher performance product you will pay more. Simple.
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing
Rollin' on genuine ELGT wheels.
K&N Filter
/////Alpine Sound.
EBGT Momo Woodgrain Steering Wheel
The Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile.
Revolver is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2011, 11:49 PM   #8
vztrt
vztrt's Avatar
Its still steel, but the process in getting it lighter is actually making the metal thinner in places were it will not effect the strength. This is not a special alloy, its the same metal.
Daniel
Old 02-02-2011, 01:17 AM   #9
Ibrox90
Ibrox90's Avatar
Nanotechnology manufacturing isnt a new concept.
Ideally with nanotechnology, eventually the car will build its self in a similar way how the human body grows.
HIS
THUNDER
2004 BA XR8
Blueprint
Mods:
Quad Exhaust, Hi-Flow Air filter, BFtiming chain tensioners, Billet Oil pump gears
stage 2 shift kit, riding on G6ET 18's
HERS
FLASH
BA MKII XR6 Turbo
Phantom Purple
Typhoon front end
Parking your ford after a long day of being Awesome
http://www.facebook.com/pages/Parkin...37774932974038
Ibrox90 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2011, 01:23 AM   #10
buggo
[BU66OS]
buggo's Avatar
What do you mean? Cars will be organisms or something???
FG XR6 Turbo Nitro
BA XR8 Manual
buggo is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2011, 09:06 AM   #11
flappist
You mean like diamonds are just carbon, like in a pencil?
CPUs are just silicon, like in sand?
Aircraft are made out of the same stuff as beer tins and foil.....
All the same aren't they?
Old 02-02-2011, 09:38 AM   #12
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
This sounds just like the latest development from the ULSAB (UltraLight Steel Auto Body) Consortium that has been in place for around a decade.
UltraLight Steel Auto Body (ULSAB) Programme
There is also a number of offshoot projects listed under WorldAutoSteel PROJECTS menu for these keen on further reading.
The Australian Steel Industry and Ford have been represented from day 1. The technology developed is gradually being taken up as it becomes cost effective.
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2011, 10:10 AM   #13
The Wheel Deal
The Wheel Deal's Avatar
Didn't you watch Transformers??
www.thewheeldeal.com.au
Australias' best deals on tyres & wheels
FordForums Discount Coupon Code: 4rd4rum
The Wheel Deal is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2011, 10:39 AM   #14
burnz
VFII SS UTE
burnz's Avatar
we are borg, your biological destictivness will be added to our own..
GO SOUTHS
Old 02-02-2011, 11:45 AM   #15
vztrt
vztrt's Avatar
You can make diamonds on a production lab to the point it can fool the experts.
CPU's are made by a process of flowing chemicals to create the billions of transistors in silicon.
Pretty sure they have a material with the metal (escapes me what it is ATM) that keeps the strength but keeps it lightweight. But it isn't a new allow.
The nanotech makes panels/parts out of steel that are thinner then how it would normally be done. But it would be done in a way that it would keep it strength. So thus using less steel and making it lighter.
Daniel
Old 02-02-2011, 12:49 PM   #16
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Would be a great way for Ford to reach their weight reduction targets. One of the key stated goals of One Ford.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2011, 01:10 PM   #17
flappist
Yes exactly right but each of these uses several patented and/or proprietry processes to achive the end result all of which are licensed and therefore cost money.
Old 02-02-2011, 01:22 PM   #18
vztrt
vztrt's Avatar
Unless you own the patent.
Daniel
Old 02-02-2011, 02:12 PM   #19
Ibrox90
Ibrox90's Avatar
not at all like that.
Tiny Nano builders put the molecules in by them selves.
No cars wont be organisms thats impossible but in theory one day they will build themselves
finally glad i got to use my 3 weeks of a nanotechnology degree for something
HIS
THUNDER
2004 BA XR8
Blueprint
Mods:
HERS
FLASH
BA MKII XR6 Turbo
Phantom Purple
Typhoon front end
Old 02-02-2011, 02:43 PM   #20
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
They don't really elaborate on the nanotech side of things (something to remove/hollow out the metal?). While I'm a fan of forged composites, plastic panels, carbon fibre panels, 3d printing and now covitic aluminum it'll be interesting to see how they can be repaired after a bingle (e.g. Glued aluminum Aston Martin monocoques).
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2011, 03:09 PM   #21
flappist
Exactly, then it just costs everyone else money......
Old 02-02-2011, 03:20 PM   #22
Fled74
The Thread Killa
Fled74's Avatar
Leaving you to roll around in it like Scrooge McDuck.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle
Fled74 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2011, 06:37 PM   #23
vztrt
vztrt's Avatar
Default Re: Steel nanotechnology
Not really wanting to start a new thread, but Ford seem to have a plastic weight save tech that is being worked on.
http://www.autoblog.com/2011/04/04/f...used-plastics/
Ford looks to save weight with bubble-infused plastics
by Aaron Richardson (RSS feed) on Apr 4th 2011 at 6:21PM
Just like every other automaker, Ford is looking into making its cars lighter, and thus more eco-friendly. Thanks to a bubble-infused plastic introduced at the Massachussetts Institute of Technology [MIT] called MuCell, Ford says it can step further toward its goal of lightening all its cars by anywhere from 200 to 750 pounds.
MuCell is made by pumping tiny bubbles of nitrogen or carbon into standard injection-molded plastics. Though the bubbly plastic is slightly weaker than the standard stuff, Ford says the difference will be negligible, since its plastic parts are engineered to be 50 to 100 percent stronger than they should ever need to be.
Though the idea is still in development, Ford says it wants to be running MuCell plastics in all its cars by 2020. Though the technology has been around since 1995, it hasn't made sense for automakers to start buying in until now. With a new focus on green technology in the automotive industry, the move suddenly makes a lot of sense, and Ford will start using the plastic in items like engine covers beginning in the next few years. Check out the official press release after the jump.
[Sources: Ford, FastCodeDesign]
Daniel
Old 05-04-2011, 06:43 PM   #24
SteveJH
No longer a Uni student..
Until the Patent runs out.....
SteveJH is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2011, 12:05 AM   #25
Buntz
Straight Eight
Buntz's Avatar
Luckily I forum searched this before posting it.
I'd expect to see a concept car from Ford introducing it's new ideas and technologies for saving weight, in the near future. Finally America has seen the light. Lightweight equals better fuel economy, and more sportiness. Cars are coming full circle but far more advanced. Ford may not have got a car guy for their CEO.. but this aeroplane guy seems to be working as well if not better than hoped.
The Falcon is dead. Long live the Mighty Falcon.
Buntz is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2011, 12:20 AM   #26
SteveJH
The concepts are all basically the same anyway.
