Old 16-10-2011, 10:53 AM   #1
XLS-5.0L
XLS-5.0L's Avatar
Default Weld Racing on AU offset
Ive been looking around for a while at Weld Draglites for my ute. Had 18's on for a little while, but its not the look im after.
I have seen a few AU/BA's with either Draglites or Pro stars and im wondering what offset they go with.
im looking at 15x6 or 15x7 on the front and 15x8 on the back, but before i order them i want to know if anyone can give me some details on fitment. I want the rears to fill out the guards...
cheers Jeff.
'02 AUIII XLS V8
- Pacemakers and dual 2.25
- Magnaflow cats
- MSD Coil pack
- 3/8 Phenolic spacer
- Sniper Flash tune
Love the Windsor!!
XLS-5.0L is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2011, 09:00 PM   #2
justa6
justa6
justa6's Avatar
Default Re: Weld Racing on AU offset
it's a bit of a problem with au offset. a standard ford 8" wheel has 6" B/S, and the biggest b/s pro stars or draglites go is 5.5". so they will stick out 12.5mm more, which will come very close to the tub, if not hit.
also, if yours is series 2, with the bigger 2 spot brakes, you will have to modify them to put 15's on the front.
ba's you see with big rears under them have shortened diffs, so the offset is not a problem.
justa6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2011, 09:42 PM   #3
b2tf
not here much anymore
b2tf's Avatar
Illegal to go backwards in rim size, being an XLS yours would have had 16's from new.
RAM 1500
Old 16-10-2011, 10:08 PM   #4
mrfordfairmont
351 clevo
mrfordfairmont's Avatar
there is a au in brisbane with centrelines on it.... unsure of size but it look sweet
2006 ford territory turbo stock as a rock for now
2004 territory ghia
click here for pics
work daily ke laser ghia RIP
click here for pics
Daily EF II fairmont wagon RIP
click here for pics
XD 351 clevo lowered
click here for pics
thanks to
p.e.a.c.h performance at stafford
http://www.peachperformance.com
mrfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2011, 09:40 AM   #5
XLS-5.0L
XLS-5.0L's Avatar
hmmmm......interesting. might re-think. 16 inch is a very un-popular aftermarket size.
'02 AUIII XLS V8
- Magnaflow cats
- MSD Coil pack
- Sniper Flash tune
Love the Windsor!!
Old 17-10-2011, 10:02 AM   #6
XLS-5.0L
XLS-5.0L's Avatar
Weld Racing S71. 17 inch......thats the look im after!!
'02 AUIII XLS V8
- Magnaflow cats
- MSD Coil pack
- Sniper Flash tune
Love the Windsor!!
Old 17-10-2011, 11:19 AM   #7
blownv8au
Pro Street Au Ute
blownv8au's Avatar
The 17's might be the go for you, it will get you around the issue with the front brakes. I've got convo pros on mine 15x12 but i've built a custom tray. I've been looking for info on fitting them on the front with not a lot of help. So i'll be going for 15x4 1/2 or 5 with the least amount of backspace and mod the caliper if its needed.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
