Old 04-03-2012, 08:10 PM   #1
imbhvn
Default t5 gearbox rebuild help
Hey peoples, can anyone shed some light on whats involved in rebuilding a t5 gearbox? how hard is it? are the bearings pressed into place ectc etc. Thanks in advance.
imbhvn is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2012, 11:14 PM   #2
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Default Re: t5 gearbox rebuild help
Not hard, but you need a good mechanical understanding. Gregorys' books actually have a half-decent walkthrough.
Special tools - Circlip pliers, a 3mm punch, and feeler gauges. You may need to buy some shims for the gears but usually the old ones provide the correct clearances once there are some new bearings under the gears. Doing the AU t5 is much easier than the earlier units as they have a cage bearing on the front of the mainshaft rather than loose needles. This also means you shouldn't need to get the mainshaft resleeved as they rarely wear away anymore.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 06:06 PM   #3
imbhvn
Cheers for the heads up, thankfuly the gearbox is covered by warranty, hopefully the box they give me this time doesn't fail me. probably wont hurt to do a rebuild anyway.
Old 07-03-2012, 12:35 AM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Haha hopefully! Looking at about $380 for the bearing kit, and $30 -$60 each for the synchros depending on what you need to replace. Usually first and 5th. The boxes usually go 2-300 000 km if looked after but don't like towing heavy loads in 5th on a regular basis.
Old 05-04-2012, 08:07 AM   #5
imbhvn
well got a phone call yesterday, the bearings are fine the gears sheared off! told me its not covered by warranty and tried saying i had been doing some heavy towing (which i hadnt) and that it will cost over 1000 to get it repaired. so now im left with a ****** box! ill upload a pic of the gears when i get home
Old 05-04-2012, 10:21 AM   #6
Chewy
Giggity
Threaten to call the ombudsman...
2001 AU11 XL UTILITY
Chewy is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2012, 11:37 AM   #7
mongrelEF
Bugger!
mongrelEF's Avatar
yup, if the car's still under warranty then stripped gears bloody well should be covered! In any case, towing won't kill the gear, it kills the bearing and in extreme cases, the gearbox casing. Not the gear! That has to be a casting fault. As above, speak to the ombudsman about it....
Old 05-04-2012, 11:56 AM   #8
blueoval
Critical Thinker
blueoval's Avatar
imbhvn - where are you located mate?
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
