Guy that posts stuff
Heres a bit of crystal balling.
The new I6 won't be made out of regular cast iron, or aluminium but compacted graphite iron.This material is approximately 1.5 to 2 times stronger, allowing stronger engines to be constructed with less material (thinner walls), hence saving weight of the order of 50kg. This technology is currently used on several jaguar desiel engines and in the Falcon RTV (rear shock mounting plates). CGI does not require all new processes, however slower feed rates and better tools are required. Stronger construction will also improve NVH. It also allows the possibility of a Diesel I6 varient. CGI weight benifits are comparible to Aluminium and other alloys. It would be far easier and cheaper to incorperate it into the existing falcon manufacturing program. CGI should also get a look in on Falcon suspension components (wishbones etc), improving strength, weight and NVH. It is quite likely the I6 will shrink in capacity to around 3.5L. For several reasons: -Economy, smaller engine, less friction, lighter internals, improved economy -More compact dimentions, improved pedistrian safety by lowering the engine, also improves handling, cooling, NVH,lower weight. It will most likely have a shorter stroke -Power, currently at 190/245kw, with over 200kw easily obtainable. With the smaller engine these outputs can still be met but with a smaller and lighter engine. A 4.0L may continue in uppermarket and performance cars, but require Jaguar like explosive bonnet pedestrian systems which is not viable for entry level vechicals (expensive to build, expensive to replace). New technologies. Direct injection will most likely be required by ever furthering emission laws and fuel economy targets. It should also help in low end performance and in turbo charged applications. EURO IV emissions are expected to be required by about 2008-2010. Athough it is possible to meet it without direct injection, the fuel economy benifits alone are worthy for the technology. This technology will most likely appear on premium or Sport versions with the 4.0L engine. Injected LPG. LPG will still remain competitive with a more efficent injected LPG system, improving range and performance. However the tank maybe reduced in size to allow more efficent packaging. |
Shoot.
It sounds ideal... Finally matching capacity and efficiency to Japanese and Euro engines. But how soon will this sort of thing come into mainstream Falcons, if ever?
20V Turbo |
#3 | |||
Burnin Rubber
Use of carbon is becoming more common in the world. No suprise that this will be the future. Good article.
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
DJR TM#54
Sound good & one could only hope that it would go ahead, but what would it cost to make the change to use these materials.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains ![]() |
Your are missing one important material - plastic!
FF |
The Guy You Love To Hate
Whats explosive bonnet pedestrian system?
4L would be better, one of the things that makes it stand out from the rest.... 3.5 ?- well then it will be the same as any other car - hope they make a 4L CGI inline 6 standard across the range. Seriously if it's already getting 10.2L per 100, a 3.5 version isnt going to get much better, it's time to look at biofuels as a long term solution, and stop trying to do short term solutions like save 1L per 100km and make it ethanol compatible and still have the power and torque.
XR5T - Sea Grey.
I like that article a lot, but I'd have to say keep it 4 litres, but with 2 power ratings (Spec1: XT/Futura, Spec2: Fairmont/Ghia), with XR6 to use the Spec2 engine with sportier gearing etc.
My opinion on sticking with a 4 litre engine at all cost is purely an emotive one. FAU is the '4 litre family car' company. 3.5 just doesnt feel Aussie. I dont even care what the Red team have under their bonnets 6 pot wise, I want my Falcon 6's to be 4 litres no matter what decade I buy it in. The chance of new tech allowing for stronger engines and therefore diesel one is exciting. If the inline 6 can be modified for LHD markets, look out Europe, because that would be the next frontier, not the USA. Once again, what a great article. |
me may my mo
I reckon it'l be all-aluminium, mainly because Ford US' new 3.5 V6, now officially rated at 265hp (197kw), has an aluminium block....i think this will pass on to Ford OZ, i.e. the material for the block.
Paint Repairs Spoilers
What happened to the Joint venture that Ford were doing with the Magnesium Boys????
Tyre smoke - nah must be smoke from the running in oil / Sorry officer, just put some tyre shine, did not think it would do that. Unfit - How could I be, always running off at the mouth and jumping to conclusions |
#11 | |||
Force Fed Fords
Good question, in my days at Ford, aluminium casting, Magnesium was all the talk, plus their investments up in Qld etc.......
2021 Focus ST-3 Mountune Enhanced |
#12 | ||
Sounds like more crap.
#13 | ||||
Burnin Rubber
#14 | |||
me may my mo
On a side note, as stated, the 3.5 will produce 197kw and 340nm using regular 87 octane fuel!, the hi-po alloytec needs premium, i think, to get its 190kw and 340nm... even though its got 100cc more to play with... good on ya ford!!! |
#15 | |||
Peter Car
#16 | |||
...fairly odd
so if hes way off the mark how about you tell us what they are gonna do.
1992 EB Falcon 5.0 V8. mods; dust, dirt, cobwebs, scratches, trolley dents, dented bonnet, gutter scrapes, rattly exhaust, and floor mats.
#17 | ||
I.B.S is a pain in d'***
Wow, coming soon to the all new platform Falcon........... Carbon Graphite twin cam direct injection V-Tec! Available in with Turbo with the XR6T
I DONT BELIEVE IN NOS.............but if its given to you free at the hospital well then ![]() |
#18 | |||
Peter Car
#19 | ||
Viper FG XR6 Turbo
i dont understand this thread, is this information you have proof of? or are you just stating your wish list? cos it defenitaly sounds like crap to me.
what is with all these useless threads poping up with peoples, made up theorys of where ford will be in the next couple of years? |
#20 | ||
Some people above know something about upcoming engines but are unable to provide the full details so to protect themselves and the Ford motor company.
FF |
#21 | ||
Gee'z I hope Ford Oz doesn't do this.....for our sake. I'll sacrifice a few extra kilos for a tried and proven cast iron block any day.
While aluminium may be better in theory, as it's tensile/toughness: weight ratios is better than steel, US/Oz car-makers have never had the brains to apply it properly in practice. So now we are faced with "graphite iron"?? Graphite is the main carbon type found in the "Grey Cast Iron" and "Meehanite Cast Iron" in present Falcon iron block engines!! ![]() It seems that marketing departments love using these words, as the average bloke has no idea what "graphite iron" means. A bit like people who continually market parts as "billet" parts................ |
#22 | |||
#23 | |||
#24 | |||
Burnin Rubber
Still not as bad as ECOTEC.
#25 | ||
Cobblers!
The Info that I have gathered is that Geelong would need a serious investment to get it to produce a V6. That means that we will see an I6 for as long as Ford is in Australia, mainly due to the tight monetary status of Ford USA. I also see a 4.0 Litre. Only because the engine has always been like that. It has been just above - 4.1, or just below - 3.3, and again, the 4 Litre is seen as the Falcon motor. It is one of the only remaining Straight 6 Engines in the world, with only BMW making an I6 now (Mercedes went to a V6). There is a lot of history in the Falcon engine.
Martyvan, I have Rifle Shafts, which are a Steel Shaft. My Only Graphites are a Taylor Made R5, and a Calaway Big Bertha.
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
#26 | ||||
...fairly odd
#27 | |||
Cobblers!
#28 | ||
hmm eyebrows
Another nostradamus prediction.
XE 4.9 Falcon S & XA 4.9 Fairmont hardtop |
#29 | ||
Viper FG XR6 Turbo
why would we want a V6, the only advantage a v6 has, is that its more compact (for smaller cars and for importing) and can be used for FWD, none of which advantages the consumer of a falcon
