Old 06-09-2013, 11:40 AM   #1
1TUFFUTE
1TUFFUTE's Avatar
Default Diesel engine oil black in 2 days?...........
Um my friend got his small diesel car serviced and had an issue under the bonnet....so while i checked that for him i checked his engine oil......jet black and it was supposed to have been serviced with oil and filter change only 2 days before. IS THIS Normal. Apparently he rang back and it is....and a dealer he rang said the same thing basically. But 2 days does NOT sound right to me.
Any info would be appreciated....taa
Old 06-09-2013, 11:45 AM   #2
GASWAGON
Default Re: Diesel engine oil black in 2 days?...........
Some diesel engines have a 'bypass' filter that should also be changed when normal filter is changed....The bypass filter holds a small amount of oil and it contributes to making the new oil dirty again if not changed....What sort of car is it? Does it have a bypass filter fitted?
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 11:51 AM   #3
1TUFFUTE
1TUFFUTE's Avatar
It's an 2007 focus 2.0ltr diesel turbo. 90k service. But was 3 k over due.
Old 06-09-2013, 11:55 AM   #4
mac_man_luke
mac_man_luke's Avatar
Could be sludge that was built up from the overdue service. Could be worth doing another oil and filter change.
Diesels do blacken quick but 2 days is pretty quick.
2015 Toyota Landcruiser 79 V8 SC
mac_man_luke is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 11:59 AM   #5
Jason[98.EL]
Jason[98.EL]'s Avatar
check this thread out on piston heads
sound like it is normal for it to do it
I just googled
why is oil black in a diesel
there is plenty of info there
hope that helps
Jason
[SIGPIC][/SIGPIC]
Old 06-09-2013, 12:00 PM   #6
martinijosh
martinijosh's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent guide for headlamp repair.
Sounds like they either forgot to change the oil but still invoiced or forgot to change the filter.
[Moto] Darkness Black - Hornet 900
[Daily] Molten Orange - '14 WZ Fiesta ST - Team Dynamics Pro Race 3 Wheels - Bluefin Stage 1 - Resonator Delete - Stubby Antenna
[Weekender] Winter White - '06 BF XR6 Turbo - 6spd ZF A/M - Leather - D/Zone Climate - BF XR 18's
Headlights don't work in your B Series? Here's how to fix it!
martinijosh is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 12:56 PM   #7
dleach80
GSnBoooooost
It's a diesel it's gonna turn black very quickly, you can never drain the entire amount of oil resulting in old oil sitting in the sump, head, galleries unless you let it drain over night, all there interested in getting your car in and out as quickly as possible.
dleach80 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 01:18 PM   #8
Rodge
Rodge's Avatar
Yeap that's pretty much it. Because it was ovrdue for a service it would have been jet black and the oil ramaining in the engine after allowing it to drain out affects the new oil going in. They blacken up the oil pretty quick, its just how diesel engines are, they don't call them dirty engines for nothing...
The oil in my SC GT-P looks cleaner after 8,000 km's and 12 months than my Euro diesel does after driving it around the block from the dealer after its service.
Rodge is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 01:33 PM   #9
TC200six
As others have said, black oil in diesel engines is normal.
It's impossible to clean out the engine's internals from changing the oil & filter alone and the new oil gets contaminated with what's left of the old oil. As long as you know the oil and filter was changed, you have nothing to worry about.
TC200six is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 01:44 PM   #10
1TUFFUTE
1TUFFUTE's Avatar
I just googled there is plenty of info there
hope that helps
Jason
Thanks that sorts it out....apparently they go black before you get home......weird and goes against everything I'd expect but its safe and true.
Thanks
Old 06-09-2013, 06:07 PM   #11
ILLaViTaR
ILLaViTaR's Avatar
If it's black it's burnt/contaminated and it will cause damage/wear. How is this safe to use over the next 10 000k's?
If it's normal every single motor will have the same problem, and I bet some don't have black oil.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come!
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 06:22 PM   #12
1TUFFUTE
1TUFFUTE's Avatar
that's exactly what I thought and instantly told my friend....."oil goes black from heat and getting burnt over time...plus contaminated"
But apparently in diesel motors its 100% normal because the oil carries particulates or some garbage aswell as lubricating. All sounds stupid to me.....espescially when diesel engines don't rev high hence far less heat....so wheres all the gunk and burning coming from? Ahwell....he inquired...was assured it was re[laced and any engine damage is covered under warsnty by the diesel engine oil companies....weird hey
Old 06-09-2013, 07:06 PM   #13
TC200six
To the above two comments. This is why I believe diesels should have their oil changed much sooner than 15,000ks. But it seems all companies have extended their intervals to that.
Oils in diesel engines contaminate differently due to the different fuel. You see, oil of LPG engines contaminate yellow, petrol motors contaminate brown or black if running rich.
If the Focus uses a cartridge filter, I would say to change the filter before draining the oil, because the filter holds a bit of oil itself, and if you remove the filter after refitting the sump plug, some old oil will run down into the sump. Hope that makes sense.
Old 06-09-2013, 07:16 PM   #14
302 XC
Diesels don't need to rev high to generate heat,they run comp ratios twice,sometimes 3 times that of a petrol engine, then throw some turbo boost in there, and your talking temps hot enuf to melt pistons, and they don't need to rev to do it ...
I know of some older diesels running over 20 : 1 ratio and get fed over 15 + PSI of boost,and don't rev past 4,000 rpm ....
302 XC is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 07:56 PM   #15
chookaradley
You say it was black within 2 days. More often than not they are black within 2 minutes. I've serviced heaps of diesels of all makes and models and found this to be the case. I don't think the colour of the oil nesessarily detracts from the oils ability to protect your engine(in a diesel). I've had more than one occasion where a customer has complained about not having there oil changed when I had done it.
chookaradley is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 08:28 PM   #16
irish2
20:1 comp ratio produces more heat than a quick rev in a petrol...
irish2 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 09:17 PM   #17
GTP-RPD
GTP-RPD
GTP-RPD's Avatar
Yep drive a work diesel captiva and oil goes black within half an hour of driving after an oil change. Perfectly normal I have been told. Seen the new oil go in.
GTP-RPD is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 09:40 PM   #18
GASWAGON
You cannot stop a bit of discolouration from changing the oil.....The new oil will be 100% fine for 10-15,000k's, but after that it HAS to be changed.....I've just had a friend tell me he hasn't serviced his crummydore on gas for 3 yrs.... If thers one thing to do on a car its CHANGE THE BLOODY ENGINE OIL!
Old 06-09-2013, 09:55 PM   #19
SumoDog68
Technology is changing some commonly held concepts - it is possible to have oil do its job for much more than 10-15k.
SumoDog68 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 10:17 PM   #20
martinijosh
Same thing, guy I know with a vz sv6 hasn't changed the oil for 40,000
Old 06-09-2013, 10:22 PM   #21
ebxr8240
Performance moderator
ebxr8240's Avatar
Diesel oil contains much higher detergent percentage .. Although oil is black the engine is clean !!
Make sure the air cleaners are in good nick or it will run rich...
Short trips on diesels require more frequent servicing..
Daily driver GTE FG..
Old 06-09-2013, 11:43 PM   #22
Legit290
Legit290's Avatar
Yeah I used to have a diesel work ute. It freaked me out when I had the oil and filters changed and checked the oil when i got it home and it was black. My mechanic laughed when I hassled him about it.
Perfectly normal
Legit290 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 11:49 PM   #23
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Search for my thread in the Focus section. My oil was black again leaving the dealer after a service.
Normal apparently.
___________________________
Old 06-09-2013, 11:55 PM   #24
Yellow_Festiva
Where to next??
I was close to buying a Punto diesel very cheap so downloaded the manual for UK spec cars and I think oil intervals were something crazy like 30k between changes.
My Focus gets done every 7.5km.
Old 06-09-2013, 11:55 PM   #25
nb_351
building the xe...
nb_351's Avatar
The black is carbon and of a Diesels engine oil is clean it's not doing it's job, blank and runny is perfectly normal even after long intervals
Carbon is a by product of a diesel combustion motor
The trucks I service at work go 30000km between changes, that's the Detroit motors, caterpillar and cummins I do at 20000km intervals
45L still gets mighty dirty after that time but the technology these days in oil is much better than even a decade ago, some truck manufacturers specify 40000km with the correct oil but I think that is too long
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2013, 11:56 PM   #26
b2tf
not here much anymore
b2tf's Avatar
If the oil isn't dirty I would be worried. Oils job is to remove contaminants from the engine (along with everything else it does) - it should be coming out looking filthy.
2024 F150 XLT
Old 06-09-2013, 11:59 PM   #27
burnz
VFII SS UTE
burnz's Avatar
nailed it.
and diesels actually run lean, fuel is added with a full open intake. (no throttle body)
GO SOUTHS
Old 07-09-2013, 12:05 AM   #28
martinijosh
That's once every trip to the supermarket. :p
