Old 06-05-2006, 02:17 PM   #1
act2617
Talking New Bentley - 411kW/650Nm 4 WD
http://www.theaustralian.news.com.au...-13232,00.html
act2617 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2006, 02:20 PM   #2
Polyal
The 'Stihl' Man
Polyal's Avatar
OK this might seem rude but whatever and no one answered this question before, but is act2617 an AutoBot?
  • 1973 ZF Ford Fairlane
Old 06-05-2006, 02:27 PM   #3
Casper
Contributing Member
Casper's Avatar
Nope. Real person.
Older, wiser, poorer.
Old 06-05-2006, 02:39 PM   #4
Wokkas
The "Bently Continental Flying Spur". Do you reckon they could have picked a more ridiculous name?
0-100 in 5.2 seconds for a car that weighs nearly 2.5 tonnes. Not bad!
You'd hardly call it a "drivers" car though.
Wokkas is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2006, 03:18 PM   #5
AnthonyQLD
Boss power
AnthonyQLD's Avatar
And at only $353,000 Ill take 2 lol
:the_finge BOSS 260+ :the_finge
AnthonyQLD is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2006, 03:32 PM   #6
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
anyone got links to these w12 engine's ? do they have 2 crankshafts?
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2006, 03:39 PM   #7
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
The W12 engine is made up of two very thin V6 four-valve modules which are configured at an angle of 72 degrees with a joint crankshaft with seven main bearings to make up a V-V arrangement, i.e. a W. The cylinder angle is just 15 degrees Within the two V6 banks. This makes the construction, which is very compact in comparison to V12 engines, possible.
http://www.ultimatecarpage.com/frame...hp&carnum=1077
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2006, 03:44 PM   #8
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
i found this, still cant understand how the things work, the cylinder head looks like it needed some designing.
http://images.google.com.au/imgres?i...lr%3D%26sa%3DG
Old 06-05-2006, 08:12 PM   #9
Falcon Coupe
Clevo Mafia Inc.
You ain't Robinson Cruseo there mate.
Old 07-05-2006, 07:48 AM   #10
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
It is named after models in the 1950s, as well as the original Continental coupe there was one coachbuilder that did a 4 door version called the Flying Spur. Back then you had a choice of about 4-5 different body styles.
Old 07-05-2006, 09:14 PM   #11
LethalLeigh
Get in the van!
LethalLeigh's Avatar
A W motor is effectively two V motors sharing the one crank. The difference is that the centre valley has a high spacing (I think 72deg on the Veyron) and the two Vs have small enough spacings such that they share the same heads which is why it looks like a squashed inline 6 cylinder in this previous image. The benefits (ignoring complexity) is a smaller engine length so you get a W12 for the space of say a V8 or V10.
VW have used simliar concepts on a smaller scale with their V5 motor and a more recent V6 used in the Golf R32 which had a V separation of just 15deg.
The Dad Bus (TM): 2004 BA XT Wagon, soon to be set up as a camper and tourer.
LethalLeigh is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 03:51 PM   #12
turboute
turboute
The other aceivement that volkswagon di when they made these engines was the fact they did it with only two comshafts per bank- the lever system they use to make the valves on the opposite side of the head open is very complex - esp in the fact that they can sustain decent rpm without valve bounce/float.
turboute is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 05:02 PM   #13
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
Although the W engines are compact in length, they are still hung way out front (well past the front axle line) in normal VW/Audi tradition. Have a look at a Bentley (or an Audi V10 S8) for that matter and you will be staggered how far forward they are mounted. The designers have done a very good job of disguising this.
The next time you are in a Bentley dealership (or the motorshow) have a look for yourself and you’ll see what I mean.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 05:31 PM   #14
LethalLeigh
Get in the van!
That's allegedy because Audi try to maximise interior space without changing the overall length. Just makes their cars understeer like mad despite quattro drivetrains.
Old 08-05-2006, 11:34 PM   #15
outback_ute
Ute Forum Moderator
Contributing Member
turboute - lever system aka "rockers" like a lot of cars...
Audis have a longitudinally mounted engine and front wheel drive (the all wheel drive models are the same layout), the diff is behind the engine (and clutch until recently), so the driveshafts are behind the engine. On the current A8 they have moved the wheels forward, not sure on the detail of how this was done though.
