Old 05-02-2013, 03:52 PM   #1
zac.cartledge
Question Windscreen decal laws?
Hi guys.
Joining a car club and want to put the decal on my windscreen or back window of my ute but want to avoid a yellow sticker at all costs. Just wondering what laws and restrictions there are in regards to front and rear windscreen stickers?
zac.cartledge is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 03:56 PM   #2
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
Default Re: Windscreen decal laws?
you can put/cover your whole back window if you want as a ute is a commercial vehicles and you dont need to see out the back window, that also why you can put darker tint on your rear window if you want to
but if you want to see out your back window just stick it behind the drivers side on your rear window
FG XR8 Ute 2010 Nitro,
Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum
Powerbond 25% under drives, Sports bar,
now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset
total of 285.5 rwkw and 642nm
when Herrod cams in 290rwkw
GSXR 750K7 with goodies, dyno'd 136rwhp,
10.567sec for the strip
comagutsa is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 05:10 PM   #3
XrRabbit
Little Sammy xr6
XrRabbit's Avatar
Front you can only have it right at the top. Is aloud to come down about 7.5-10 cms. Out it on the rear and you will have no problem what size it is
Lets RIDE!
XrRabbit is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 06:10 PM   #4
blueprinted_xr
FPV F6E FG XR8 UTE EL XR6
blueprinted_xr's Avatar
Far as im aware, WA only allows 70mm from the top of the windscreen.
blueprinted_xr is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 06:29 PM   #5
Peter B - CV8
Originally Posted by zac.cartledge View Post
Hi guys.
What state are you in ??? There's probably different legalities for each state.... About time we had a standardised set of rules for this type of stuff.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 06:35 PM   #6
Campo81
Campo81's Avatar
I'm a signwriter and we tend to try stick (no pun intended :p)to 100-125mm high
Campo81 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 07:09 PM   #7
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
A good rule of thumb is stay outside the sweep of the wiper blades on the front.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 09:09 PM   #8
EDManual
EDManual's Avatar
I had the tint guys put a VERY dark front windscreen tint sash. These guys seemed to say you could go down as low as the bottom of your rearview mirror. Which on my car was well below the sweep of the wipers. (Triton ute). Probably 15cm I'd say. Havnt had any probs with anyone about it.
EDManual is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2013, 09:20 PM   #9
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
The older cars had a similar band across the top of the screen that started dark then generally got lighter.. I think dads xa and xf had it?
___________________________
