Old 13-07-2006, 08:41 PM   #1
AUIIIXR8
Formerly AU2XLSV8
AUIIIXR8's Avatar
Rough guesses:
Assuming it's a 6 120-160rwkw
Assuming it's an 8 130-170rwkw
If it's an 8 your heads will hold you back.
Wrong section to ask mate
Current ride = Mazda 6 MPS
Toy = AU2XLSV8 - another one
(really my best mates but I'm claiming it)
Past
EL 6 S/C - sold
AUII XLS V8 Stroker - sold
99' Laser (runabout) - sold
BA Fairmont - sold
AU III XR8 220 - sold (so should have kept this one)
AU III XLS Tickford 6 - sold
Formerly AU2XLSV8
AUIIIXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2006, 08:41 PM   #2
351ciofgrunt
Go Hard or Go Home
Originally Posted by Blake_7
im buying a eb f/mont ghia.. has the following mods
exhaust
extractors
cam
pod
chip
wat sorta power ball park would that produce...
would need more info than that...as in exhaust? describe it
cam? we all got cams... what are your specs?
351ciofgrunt is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2006, 08:54 PM   #3
351ciofgrunt
Go Hard or Go Home
With buying an EB falcon always make sure its a series 2, these were built after april 1992
the series 2 has the 4.0litre that has alot more power than the series 1 which had the 3.9litre
if its the series II 4.0litre and you like the way it goes, then i say buy it...
power might be around 160-170kw, if its the series II 4.0litre
Old 13-07-2006, 11:41 PM   #4
charles_wif_xf
Purveyor of filth
Go get a dyno run and stop guessing. It will cost you $80 at most places that have 'em.
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 12:25 AM   #5
XRated
Shoot.
XRated's Avatar
There isn't much difference power-wise between the 3.9L MPFi and the 4.0LMPFi. I'd be tipping between 130 and 145 with the mods listed and depending on the cam. Manual certainly makes the ol' E-Series fly, and with a shorter diff it should really hammer off the line!
20V Turbo
Old 14-07-2006, 05:58 AM   #6
hrtrip
I Hope Holden Dies
hrtrip's Avatar
buy it - i wish i had a manual
HRT R.I.P
Icon Blue BFII Fairmont
Stock as a rock... :(
hrtrip is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 06:16 AM   #7
351ciofgrunt
Go Hard or Go Home
There is a big difference between the 3.9 and the 4.0...
six cylinder engines available for the EB:
3.9 120kw
3.9 139kw
4.0 148kw (series II)
4.0 161kw (series II XR6)
assuming its a 4.0 litre then with the mods described you should be at least at the XR6 level of output of 161kw
make sure its a series II!!
Old 14-07-2006, 12:13 PM   #8
XRated
Shoot.
XRated's Avatar
3.9 120kw
3.9 139kw
Umm, no, there isn't.
The 3.9L with 120kw you refer to is only in CFi EAs and EBs. However, there was an option to have MPFi on both models (standard on Ghias) that boosted power to 139kws. Obviously the EBII and ED did not get CFi (thank God!) and came standard with 148kw (slightly different bore to the 3.9L). The 9kw difference is not much considering that the car is a bit lighter than later model EBs and EDs.
20V Turbo
Old 14-07-2006, 12:20 PM   #9
351ciofgrunt
Go Hard or Go Home
so do you have a problem with me advising to make sure its a 4.0 litre? 9 kw would still be noticeable...
why are you so defensive about the 3.9?
