Old 28-01-2023, 09:48 AM   #1
malbaby
Default Are alloy fuel lines "Engineer" approved.
Intending to run alloy fuel lines underfloor of a car that requires Engineer Certification....OK to use??
malbaby is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2023, 10:24 AM   #2
39ClevoUte
39ClevoUte's Avatar
Default Re: Are alloy fuel lines "Engineer" approved.
I always engauge my engineer at the start of a build. That way they don't mind answering questions along the way. It also gives them a heads up on what you have done and results in no surprises for either of you at the end.
Many engineers have personal preferences. Some enforce their preferences and others will approve anything that is approved/legal, but not necessarily their preference.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2023, 08:29 AM   #3
malbaby
So using alloy without Engineer approval may be risky??
For absolute certainty, I should use copper or bundy?
Old 29-01-2023, 09:55 AM   #4
39ClevoUte
39ClevoUte's Avatar
I don't know mate, have a read through this
https://www.infrastructure.gov.au/si...Jan2011_v2.pdf
If your getting the car engineered, I'd ask one.
Old 29-01-2023, 12:21 PM   #5
Itsme
Itsme's Avatar
I cannot see any reason why alloy tubing would not be suitable for fuel lines since a lot of modern vehicles now use plastic fuel lines.
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 29-01-2023, 12:52 PM   #6
mad2
Regular...with metamusal
and have since back in the 70's
mad2 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2023, 07:46 AM   #7
malbaby
Thanks guys....very helpful.
Old 30-01-2023, 04:42 PM   #8
XRtowcar
Mustang GT mmmmmm......
XRtowcar's Avatar
You could try stainless steel tube.
I have become a Mustanger.
XRtowcar is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2023, 04:40 PM   #9
Dr Terry
It depends on the type of fuel to be used.
If you're using E85 don't use alloy, it corrodes, use steel bundy or plastic. You can use stainless but it is very hard to work e.g. flaring etc.
I'm not sure but I don't think that copper tubing is permitted for automotive use. It fatigues & cracks much too easily.
Dr Terry
Dr Terry is online now   Reply With Quote Multi-Quote with this Post
