Old 05-12-2005, 11:44 PM   #1
matey
Default Roller rockers yes no?
I was just wondering if any one could fill me in on the pros and cons of roller rockers seeing they cost quite a lot what are the benifits are they easy to set up i have a 302 cleveland thanks :baby bott
Old 06-12-2005, 12:25 AM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
They ROLL across valve tip [roller bearing] instead of sliding.Cuts down valve guide wear ..
Often fitted to improve lift as well, though 302 C's have 1:72 ratio..The falcram point on good rockers are roller bearing as well and should hardly wear..They are much more rigid and don't flex like pressed steel rockers..The stud mount type need pushrod guids and hardened pushrods ...
Daily driver GTE FG..
Old 06-12-2005, 12:39 AM   #3
Kieron
Unless your going for serious revs/power (and with a 302C, its safe to assume your not) then they are a waste of money.
Basically, roller rockers reduce friction in the drivetrain, typically they can be of stamped steel design with a roller tip/friction mount or alloy with roller tip/needle bearing mount.
A few Benefits -
A roller rocker rolls across the top of the valve, pushing the valve down squarely as opposed to the stock friction tip which 'wipes' across the valve tip causing the valve stem to be pushed against the valve guide creating friction and wear.
The alloy roller rockers are far stronger than stock rockers, so are capable of withstanding high revs.
If it has a needle bearing mount, there is again a reduction in friction, less friction = more power/less heat.
Kieron is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 02:28 AM   #4
Blue Oval Mopar Man
Has Blue Blood
Blue Oval Mopar Man's Avatar
It just so happens I have a set of 1.6 ratio Windsor roller rockers if anyone is interested ! I also have cleveland 1.73 ratio , but I have plans to use them soon !
Poller rockers are probly a waste of money on a near stock engine , but if you start putting in high lift cams and heavy valve springs they are worth the expense !
Real cars dont wear bowties
I'm not arrogent , Just superior
Blue Oval Mopar Man is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 03:32 AM   #5
Grechie
Grechie's Avatar
my friend said he'll blow all of us away wen he gets roller rockers in his VS V6 ?would they give that much of a power increase
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 06:59 AM   #6
thunderoo
Blueprint of Perfection
thunderoo's Avatar
LOL ..... The VS V6 Commodore already has roller type rockers fitted from factory.....hehehe im not kidding...i play with them everyday at work !!! hahaha sorry im almost in tears hearing that comment. :
HIS
426 RWHP / 1100 NM OF TORQUE 393 CLEVELAND
AFD 2V CYLINDER HEADS
1974 XB COUPE
NO TRACTION AT EASTERN CREEK
HERS
BOSS 260 03 XR8 SEDAN
COLD AIR INTAKE BY PERFORMER SHAKERS
FULL X-FORCE QUAD TIPPED EXHAUST SYSTEM
thunderoo is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 07:45 AM   #7
LTDHO
The one and only
LTDHO's Avatar
Without a doubt a great modification.
Even on a stock 302.
Although more suited for hi po motors, it will reduce the wear of a stock motor.
Tuned by CVE Performance
Old 06-12-2005, 09:24 AM   #8
fatxagt
fatxagt's Avatar
Needless to say really but they look horn when ya take ya rocker covers off.
fatxagt is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 10:03 AM   #9
matey
thanks a lot i dont think i will be buyin them :
Old 06-12-2005, 11:09 AM   #10
ebxr8240
ebxr8240's Avatar
He'd be fitting higher ratio rockers...Or wasting time and money if not....
Old 06-12-2005, 02:39 PM   #11
fatxagt
fatxagt's Avatar
Maybe spend ya money on manifold carb set up, or extractors. that will give ya a bit more power. What car is it in?
Old 06-12-2005, 04:36 PM   #12
matey
Wink
i did that allready extractors edelbrock manifold holly 600 and i just had a 2and half inch exhuast fitted its going quite well :
Old 06-12-2005, 04:50 PM   #13
Grechie
Grechie's Avatar
thankx guys ill roll him now
KPM Street Fighter
PCMTec
