Old 30-01-2007, 05:43 PM   #1
19bobo68
Default air mode selector switch
can anyone help me please
I am having problems with my air mode switch (the one on the left side of the heater console) on my 1998 au forte.
There seems to be air leak directly behind the switch, Which seem to affect which place the air comes out of in relation to the indicated selection.
Can anyone help me.
cheers Rob
19bobo68 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2007, 06:23 PM   #2
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
So im guessing it's defaulting to the windscreen vents?
Behind the dial is a "loom" of vacuum lines.... chances are, one of them has popped off... maybe even split.
Take the control panel out (might have to remove dash?? not sure, never worked on an AU) and investigate where the leak is coming from. Will (hopefully) be a matter of popping a vac line back on, or removing/replacing/repairing damaged section.
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2007, 07:48 PM   #3
19bobo68
Should it default to windsreen demister, Because my one is not it seems to be working in reverse, for example when placed on the foot well section in blow air from the front vents. Could it still be the vacuum hoses or the vacuum selector switch
Old 03-02-2007, 11:00 AM   #4
19bobo68
Default fixed air mode switch
Thank you all for your help, I found the problem the vacuum switch came apart allowing air the leak past the seal replaced with new one ($23.00 from Ford) all is well again
Many thanks rob
