Old 14-02-2014, 04:24 PM   #1
AAXR8
AAXR8's Avatar
Default MSD Tach Signal GMR pick up
Has anyone installed a MSD Tach Signal GMR pick up?? I have a 03 BA XR8 that's getting a couple of Gauges Installed and I was told this item was the best to use for your tacho gauge to find a RPM Signal?! Has anyone installed one of these yet?
If so can you tell what there like to install & do they work well so the Aftermarket Auto Meter Tacho can pick up the RPM signal! Thanks any Feedback would be Fantastic!!!!
AAXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2014, 08:25 AM   #2
mash again
Default Re: MSD Tach Signal GMR pick up
I tried to pick up a tach signal using one on an AU 6 from the coil pack and injector signals but couldnt get it to work properly. have a read of this https://ecliptech.com.au/wp-content/...ford_ba_bf.pdf
mash again is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2014, 02:11 AM   #3
AAXR8
AAXR8's Avatar
I wonder if the Auto meter digital shift light could work this way?? Thanks i have saved the information & i will talk to my installer!!! Good on you mate
