Old 20-01-2012, 09:26 AM   #1
xp_wannabe
xp_wannabe's Avatar
Default AU2 VCT - Slight miss
I cannot for the life of me get rid of a slight miss that my ute has, just off idle, doesnt seem to matter if its under load or not.
I have done the following trying to fix it:
1. New plugs
2. New Top Gun leads
3. New VDO ignition coil
4. Reconditioned injectors (ultrasonic clean, new filter baskets, new o rings etc)
5. Cleaned throttle body and entire inlet tract including K&N filter
The miss is still there! It is 10 x better than before I replaced everything, but there is still a slight hesitation there and its really annoying me...
The spark plugs are Autolite 985's, gapped to 0.9mm as per Jim Mock Motorsport advice.
What else could it be? Is it a computer issue? Fuel somehow?
Thanks, Mark
xp_wannabe is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2012, 07:55 PM   #2
dieseltrain79
Default Re: AU2 VCT - Slight miss
Inlet manifold gasket . Try tightening up the inlet manifold bolts , see if they are loose .
Otherwise replace it , its common on the falcoons
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2012, 08:30 PM   #3
rmack
rmack's Avatar
Have you tried cleaning the Crank Angle Sensor?
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2012, 10:41 PM   #4
xp_wannabe
xp_wannabe's Avatar
Thanks for the suggestions fellas, but today I did the ECU reset (as described on here) and it seems to have fixed the problem.
Old 21-01-2012, 10:46 PM   #5
SSD-85
I love it when its that simple. Hopefully its the last youll see of that issue.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2012, 09:40 PM   #6
xp_wannabe
xp_wannabe's Avatar
Actually, scratch that.. The miss is back...
The ECU reset did help, and the very first drive after I did it was nearly faultless (I'm sure I didn't imagine it?!), but now it is back..
How do I clean the crank angle sensor, and where is it?
Do those cheap OBD2 scanners on ebay work on this model?
Old 24-01-2012, 01:28 AM   #7
mik
mik's Avatar
in this pic you will see the writing on the harmonic balancer, see the w just above that , the black plastic doover with the couple of wires coming out of it , that is the crank angle sensor(basically a magnetic switch), the harmonic balancer(crank pulley) has a toothed gear type thing attached to the back of it, one tooth is missing on that gear, this is a reference point for the engine computer, the computer counts the teeth from the missing tooth and knows exactly what the crank is doing and when to to set the spark off among other things i suspect.
http://www.olympicmotorwreckers.com....C6E21F626F.JPG
just my opinion , i`d be surprised if it was the crank sensor, but it can`t hurt to try.
i`d probably give it a squirt with a can of degreaser if i had too, i`m thinking maybe you could pull the plugs out taking note which cylinder they came from and see if one looks dirty or different to all the others, if the answer is yes i found one, it might pay to put a working old lead or plug in and see what happens, if it solves the problem you know one was dodgey(it happens on occasion),
if it doesn`t further investigation will be required.
Old 24-01-2012, 08:35 AM   #8
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Personally I would lose the Top Gun Leads, they're nasty. Value for money would have to be Eagle Leads, I run Eagles on both my cars and don't have an issue and running LPG they're very sensitive to a dodgy lead, and if you've got deep pockets there's Ice ignition leads. Others will have other preferences but none of them will be Top Gun that's for sure.
Bushbasher
MINE- AUII Forte
Old 30-01-2012, 04:42 PM   #9
xp_wannabe
xp_wannabe's Avatar
Bushbasher
I'm thinking it's the leads as well. The problem has intensified with the recent rain/humid weather we've been having.
I'm going to try the Eagles, and Repco will send the Top Gun's away to be tested, and if they fail they will refund my money.
Old 26-03-2012, 09:23 AM   #10
xp_wannabe
xp_wannabe's Avatar
Ute is now fixed, ended up being the intake manifold gasket.
See my thread here for more info:
http://www.fordforums.com.au/showthr...76#post4189676
Old 26-03-2012, 06:21 PM   #11
mik
mik's Avatar
well done.
Old 26-03-2012, 08:00 PM   #12
dieseltrain79
Score ;) Same on the wifes Au ghia !
Old 11-04-2012, 10:15 AM   #13
webbiegareth
Where'd you get the gasket from, how much... and how did you do it? It's fairly easy yeah?
Our AU has a slight miss at idle, it's very random. It's got new leads & plugs, no change... will probably look at the coil pack next, however if it's easy to change the gasket then I may as well do it, since everyone is saying it's very common in the AU's
webbiegareth is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2012, 10:34 AM   #14
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Try the inlet manifold bolts & see if they're loose too, probably need checking once a year. Not hard at all to replace ive done it. If not, yep its the coilpack !
cheers,Maka
Old 11-04-2012, 12:34 PM   #15
webbiegareth
I see I can pick up a new Bosche pack for $86 off ebay (with free postage), worth replacing it anyway for that price?
I'll buy a 10mm ratchet spanner and try tightening the manifold though... I've had a quick look at other threads and it looks doable to replace the gasket itself, apparently the hardest bit are the bottom two bolts (which they say to do first).
The one thing that worries me as I have some kind of bracket between the 1st bolt at the front of the inlet manifold and the water thermostat housing, so I'm not sure hot to remove the manifold without removing the thermostat housing to get that bracket out of the way?
Does anyone else have that bracket joining them together?
Old 12-04-2012, 09:59 PM   #16
Day-mow
rexnet
Day-mow's Avatar
That bracket is ok. All you need to do is loosen the thermo bolt and undo the inlet bolt and it's good. Make note of what bolts go where. Some very in size and also like a head. Work Ing a circular pattern moving inside out when tightening them up and Itll tighten up evenly. IMO bottem of cylinders 5&6 are very lame. 1/4 " drive Uni joints and extension bars are your friend!!!
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
