Old 31-01-2006, 06:23 AM   #1
mike
Default 2007 ford expedition
nice article
expedition looks great inside and outside , has a lot of potential for a suv, check the article, there is a small clip there
Old 31-01-2006, 06:13 PM   #2
chief
FTF Club Moderator
chief's Avatar
They say it uses a "Triton", Single Cam, 3 Valve 5.4L V8. Is that what we call our Boss motor?
Also curb weight at 9100 lbs. ie just over 4 tonne. A bit heavy. Or is that a typo and that is how much it can tow?
An extra 130 cubic feet of cargo space. Are you taking the whole house in the car?
Albert Einstein:
Fords in the Park 2010
Old 31-01-2006, 06:30 PM   #3
ImpulseTaco
n00b
ImpulseTaco's Avatar
"Triton" is what the modular engines have been called in pickups/SUVs over here since their introduction way back in 97. The actual name "Trition" has something to do with a cooling system failsafe, where if the engine coolant runs dry, the engine will continue running, then run with reduced power and shut off the A/C, then stop some cylinders from firing to act as air pumps, and finally shut the engine down to prevent permanent damage.
From what I have read, the 3 valve engines, regardless of moniker on them were tested in Oz first, then made it to production. The current model F150 has a 3 valver, as does the Mustangs. I'd be willing to lay money that the electronic throttle system on the new mustangs was first used on the BA's.
Jordon
'03 Tacoma 4x4
ImpulseTaco is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 06:34 PM   #4
LUXO_8
windsor user
the boss is the quad cammer, so no. i'd say its the 3V as used in falcons fairmont ghias and lwb cars
that'd have to be a typo, theres no way it'd weigh 4 tonnes!!
Old 31-01-2006, 08:25 PM   #5
AnthonyQLD
Boss power
AnthonyQLD's Avatar
I would have to say that its not 4 tonnes, no way it would weigh that much. But its not a bad looking SUV will we see them in Australia? replace the explorer
AnthonyQLD is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 08:29 PM   #6
LUXO_8
windsor user
definatley not an explorer replacement, they're longer than the suburban......and are based on the F350
Old 31-01-2006, 09:01 PM   #7
Transit Truck
Transit Truck's Avatar
I believe you are mistaking it for an Excursion... which is based on the F250/350. They no longer make Excursion's and alot of speculation is on a new longer based Expedition which will replace the older Excursion.
Transit Truck is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 09:11 PM   #8
LUXO_8
windsor user
of course, i was trying to think of the name and thought it was the expedition......
what size is the expedition, looks to be a fair whack bigger than the explorer by that pic.....
Old 31-01-2006, 09:47 PM   #9
chevypower
chevypower's Avatar
Expedition is F150 based, and about the same size as the Landcruiser 100 (but better on road) - 9100lbs might be the towing capacity. - Vehicle weight would be around 2.5 tonnes. the Boss motor is the same engine, just with the Lincoln Navigator heads (4 valve)
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 10:24 PM   #10
csv8
csv8's Avatar
In America, Ford SUV's go, Explorer, Excursion, Expedition. Sizewise. Then you have the Lincoln versions. Lincoln Blackwood is awesome !!!
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 12:46 AM   #11
ebxr8240
Performance moderator
ebxr8240's Avatar
Read for yourselves...
http://www.fordvehicles.com/suvs/
http://www.fordvehicles.com/suvs/expedition/
Daily driver GTE FG..
