Old 09-08-2017, 09:16 PM   #1
notNA
Default DBA or RDA its time..
well its almost time to change my rotors
i have been looking at the DBA rotors but was told apparently the RDA rotors is better value for money (cheaper... sounds like a load of **** to me)
currently looking at this rotor
http://www.supercheapauto.com.au/Pro...07S/SPO2778854
unsure on pads at the moment
any recommendations are welcome
currently have a 2015 xr6 turbo with 4 pot brembos.
notNA is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2017, 09:41 PM   #2
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Default Re: DBA or RDA its time..
DBA > RDA
I've had both and the DBA last longer , they are lighter , they look better.....
These are on my GT at the moment which also has 4 spot front and rear Brembos
http://www.dba.com.au/dba-t3-club-spec-series/
Pads are EBC red stuff which have been an excellent street pad so far.
A bit dusty when bedding in but low dust afterwards with good bite hot or cold.
Complete set up :
DBA T3 club spec rotors all round
EBC red stuff pads all round
braided good ridge brake lines all round with castrol react DOT 4 performance fluid.
Brilliant set up for street use.
Old RIDE
2006 BFGT
Gone but not forgotten
New RIDE
2018 AMG Mercedes A45
Angry AWD assassin
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2017, 09:45 PM   #3
Mechan1k
Mechan1k's Avatar
Depends what your application is as well. I have used RDA slotted rotors for many years. But it's been on work utes and family cars though. Have served me well and have had many many kays use out of them.
agree with Bluey though ... good fluid and a good pad will make a difference as well.
Braided lines give a nice decent pedal feel as well.
I run Project Mu NS400 pads on my vehicles ... as I don't push them. They bite just as good (if not better) as the Ferodo DSP's but with no dust.
Oh ... check out Race Brakes on here ... Matt looks after all forum members of brakes and is well priced and delivers to your door as well ... or if in Western Sydney area ... you can drop in to pick it up and have a chat as well
Old 09-08-2017, 09:55 PM   #4
notNA
just daily driver, no track yet but i do need the stopping power cause of idiots on the M4 every day..
doing 100kmph and then they decides to slam the breaks cause they weren't paying attention.
and yes i'm in western Sydney.
Old 09-08-2017, 10:03 PM   #5
Mechan1k
Mechan1k's Avatar
I hate that as well. Even leaving earlier to try and beat the traffic. M4 blows.
Race Brakes are in Wetherill Park
Old 09-08-2017, 10:11 PM   #6
notNA
looks like ill be paying race breaks a visit
even cheaper then what i was quoted from other places and not even going to bother with RDA
just need to figure out what pads now
Old 09-08-2017, 10:12 PM   #7
Mechan1k
Mechan1k's Avatar
Matt will have a range of options for your sizing/application when it comes to pads.
Old 10-08-2017, 12:13 AM   #8
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Is it wrong that I just pictured the ladies products section of the supermarket when I read this..
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2017, 12:14 AM   #9
Mechan1k
Mechan1k's Avatar
LOL .... as long as they prevent "accidents" in public ... it's all good
Old 10-08-2017, 12:17 AM   #10
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
I'm running DBA T2's and Libra Fleur..
Old 10-08-2017, 12:20 AM   #11
Mechan1k
Mechan1k's Avatar
Some pads are best suited to heavier usage/applications.
Old 10-08-2017, 06:06 AM   #12
FTE-063
FTE-063's Avatar
I'm running DBA T3 in front & DBA T2 in the rear along with Project Mu NS400 pads all round on my AU XR8 sedan
it's best brakes for street use I've had, and I had a few brake combinations over the years
cheers Dean
FTE-063 is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2017, 07:51 AM   #13
cheap
Wirlankarra yanama
cheap's Avatar
RDA are useful as doorstops.
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2017, 07:55 AM   #14
Mechan1k
Mechan1k's Avatar
Never had an issue with them. They do the required job perfectly fine.
Comes down to your application.
They are a lot better than the standard factory offerings.
Old 10-08-2017, 07:57 AM   #15
notNA
ill agree with that after the research i have done so far
Old 10-08-2017, 08:05 AM   #16
josh1990
Have RDA on the Turdrolla - go rusty all over in the slightest humidity.
DBA on the ute - No rust (except when I get the actual braking surface wet, nowhere else like rda).
That's enough for me, without taking into account the DBA's superior kangaroo paw venting, build quality etc.
2017 Ranger XLT 3.2L Hi-rider
josh1990 is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2017, 09:02 AM   #17
cheap
Wirlankarra yanama
cheap's Avatar
RDA (Rotors Drums Australia) don't let the name confuse you. RDA are simply a distributor of overseas manufactured stuff, probably mostly made in China.
DBA (Disk Brakes Australia) designed and manufactured in Australia.
Old 10-08-2017, 09:27 AM   #18
notNA
think we need to educate spare parts stores, they have it the other way around..
well the 2 i called so far
Old 10-08-2017, 11:13 AM   #19
JC
JC's Avatar
You might also look at ADB - I use them on my GT for street application only, and at the drags, and can't feel any difference to the brembos. They weigh the same as the brembo discs and have served me well for the past 12 months or so. They are cheaper than RDA/DBA, but if all you want them for is street duties, then they are all you need (IMHO).
Ford Performance Club ACT
Old 10-08-2017, 11:14 AM   #20
ozrunner
A few years ago I needed some discs asap and DBA's weren't readily available so I brought some RDA's.
But upon unpacking the machining was obviously not up to the same standard as DBA's which was then confirmed after fitting as the front wheels wouldn't stop wobbling.
I put one on the rear and with the vehicle on stands ran it in gear. They had so much side run out it wasn't funny.
Cut my losses and waited for some DBA's to arrive and the junk RDA's are at rest somewhere in the local tip.
ozrunner is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2017, 11:17 AM   #21
JC
JC's Avatar
DBA also made in China - don't let the rep fool you.
Old 10-08-2017, 12:39 PM   #22
notNA
yes but by what iv been seeing in my research the RDA has a lot more quality issues in the long run.
i would rather pay extra and have something decent and long lasting.
i was also considering the t5 series until i saw the price
Old 10-08-2017, 02:26 PM   #23
Never had any issues with DBA T2's on both the BA XR6 and FG... Highly recommended. Performance will also depend a lot on your choice of pads to match.
Old 10-08-2017, 02:53 PM   #24
notNA
yeah have no idea on pads at the moment.
still researching, looking at red stuff at the moment.
Old 10-08-2017, 03:39 PM   #25
cheap
Wirlankarra yanama
cheap's Avatar
I've have good results with DBA T3's and QFM brake pads.
Old 10-08-2017, 10:15 PM   #26
FG50T
FG50T's Avatar
I believe it's the RDA that are made in Aus and DBA are made in China. I think where the metal used in it is from is the technicality.
Both discs are great. My Brembo discs rust up worse than any of the two above. My RDA's peform flawlessly. The only flaw I see in them is that they are easily identifiable just as the DBA's are and people don't want to look 'cheap'. Fact is I see loads of cars every day running RDA rotors, all are fine and they all do the job better than stock rotors.
FG50T is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2017, 11:21 PM   #27
cheap
Wirlankarra yanama
cheap's Avatar
RDA website: http://www.rdabrakes.com.au/page/about.aspx
DBA website: http://www.dba.com.au/about/
In response to which company is a importer/distributor of rotors and which company manufactures rotors in Australia, it couldn't be much clearer.
Old 11-08-2017, 10:57 AM   #28
JC
JC's Avatar
Not quite clear cut - On the DBA home page (bottom left), it says:
ABOUT DBA
Disk Brakes AustraliaDisc Brakes Australia is an Australian owned, international manufacturer, designer and global marketer of after-market and OE disc brake rotors and brake pads.
While they used to manufacture solely in Oz, they now do some in China too - they have to to stay price competitive.
Old 11-08-2017, 11:11 AM   #29
josh1990
Everything's made in China* these days. Are we surprised?
*except for babies, they're made in Va-China
Old 11-08-2017, 11:11 AM   #30
ute83
I believe the only rotors made here are the dba 4000 series. Everything else comes from china.
ute83 is offline   Reply With Quote Multi-Quote with this Post
