Old 10-09-2007, 07:22 PM   #1
Armageddon Designs
Automotive Graphic artist
Armageddon Designs's Avatar
Default When CATS go bad!
We had one of the engines in one of our Cat 793C Haul Trucks go bang a few days back, got some pics of the remains, thought you guys might like them! There was a crack running the full lenght of the left side of the block. The pics are only off my phone so they don't do it justice!!! LOL
The Devil is in the Detail!
: ARMAGEDDON DESIGNS - NEW SITE NOW ONLINE :
Armageddon Designs is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 07:23 PM   #2
GK351
GK351's Avatar
geez that spat the dummy pretty nicely.
How many km's did you get out of it?
GK351 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 07:28 PM   #3
dave351cid
playing in my big shed
dave351cid's Avatar
looks very expensive $$$$$$$$$$$$$$$$$$$$$$$
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 07:30 PM   #4
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Holy crap. Thats nasty.
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 07:39 PM   #5
fou_bleu
Get EcoBoosted
fou_bleu's Avatar
O.u.c.h!
fou_bleu is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 07:43 PM   #6
Armageddon Designs
The life of these engines isn't messured in K's, all done in Hours, but saying that not sure, I just saw it out in the yard waiting to be picked up and sent back to Westrac. I probably should have mentioned that it is a Quad Turbo V16 out of one of these!
All I can say is I'm glad I don't pay the bills for rebuilds!!! LOL!!!
Old 10-09-2007, 07:50 PM   #7
Lukeyson
Right out sideways
Lukeyson's Avatar
thats crazy
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 08:40 PM   #8
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
That's another 'leg out of bed'
Would have been a nice bang!
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 12:35 AM   #9
cowboy
Cowboy
cowboy's Avatar
What mine do you work at mate? Ever see the video of a haul truck running over a landcruiser? Awesome.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1930 Pontiac Landaulet
1932 Pontiac V8 sedan
1935 Pontiac sedan
1937 Pontiac 8 sedan
1948 Pontiac silver streak
1949 Ford F3 pickup
1953 Pontiac Chieftain
1955 Austin Champ
1957 Dodge Power Wagon
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
cowboy is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 08:12 AM   #10
Armageddon Designs
Yeah seen that, makes you stop and think for a minute!!! LOL
I work at Newcrest's Cadia Valley Operation, just outside of Orange.
Old 11-09-2007, 08:47 AM   #11
J.C.
Generally, as mentioned previously, these are measured in running/machine hours. The life of an engine should be anywhere between 14500-17500hrs. Around this time time period is the most economical time for rebuild and by this stage the engine is starting to become sad anyway with blowby reaching the high side of the margin and cylinder heads leaking oil from under the spacer plate gasket.
The component hrs or the life of the component (engine) is also determined by fuel burn. The more fuel it burns during its life span, the more load, which in turn means more wear and component stress so the rebuild time comes around sooner so to speak ..... by rights. At least that's what Caterpillar are working on nowadays. So engine life can extend beyond the previously stated hrs.
The 793C came out with two engine arrangements. One is a 69L, V16 with four water cooled turbos in compound configuration (two high, two low pressure), water jacket aftercooled.
The other is a stroked version, high displacement, 72L, V16 with four water cooled turbos (non compound, two per bank), water jacket aftercooled. Both engine arrangements have SCAC (separate circuit aftercooling). Which basically means that the aftercooler circuit water has its own water pump, radiator (which is incorporated into the main radiator frame using the same cores as the engine jacket water to make up the full radiator arrangement at the front). The engine and aftercooler coolants do meet at the very top of the header tanks though. Top engine rpm is 1950, although have seen event histograms of 2400>. Continuous overspeeds during its life ends in something similiar to the above pics and premature failures.
These vehicles have a payload of approximately 220T, a top speed of 54-56kph, the trans are fully automatic with lockup in every gear except first (which is convertor drive then changes into lock up at a predetermined speed) and are stopped by the uses of wet (oil cooled), multi disc brakes.
There you have it. Some more useless trivia for AFF members.
Oh yeah! They also have traction control (which is disabled above a factory preset ground speed ....) and auto retard to try and limit engine overspeeds (I'm guessing that it wasn't working on this one or the operator was heading down the ramp flat with his foot on the gas just once to often..... hence the auto retard will not operate).
J.C. is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 08:53 AM   #12
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
No replacement for displacement.......................
Do ships have a similar engine lifespan?
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 08:54 AM   #13
cowboy
Cowboy
cowboy's Avatar
Thought they were full electric drive? I'm sure the ones I have been in were.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1935 Pontiac sedan
1949 Ford F3 pickup
1955 Austin Champ
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
Old 11-09-2007, 09:01 AM   #14
J.C.
Caterpillar are yet to release an electric drive rear dump truck (although I have heard it is on the board if not running around under test conditions). Other manufacturers such as Komatsu have electric drive trucks.
Caterpillar, to my knowledge, have always had mechanical drive rear dumps. From the 769 up to the mighty 797. All mechanical drive.
Old 11-09-2007, 09:22 AM   #15
cowboy
Cowboy
cowboy's Avatar
Ahhh. That explains it them. All the ones I have been in were Komatsu.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1935 Pontiac sedan
1949 Ford F3 pickup
1955 Austin Champ
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
Old 11-09-2007, 09:49 AM   #16
irlewy86
Meep Meep
irlewy86's Avatar
Daylight in the engine block generally bad.
There goes $350,000 in rebuild.
Thundering on....
irlewy86 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 02:40 PM   #17
loxxr6
XB in parts...
loxxr6's Avatar
My brother works for Westrac and we get pics pretty often of all the crashed/broken/etc trucks. They're always good value.
Old 11-09-2007, 03:40 PM   #18
DJM83
Barra Turbo > V8
DJM83's Avatar
Geez it really went bad there. Id love to see one of these things up close and personal just too see how big they really are
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 04:31 PM   #19
tapeworm
tapeworm's Avatar
These things are awesome, do u know how much torque these engine make?
tapeworm is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 04:44 PM   #20
xwgasaxe
under new management
xwgasaxe's Avatar
Terex mining also use GE electric motors for their drive. We supply the OE wheel seals for these.
XW tarmac rally car, 3/4 race cam, NGK spark plugs
xwgasaxe is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 06:21 PM   #21
[Tonko]
What's green is gold
[Tonko]'s Avatar
Yeah i'd like to know this aswell, kw/hp and torque...
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 06:25 PM   #22
irlewy86
Meep Meep
irlewy86's Avatar
I don't know about the Cat.
But Detroit 4000 series 1967 cubic inch (65l) V16 makes 2300hp (1715kw) at 1900 rpm.
Thundering on....
Old 11-09-2007, 06:44 PM   #23
scottsbaxr8
scottsbaxr8's Avatar
Default bloody hell
I have a mat ethat works in mines in Wa he sent me a pick of a ute that accidently got crushed, driver walked out. I will try and find and post
scottsbaxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 06:46 PM   #24
Wokkas
Nothing useless about that mate : . Great read.
Wokkas is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 07:58 PM   #25
v8falconsrule
Blue ~oval~ Blooded!!!
v8falconsrule's Avatar
I remember when I was a little tacker, they had an open day at the Tarong power plant. We saw the draglines, haul trucks and some of the inside of the plant and everything was HUGE! It was truely awe inspiring.
Give me fuel, give me fire!
50th Anniv G6E Turbo in Sensation
Cobalt blue 94 ED XR8 Sprint- resto/ project
v8falconsrule is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 08:01 PM   #26
Yaw
Ford Fanatic
Yaw's Avatar
Looks like an electrical problem....The distributor got knocked off the block by the conrod!
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 08:13 PM   #27
Green X
CAT= Cheep A#$% Tractor LOL, Just kidding.
I got a Video of a MTUDDC 9000 sires V20 Quad turbo at idle on my phone, will try and upload it on the weekend it's big 52,000kg and worth a few million.
FPV GS ute 5.0 S/C
Twin 3-inch, pacemaker headers
Green X is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 08:56 PM   #28
XR6Dan
Why??
XR6Dan's Avatar
Ha, I used to work there - well, next door at Ridgeway. Love the big trucks and shovels!! It's pretty humbling being in a landcruser and one of those suckers goes thundering past.
XR6Dan is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 09:14 PM   #29
gz1
gz1's Avatar
Having never seen an engine even close to this size it makes it hard for me to visualize exactly the scale. Do you have any pics that show the whole engine for reference?
gz1 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2007, 09:47 PM   #30
cowboy
Cowboy
cowboy's Avatar
Rig I'm on at the moment has 5 diesels rated at 6000HP each. 10 feet high by about 25 long.
1927 Pontiac tourer
1928 Pontiac tourer
1929 Pontiac sedan
1935 Pontiac sedan
1949 Ford F3 pickup
1955 Austin Champ
1967 Jeep Gladiator
1975 TD Cortina
1978 F100 4x4
2006 GU Patrol ute
