Old 12-11-2012, 12:39 PM   #1
Kable72
Parts Interpreter
Kable72's Avatar
Default Drag racing tips
Hey guys,
Just wanting to get some tips before I put my XR6 on the strip. Not the first time on the strip but first manual I have owned so I don't know how to launch and shift without causing damage. Any tips would be great
BFMKII XR6 Turbo Sedan
6sp Manual Pedders Coilovers Short Throw Shifter
Kable72 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 01:50 PM   #2
Marksman X
Default Re: Drag racing tips
Only tip I have is to make sure the traction control is off. Other than that I just walk mine off the line (BA XR6T) as I have a 5spd manual and I don't really want to break it.
Marksman X is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 02:43 PM   #3
Kable72
Parts Interpreter
Kable72's Avatar
Well the other day I raced my mate (private property!) in his 4sp XR6 and I walked mine off the line but I just couldn't catch him. I got a 6sp manual and he just floored me. He got to load his up and I didn't know how to do it properly and safely in mine so I just walked her off and he spanked me?
Old 12-11-2012, 05:35 PM   #4
Dash_XR
Dash_XR's Avatar
I assume they don't have launch control like the turbos? I wonder if it can be turned on in the tune?
FG XR6 Turbo (Manual) - 301rwkws @ 15psi
Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's
Dash_XR is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 06:50 PM   #5
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
You need to use your clutch to control the launch and any potential wheel spin or to prevent loading up and laboring the engine and drive line. The clutch is the wearable item expect to smell burnt clutch at the end of the run and give the clutch plenty of time to rejuvenate before the next run.
You need to watch out for a slipping clutch, plenty of people have tried to do a burnout and ended up just smoking their clutch.
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 07:16 PM   #6
Kable72
Parts Interpreter
Kable72's Avatar
Any tips to identify a spinning clutch before it's too late?
Old 12-11-2012, 07:23 PM   #7
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Slipping clutch? Revs rise but speed doesn't.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 07:46 PM   #8
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
You should be able to feel a slipping clutch thru the lack of acceleration and increase of engine rpm. If its a slipping clutch during the burnout your worried about, angle your side mirror down to see your back wheels, have a quick look. Should be obvious if its slipping though.
Have more Horses than the guy next to you, if winning means something.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 08:33 PM   #9
Kable72
Parts Interpreter
Kable72's Avatar
Winning isn't everything as it's an N/A six. I just want to have some fun on the strip without breaking something. I know, things will break in racing. That's the nature of racing.
Old 13-11-2012, 11:12 AM   #10
Giant
Giant's Avatar
Just have fun, using street tyres you will most likely break traction before parts. You don't really require a burn out on street rubber, maybe one at the start of the night to clean the tyres.
Adjust your tyre pressures to get the best grip. Remove excess weight. If your running big wheels and tyres best to fit a set of 16 inch steel stock wheels for the drags to reduce rotating mass and give you more tyre wall for launch.
Old 13-11-2012, 01:57 PM   #11
Kable72
Parts Interpreter
Kable72's Avatar
So the tyres will go before anything else? Awesome, I just heard that the clutches in these things are a real let down so I didn't want to take it and have to baby it home with a bald clutch plate.
I just want to have some fun on the strip so I don't do it on the street. Not worth the trouble.
Old 13-11-2012, 02:06 PM   #12
Giant
Giant's Avatar
With in reason, just be sensible and look after the clutch and the car. The clutch will need time to recover after a run, so no back to back runs.
Drag racing is hard on the car so play smart. If your worried about it check with your local tuner and transmission place and see what they think.
Old 13-11-2012, 02:15 PM   #13
Kable72
Parts Interpreter
Kable72's Avatar
Yeah thanks a heap, Giant . Will post up some timeslips when I can get to a meet.
Old 20-11-2012, 11:57 AM   #14
XR6_661
Cane Farmer
XR6_661's Avatar
Mate, 5 grand clutch dumps should get you home!
Just walk it through first and lay into it from second. Don't stuff around doing a skid to warm the tyres...
If you want to worry about reaction times, start going for it on the last amber.
The number 1 tip I have is to not worry too much about times on your first outing, just have a blast with it!
1994 ED XR6T - Cobalt Blue.
2009 FG XR6 - Black.
Originally Posted by Tex
I couldn't give a crap how many are in their family, what gay passtimes they paticipate in, or whether they have a cat, dog or a freaken fish.
Keep your stinking family to yourself god damn it.
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2012, 10:52 PM   #15
ash68
depends on your budget.take it easy off the line doesnt cost much . or hammer it and replace broken parts with stronger ones .
ash68 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2013, 09:01 AM   #16
Kable72
Parts Interpreter
Kable72's Avatar
So I got it out last night! First run was terrible at 15.9 but almost stalled it on the start. Just messed it up real bad and bogged down hard. Second run I got a 17.3..... but that's cos I jumped the start lol. And my last run of the night I got a 15.1
It's got better times in him, just gotta learn how to drive properly. I got one good launch off and it felt really good but the other two it was axle tramp on a very sticky track so it was pretty brutal lol. I'll post a pic of my best timeslip when I get home
Old 20-04-2013, 09:27 AM   #17
Dash_XR
Dash_XR's Avatar
Good stuff mate, as long as the times are dropping then the night was a success IMO.
Old 20-04-2013, 09:35 AM   #18
Kable72
Parts Interpreter
Kable72's Avatar
It was a lot of fun! I'm taking that more than anything lol. I was supposed to have my KPM intake on yesterday but it still hasn't arrived yet >.> oh well.
Next time I go it should have the intake and a decent tune so the times should get a lot better!
Old 20-04-2013, 09:43 AM   #19
Dash_XR
Dash_XR's Avatar
What tyres are you using? Just the dunlops?
Old 20-04-2013, 09:50 AM   #20
Kable72
Parts Interpreter
Kable72's Avatar
Yeah just the dunflops. They had enough grip for me, I wasn't breaking traction off the line but it's not like I was getting good launches anyway
Old 20-04-2013, 08:29 PM   #21
Ibanezteve
What sort of helmet is required? If I rock up in a BMX Stackhat will they tell me to go home?
Or do you need an accredited motor bike helmet?
Ibanezteve is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2013, 08:40 PM   #22
Kable72
Parts Interpreter
Kable72's Avatar
Something like a motor bike helmet yeah. BMX stack hats are a no go
Old 22-04-2013, 09:17 PM   #23
Kable72
Parts Interpreter
Kable72's Avatar
http://www.youtube.com/watch?v=PXaMM-xb_xM if you're interested, it's the 15.9 run as it was the only good video I got from the night.
Old 02-05-2013, 07:58 AM   #24
noosacuda
noosacuda's Avatar
And now "the racing bug" bites, you'll want more, more power,more quicker times..... LOL!
noosacuda is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2013, 07:59 AM   #25
Kable72
Parts Interpreter
Kable72's Avatar
Yep it's getting tuned in a month or so lol. Have an xcal on it's way just gotta book it in and it's done.
Old 02-05-2013, 12:27 PM   #26
Giant
Giant's Avatar
Depends on how fast you plan on going. You can find the helmet info here: http://www.sydneydragway.com.au/uplo...nformation.pdf
Old 02-05-2013, 12:31 PM   #27
Giant
Giant's Avatar
In the video it sounds like your getting a fair amount of wheel chirp off the line, also when you changed gear.
Old 02-05-2013, 01:13 PM   #28
Kable72
Parts Interpreter
Kable72's Avatar
Yeah that was the commodore next to me. I nearly stalled that one lol. Mine's the one that you can hear over everything else.
Old 02-05-2013, 02:19 PM   #29
RAPID_BA
3000rpm takeoff slip clutch. should be about as hard as you can go without turning the tyres too much. Keep your auto mate honest off the line and then see who has the top end.
RAPID_BA is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2013, 06:19 PM   #30
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Originally Posted by RAPID_BA View Post
3000rpm takeoff slip clutch. should be about as hard as you can go without turning the tyres too much....
Next thing you know the Pope will be giving out tips how to mug people in the street....
CAT600 is offline   Reply With Quote Multi-Quote with this Post
