Closed Thread
Old 11-10-2011, 09:07 PM   #1
cartaa100
FG POWER
cartaa100's Avatar
Default FG XR6 producing most torque in the world from an NA 6 (stock)
going by the 421nm on 98 octane i cant find a car with more torque from an NA 6 engine.
2009 FG XR6 EGO
  http://fordforums.com.au/showthread.php?t=11332753
cartaa100 is offline
Old 11-10-2011, 09:12 PM   #2
FalconXV
FalconXV's Avatar
Default Re: FG XR6 producing most torque in the world from an NA 6 (stock)
How much did the 4.9 L six fitted to F100s in the 80s/90s make? It might run it close for low down torque. Still, a pretty compelling reason not to switch to D37!
FalconXV is offline
Old 11-10-2011, 09:13 PM   #3
cartaa100
FG POWER
cartaa100's Avatar
Porsche Carrera S comes close with
420nm
2009 FG XR6 EGO
Old 11-10-2011, 09:17 PM   #4
cartaa100
FG POWER
cartaa100's Avatar
going by this link http://en.wikipedia.org/wiki/Ford_F-Series
359nm
2009 FG XR6 EGO
Old 11-10-2011, 09:19 PM   #5
SteveJH
No longer a Uni student..
Highest Torque does not mean much when other 6 cyl cars have a higher AUC due to keeping and making more power at higher rev's.
Remember, the Ford I6 makes more power then the BMW V8 powering the M3. Torque isnt everything.
SteveJH is offline
Old 11-10-2011, 09:20 PM   #6
RAPID_BA
Any diesels out there? Have to give it a run for its money
RAPID_BA is offline
Old 11-10-2011, 09:22 PM   #7
FreddyDUZ747
FreddyDUZ747's Avatar
http://www.chargerclubofwa.asn.au/me...asp?iMediaID=7
4.3ltrs of tripple carby bliss.
FreddyDUZ747 is offline
Old 11-10-2011, 09:33 PM   #8
cartaa100
FG POWER
cartaa100's Avatar
i realise it isnt everything but it helps alot for accelleration, im just curious if there is a NA 6 with more torque than it?
2009 FG XR6 EGO
Old 11-10-2011, 09:52 PM   #9
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Nothing has more torque than an internet forum !
Road Games is offline
Old 11-10-2011, 09:54 PM   #10
drew`SEVNT5
Porsche 911 GT3 RS 4.0
368kw, 460nm, 1,360kg.
A proper performance car.
Not a taxi
Current
-2011 Nissan 370z Coupe (6M)-
-2006 Husqvarna SMRR450-
drew`SEVNT5 is offline
Old 11-10-2011, 10:11 PM   #11
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
Where did Ford quote 421 nm on 98 for the I-6, I'm curious to see?
I know they were quoting 405 nm on 95.......
jpd80 is offline
Old 11-10-2011, 10:18 PM   #12
cartaa100
FG POWER
cartaa100's Avatar
Not a taxi
dont get me wrong the RS is mindblowing but
your'e comparing a $38,000 car to $330,000
you like to take little shots at me because im on my ps and drive a NA xr6... with close to your power output and is worth more just putting it out there i wouldnt say your 6 year old falcon is any head of mine... rekon you can keep the smartass comments to yourself? id rather add than argue
good work my little keyboard warrior
2009 FG XR6 EGO
Old 11-10-2011, 10:20 PM   #13
cartaa100
FG POWER
cartaa100's Avatar
ive read it from a few reviews, its also on wiki and my dealer confirmed it.
quick google search should show
2009 FG XR6 EGO
Old 11-10-2011, 10:25 PM   #14
FreddyDUZ747
Smile Re: FG XR6 producing most torque in the world from an NA 6 (stock)
Originally Posted by FreddyDUZ747
Ill quote myself to get some attention.320 foot pounds=433.861743453NM.
Like I said,pure bliss.I think these were only 4k new thoughYou know what I mean.
Old 11-10-2011, 10:30 PM   #15
cartaa100
FG POWER
cartaa100's Avatar
just had a look through, id never even heard of that car! ahah how much will one set you back now?
2009 FG XR6 EGO
Old 11-10-2011, 10:42 PM   #16
jpd80
jpd80's Avatar
Wiki says this but provides no source:
These figures rise to 208 kW (279 hp) and 420 N·m (310 lb·ft) on premium 98 octane fuel.
jpd80 is offline
Old 11-10-2011, 10:47 PM   #17
F6E
F6E's Avatar
On paper, the FPV I6T makes more power than the M3 by 1 KW, Sounds good ? but to put that into perspective the M3 (with the same 4L capacity) does it without forced induction. There is no comparison.
The E's build thread .. http://www.fordforums.com.au/showthread.php?t=11378145
current rides.....
F6E - Cooler, Cat, CAI, Flash, 20's, SSL's - 317 rwkw : 9/10
BFII - Workhorse yoot : 6/10
past bitches of note.....
E60 M5 - V10 excess, the pinacle : 11/10
VE SSV - 102000 trouble free Kms : 9/10
VZ Cross8 - V8 AWD, great allrounder. : 8/10
BA XR8 - Fat & Slow : 3/10
XH XR6 - 8/10
XG S - 7.5/10
F6E is offline
Old 11-10-2011, 10:48 PM   #18
SteveJH
It doesnt make it any less of a Naturally Aspirated 6 cylinder engine.
Defensive much?
SteveJH is offline
Old 11-10-2011, 10:50 PM   #19
SteveJH
Sure, but as well as being turbocharged, the F6 engine makes an extra 150 or so extra NM of torque over the M3 V8 which makes up for its lower red line.
However, I was comparing the I6N/A, not the I6T.
SteveJH is offline
Old 11-10-2011, 10:57 PM   #20
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
http://inflationdata.com/inflation/i...Calculator.asp
$4300 in 1972 is apparently $23K in todays money.
Not bad for a performance car, costs less than todays mid range small cars.
Franco Cozzo is offline
Old 11-10-2011, 10:59 PM   #21
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
I wish I could get an E49 for $23k.
Daniel
vztrt is offline
Old 11-10-2011, 11:04 PM   #22
FPVGT500
FPVGT500's Avatar
Andddddd you have to remember the F6 is heavily detuned from factory unlike the M3 its running at its peak
FPVGT500 is offline
Old 11-10-2011, 11:04 PM   #23
Resurrection
I was correct - AGAIN
Resurrection's Avatar
If you don't like the answer, don't ask the question. You original post made no reference to price - just maximum torque value.
Resurrection is offline
Old 11-10-2011, 11:16 PM   #24
flappist
There is actually a wiki page that states that the I6 makes 100 GAZZILLON newtonkilometres even before you start it running on Bundy Rum.
Well there will be in a few minutes when I make it up.......
flappist is offline
Old 11-10-2011, 11:17 PM   #25
F6E
F6E's Avatar
you said... "Remember, the Ford I6 makes more power then the BMW V8 powering the M3"
current rides.....
XH XR6 - 8/10
XG S - 7.5/10
F6E is offline
Old 11-10-2011, 11:20 PM   #26
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
I sold mine for 40k, lol. It did pay off my first house thought. So much torque down low, made all the V8s I had seem weak. A bit like the F6 does to V8s down low now!
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline
Old 11-10-2011, 11:25 PM   #27
LyleXR8
Yep no mention as to price so the Porsche wins!! Owned by his own thread
LyleXR8 is offline
Old 11-10-2011, 11:26 PM   #28
SteveJH
Oops, I meant more torque, my bad.
SteveJH is offline
Old 11-10-2011, 11:27 PM   #29
flappist
Pointless thread
Game over
flappist is offline
Closed Thread
