Old 07-10-2005, 10:42 PM   #1
stiddy
stiddy's Avatar
Default Differences.. old vs new
hey peeps..
talking to a guy on msn that knows everything about everything..
and i basically wanted to know the differnces between an Eb to Au 6 vs the BA 6..
apart from the twin cam and stuff like that.. whats the other differences..
and are parts interchangeable or identical from each model..
one thing hes 100% set on is that the EF-EL intake and exhaust manifolds will bolt onto the BA non turbo 6's, and the manifolds are exactly the same, eg same part number etc etc..
and hes also saying that putting a BA 6 into antyhing from Ea to Au isnt that difficult :
thanks
Matt
Old 07-10-2005, 10:55 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
thanks
Matt
Of course it's not difficult. You can put BA parts into the boot anytime
If he's so good ask him why aint he in here ed-u-kate'n us lot then?
Old 07-10-2005, 10:55 PM   #3
Casper
Contributing Member
Casper's Avatar
hey peeps..
thanks
Matt
He's an idiot. The EA-AU extractors will NOT fit a BA. In fact, between AU to BA there is close to nothing in the engine that is interchangable of any significance to power.
As for dropping a BA motor into an EA-AU.. sure, it will fit, but good luck messing with the computer to get it working. AU's have EECV, BA's have a COMPLETEY different ECU setup.
Older, wiser, poorer.
Old 07-10-2005, 11:01 PM   #4
b2tf
not here much anymore
b2tf's Avatar
Gotta love the MSN Mechanics!
2024 F150 XLT
Old 07-10-2005, 11:02 PM   #5
stiddy
stiddy's Avatar
what about inlet manifolds?
Old 07-10-2005, 11:06 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
the ports are a different shape.
if u want a BA style intake manifold, use an EF/EL one.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 08-10-2005, 07:05 AM   #7
Mike Gayner
Mike Gayner's Avatar
Surely swapping a BA 6 into an EA with computer and all wouldn't be an overly difficult proposition.
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2005, 10:39 AM   #8
Fairlane
V8 Powaah
Fairlane's Avatar
BA ECu wont work in an E series unless you justa about wire everything up including stuff like Radio's, Keyelss Immobilisation, it's a big pain in the butt. You could always run an aftermarket ECU, but generally its too much trouble.
The BA is a very different from the EA 3.9
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2005, 10:59 AM   #9
Bossxr8
Peter Car
Bossxr8's Avatar
hey peeps..
thanks
Matt
Between AU and BA the only parts that are interchangable would be the oil filter, a few of the bolt on sensors such as knock and cylinder head temp. and the injectors. Not many internal parts are interchangable bar the conrods but they do have an oil squirter on the BA. The ports are an oval shape on the BA and are round on the AU so they can't be swapped even though they are basically the same design bar the manifold mounting face.
